Scanning cannot find Public MAC
Hello:
I have set the scanning module to search devices by MAC address.  It finds the devices that are using a Static Random address, but it cannot find the ones using a Public Static address.
I can see and connect to both using NRF Connect BLE.  I am using the Rigardo module.
Here is the code I use to start the scanning module:
ret_code_t connect_to_mac(uint8_t mac[]) {
  ret_code_t err_code;
  if (isConnected()) {
    uint8_t mac[6];
    getCurrentMac(mac);
    disconnect_from_mac(mac);
  nrf_ble_scan_stop();
  nrf_ble_scan_all_filter_remove(&m_scan);
  nrf_ble_scan_init_t init_scan;
  ble_gap_addr_t m_mac_filter;
  m_mac_filter.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC;
  err_code = nrf_ble_scan_copy_addr_to_sd_gap_addr(&m_mac_filter, mac);
  if (err_code == NRF_SUCCESS) {
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
      err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER, &m_mac_filter.addr);
      err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_ADDR_FILTER, false);
      err_code = scan_start();
#ifdef DEBUG
        char *msg = malloc(255);
        sprintf(msg, "SCANNING FOR %x:%x:%x:%x:%x:%x TYPE %d",
            m_mac_filter.addr[0],
            m_mac_filter.addr[1],
            m_mac_filter.addr[2],
            m_mac_filter.addr[3],
            m_mac_filter.addr[4],
            m_mac_filter.addr[5],
            m_mac_filter.addr_type);
        err_code = sendStatusToUART(msg);
        free(msg);
#else
        err_code = sendStatusToUART(STATUS_SCANNING);
    BLE_ERROR_CHECK(err_code);
  } else {
    sendErrorToUART(ERROR_INVALID_MAC);
  return err_code;
Can you please point me to any ideas?  The only difference between the two devices is that one MAC is public (using Rigardo defined hardware address) and the other is Random Static.
Are there any limitations on the softdevice for hardware public address?
Juan
  • This might be a bug. I will talk to the developers and try to get to the bottom of it.
    Simon
  • What SDK are you using? I was not able to recreate your issue in SDK 16. Could you copy SDK16/examples/ble_central into a new folder and copy the following into main.c:
     * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "nordic_common.h"
    #include "app_error.h"
    #include "app_uart.h"
    #include "ble_db_discovery.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "ble_nus_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
    #define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
    #define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
    BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE Nordic UART Service (NUS) client instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
    NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
    NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                        /**< BLE GATT Queue instance. */
                   NRF_SDH_BLE_CENTRAL_LINK_COUNT,
                   NRF_BLE_GQ_QUEUE_SIZE);
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    /**@brief NUS UUID. */
    static ble_uuid_t const m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
    /**@brief Function for handling asserts in the SoftDevice.
     * @details This function is called in case of an assert in the SoftDevice.
     * @warning This handler is only an example and is not meant for the final product. You need to analyze
     *          how your product is supposed to react in case of assert.
     * @param[in] line_num     Line number of the failing assert call.
     * @param[in] p_file_name  File name of the failing assert call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for handling the Nordic UART Service Client errors.
    static void nus_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function to start scanning. */
    static void scan_start(void)
        ret_code_t ret;
        ret = nrf_ble_scan_start(&m_scan);
        APP_ERROR_CHECK(ret);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch(p_scan_evt->scan_evt_id)
             case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                  err_code = p_scan_evt->params.connecting_err.err_code;
             } break;
             case NRF_BLE_SCAN_EVT_CONNECTED:
                  ble_gap_evt_connected_t const * p_connected =
                                   p_scan_evt->params.connected.p_connected;
                 // Scan is automatically stopped by the connection.
                 NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                          p_connected->peer_addr.addr[0],
                          p_connected->peer_addr.addr[1],
                          p_connected->peer_addr.addr[2],
                          p_connected->peer_addr.addr[3],
                          p_connected->peer_addr.addr[4],
                          p_connected->peer_addr.addr[5]
             } break;
             case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                 NRF_LOG_INFO("Scan timed out.");
                 scan_start();
             } break;
    /**@brief Function for initializing the scanning and setting the filters.
