sd_ble_gatts_rw_authorize_reply() return SUCCESS by long-length parameter
When create 128byte length's CHARACTERISTIC and read with NRFCONNECT on Android.
NRFCONNECT returns GATT_READ_NOT_PERMIT even though sd_ble_gatts_rw_authorize_reply() completes normally.
code is folowing,
Why sd_ble_gatts_rw_authorize_reply return SUCCESS?
#define	BUFFER_LENGTH				(128)
attr_md.vloc    = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 1;
attr_md.wr_auth = 1;
attr_md.vlen    = 0;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid    = uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_offs = 0;
attr_char_value.init_len  = BUFFER_LENGTH;
attr_char_value.max_len   = BUFFER_LENGTH;
attr_char_value.p_value   = nullptr;
APP_ERROR_CHECK(sd_ble_gatts_characteristic_add(service_handle,
                          &char_md,
                          &attr_char_value,
                          char_param->p_handle));
case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
if ( p_ble_evt->evt.gatts_evt.params.authorize_request.type == BLE_GATTS_AUTHORIZE_TYPE_READ ) {
    reply.params.read.len = BUFFER_LENGTH;
    reply.params.read.offset = 0;
    reply.params.read.p_data = buffer;
	reply.params.read.update = 1;
	reply.params.read.gatt_status = BLE_GATT_STATUS_SUCCESS;
    APP_ERROR_CHECK(sd_ble_gatts_rw_authorize_reply(m_conn_handle, &reply));
  • Sorry,
    char_param->value_length -> replace 128
    >I am not sure what you are trying to show with the latest snippets
    this is setup for characteristic by 128-byte length, and this length is greater than MAX_ATT.
    Again say,
    I think that sd_ble_gatts_rw_authorize_reply() would return an error if called with a length greater than ATT_MTU. But it actually succeeds.
    I just want to know if this is the right move.
    Sorry for the late reply. We have been short staffed during the Christmas Holidays.
    So where in the snippet do you set the ATT_MTU? If it returns NRF_SUCCESS (0), then the softdevice will split up the package. Are you missing data on the receiving side?
  • >where in the snippet do you set the ATT_MTU?
    No. I use default setting.
    I try to read nrfconnect for mobile.
    It's return 'Error2(0x2):GATT READ NOT PERMIT
  • Ok. I think we are looking in the wrong place now. If that is the return value, it has nothing to do with the length of the characteristic. It has to do with the permissions for the characteristic.
    From your snippets I can't see that you are missing any permission settings, but I see that you are missing some uuid settings
    I suggest that you take a look at the ble_app_uart, in rx_char_add() in ble_nus.c:
    static uint32_t rx_char_add(ble_nus_t * p_nus, const ble_nus_init_t * p_nus_init)
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_t    attr_char_value;
        ble_uuid_t          ble_uuid;                       //This is missing
        ble_gatts_attr_md_t attr_md;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.write         = 1;
        char_md.char_props.write_wo_resp = 1;
        char_md.p_char_user_desc         = NULL;
        char_md.p_char_pf                = NULL;
        char_md.p_user_desc_md           = NULL;
        char_md.p_cccd_md                = NULL;
        char_md.p_sccd_md                = NULL;
        ble_uuid.type = p_nus->uuid_type;                   //This is missing
        ble_uuid.uuid = BLE_UUID_NUS_RX_CHARACTERISTIC;     //This is missing
        memset(&attr_md, 0, sizeof(attr_md));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
        attr_md.rd_auth = 0;
        attr_md.wr_auth = 0;
        attr_md.vlen    = 1;
        attr_char_value.p_uuid    = &ble_uuid;                  //This is missing
        attr_char_value.init_len  = 1;
        attr_char_value.max_len   = BLE_NUS_MAX_RX_CHAR_LEN;
        return sd_ble_gatts_characteristic_add(p_nus->service_handle,
                                               &char_md,
                                               &attr_char_value,
                                               &p_nus->rx_handles);
    But compare how you add the characteristic to this example, and see if you can find any other differences.
    Edvin
  • > If that is the return value, it has nothing to do with the length of the characteristic.
    In other words, doesn't error occur even if reply.params.read.len is larger than ATT_MTU?
