OTA over serial failure| sdk 15.2
Hello Everyone,
I am using nrf52832 and sdk 15.2 for ota over serial. I have made bootloader for OTA over UART and tested same with nrfutil using my dfu package file. firmware is upgraded successfully and  working fine.
Now I need to upgrade firmware using host MCU. I tried sending dfu package file( .zip ) to nrf52832 over UART using slip librairy to upgrade firmware but it is not working.
Is there any compulsion to send Ping packet, PNR, MTU Packet, init packet, application and bootloader separately over UART?
Can we send directly dfu package created through nrfutil to nrf52832 from other MCU over UART?
Kindly suggest me right approach.
  • Yes, I changed NRF_DFU_SERIAL_UART_RX_BUFFERS  to 10.
    Please check attached 5305.sdk_config.h file.
  • Did you test the pca10040_uart_debug bootloader with the logging turned on?
    What does the bottom of the log from the bootloader say? (The log uses RTT Backend)
    In the case where I used nrfutil, it looks like this:
     0> <debug> app: Shutting down transports (found: 1)
     0> <info> nrf_dfu_serial_uart: Allocated buffer 2000311C
     0> <debug> nrf_dfu_flash: Flash write success: addr=0x00033900, pending 0
     0> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033940, src=0x20003018, len=8 bytes), queue usage: 1
     0> <debug> nrf_dfu_flash: Flash write success: addr=0x00033940, pending 0
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
     0> <debug> nrf_dfu_req_handler: Offset:26952, CRC:0xC312551E
     0> <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
     0> <debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
     0> <debug> nrf_dfu_validation: Hash verification. Firmware start address: 0x2D000, size: 0x6948
     0> <debug> nrf_dfu_validation: Invalidating old application in bank 0.
     0> <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
     0> <debug> nrf_dfu_settings: Writing settings...
     0> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
     0> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
     0> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x20002D48, len=348 bytes), queue usage: 1
     0> <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
     0> <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
     0> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007E000
     0> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 1
     0> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 0
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20002EB4, len=348 bytes), queue usage: 1
     0> <debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 0
     0> <debug> nrf_dfu_req_handler: All flash operations have completed. DFU completed.
     0> <debug> app: Resetting bootloader.
     0> <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
     0> <info> app: Inside main
     0> <debug> app: In nrf_bootloader_init
     0> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
     0> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
     0> <debug> nrf_dfu_settings: Settings OK
     0> <debug> app: Enter nrf_bootloader_fw_activate
     0> <debug> app: Valid App
     0> <debug> app: Enter nrf_dfu_app_continue
     0> <info> nrf_bootloader_wdt: WDT is not enabled
     0> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=7 pages), queue usage: 0
     0> <debug> nrf_dfu_flash: Flash erase success: addr=0x00026000, pending 0
     0> <debug> app: Copying 0x2D000 to 0x26000, size: 0x6948
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x0002D000, len=26952 bytes), queue usage: 1
     0> <debug> nrf_dfu_flash: Flash write success: addr=0x00026000, pending 0
     0> <debug> app: Setting app as valid
     0> <info> app: No firmware to activate.
     0> <debug> app: Enter nrf_dfu_app_is_valid
     0> <debug> app: Return true. App was valid
     0> <warning> nrf_dfu_settings: No additional data erased
     0> <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
     0> <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
     0> <debug> app: running irq table set
     0> <debug> app: After running irq table set
    It would be interresting to see what that log says in your case.
    Edvin
  • The logs are printed using RTT (via the debugger). If you have your programmer attached you can use Segger RTT Viewer to monitor the logs.
  • Hi ,
    no response when used debug code. I tested on DK board and nrfutil.
    How?
    Before going to discuss this I have a question.
    I you see DFU_logs (1).txt, there is response( 60 01 03 ) for create object for last 3780 bytes but for previous packets it is different (60 01 01). Why it is  NRF_DFU_RES_CODE_INVALID_PARAMETER = 0x03?
    In nrfutil dfu_nrfutil.txt it is showing 0x01.
    It may reason behind dfu fail.