    static void scan_init(void)
        memset(&m_mac_filter, 0, sizeof(m_mac_filter));
        m_mac_filter.addr[0] = 0x11;
        m_mac_filter.addr[1] = 0x22;
        m_mac_filter.addr[2] = 0x33;
        m_mac_filter.addr[3] = 0x44;
        m_mac_filter.addr[4] = 0x55;
        m_mac_filter.addr[5] = 0x66;
        /*NRF_LOG_INFO("Filter address (before activating) %x:%x:%x:%x:%x:%x TYPE %d",
                m_mac_filter.addr_type);*/
        NRF_LOG_INFO("Filter address (before activating) %x:%x:%x:%x:%x:%x",
            m_mac_filter.addr[5]);
        NRF_LOG_INFO("Filter address type (before activating): %d", m_mac_filter.addr_type);
        nrf_ble_scan_filters_t filters;
        memset(&filters, 0, sizeof(nrf_ble_scan_filters_t));
        nrf_ble_scan_filter_get(&m_scan, &filters);
        NRF_LOG_INFO("Filter address (after activating): COUNT=N/A ENABLED=N/A ADDRESS=%x:%x:%x:%x:%x:%x",
              /*filters.addr_filter.addr_cnt,
              filters.addr_filter.addr_filter_enabled,*/
              filters.addr_filter.target_addr[0].addr[0],
              filters.addr_filter.target_addr[0].addr[1],
              filters.addr_filter.target_addr[0].addr[2],
              filters.addr_filter.target_addr[0].addr[3],
              filters.addr_filter.target_addr[0].addr[4],
              filters.addr_filter.target_addr[0].addr[5]);
         NRF_LOG_INFO("Filter address type (after activating): %d", filters.addr_filter.target_addr[0].addr_type);
        /*err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
        APP_ERROR_CHECK(err_code);*/
    /**@brief Function for handling database discovery events.
     * @details This function is a callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function forwards the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    /**@brief Function for handling characters received by the Nordic UART Service (NUS).
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        ret_code_t ret_val;
        NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
        if (p_data[data_len-1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
        if (ECHOBACK_BLE_UART_DATA)
            // Send data back to the peripheral.
            do
                ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
     * @details This function receives a single character from the app_uart module and appends it to
     *          a string. The string is sent over BLE when the last character received is a
     *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
        static uint16_t index = 0;
        uint32_t ret_val;
        switch (p_event->evt_type)
            /**@snippet [Handling data from UART] */
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= (m_ble_nus_max_data_len)))
                    do
                        ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                        if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                    } while (ret_val == NRF_ERROR_RESOURCES);
                    index = 0;
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
            case APP_UART_FIFO_ERROR:
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling Nordic UART Service (NUS) client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
     * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                NRF_LOG_INFO("Disconnected.");
                scan_start();
     * @brief Function for handling shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
                // Prepare wakeup buttons.
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_CONNECTED:
                err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
                NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                             p_gap_evt->conn_handle,
                             p_gap_evt->params.disconnected.reason);
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
                // Pairing not supported.
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("ATT MTU exchange completed.");
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in] event  Event generated by button press.
        switch (event)
            case BSP_EVENT_SLEEP:
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Function for initializing the Nordic UART Service (NUS) client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler   = ble_nus_c_evt_handler;
        init.error_handler = nus_error_handler;
        init.p_gatt_queue  = &m_ble_gatt_queue;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    /**@brief Function for initializing buttons and leds. */
    static void buttons_leds_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the nrf log module. */
    static void log_init(void)
    /** @brief Function for initializing the database discovery module. */
    static void db_discovery_init(void)
        ble_db_discovery_init_t db_init;
        memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
        db_init.evt_handler  = db_disc_handler;
        db_init.p_gatt_queue = &m_ble_gatt_queue;
        ret_code_t err_code = ble_db_discovery_init(&db_init);
     * @details Handles any pending log operations, then sleeps until the next event occurs.
            nrf_pwr_mgmt_run();
        // Initialize.
        log_init();
        timer_init();
        uart_init();
        buttons_leds_init();
        db_discovery_init();
        power_management_init();
        ble_stack_init();
        gatt_init();
        nus_c_init();
        scan_init();
        // Start execution.
        printf("BLE UART central example started.\r\n");
        NRF_LOG_INFO("BLE UART central example started.");
        scan_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    I got the following output:
    <info> app_timer: RTC: initialized.
    <info> app: Filter address (before activating) 11:22:33:44:55:66
    <info> app: Filter address type (before activating): 0
    <info> app: Filter address (after activating): COUNT=N/A ENABLED=N/A ADDRESS=11:22:33:44:55:66
    <info> app: Filter address type (after activating): 0
    <info> app: BLE UART central example started.
    Could you check if you are getting the same output?
    Simon
  • After a year, using the nRF5_SDK_17.0.2_d674dde has same issue when using other BLE device other than nRF device.
    Why not allow Application to pass the ble_gap_addr_t instead of just char* in the nrf_ble_scan_name_filter_add()
  • Could you open a new ticket and ask the question there?
    Simon
