Putty Displaying this weird character ▒▒0▒▒▒▒▒▒3^▒▒▒▒▒▒▒▒▒▒▒▒▒d▒▒▒▒▒ . How to solve it ??
I already follow the link for terminal in this link  https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v16.0.0%2Flib_cli.html&cp=6_1_3_10_3&anchor=lib_cli_terminal_settings .
From android apps sent message to mcu the message is not display in putty. While when sending from mcu  to android apps it display this weird character.
  • #define HCI_UART_BAUDRATE 30801920   in sdk_config.h
    in putty is 115200. Do I need to change the speed in sdk_config.h ?
     In the sdk_config.h, 30801920 means 115200 baud.
    The setting should be fine on the both sides.
    Could you share the sdk_config.h?
    -Amanda H
    If you want to use the terminal tool to see the log, please add the following setting in the sdk_config.h
    // <e> NRF_LOG_BACKEND_UART_ENABLED - nrf_log_backend_uart - Log UART backend
    #ifndef NRF_LOG_BACKEND_UART_ENABLED
    #define NRF_LOG_BACKEND_UART_ENABLED 1
    // <o> NRF_LOG_BACKEND_UART_TX_PIN - UART TX pin
    #ifndef NRF_LOG_BACKEND_UART_TX_PIN
    #define NRF_LOG_BACKEND_UART_TX_PIN 6
    // <o> NRF_LOG_BACKEND_UART_BAUDRATE  - Default Baudrate
    // <323584=> 1200 baud
    // <643072=> 2400 baud
    // <1290240=> 4800 baud
    // <2576384=> 9600 baud
    // <3862528=> 14400 baud
    // <5152768=> 19200 baud
    // <7716864=> 28800 baud
    // <10289152=> 38400 baud
    // <15400960=> 57600 baud
    // <20615168=> 76800 baud
    // <30801920=> 115200 baud
    // <61865984=> 230400 baud
    // <67108864=> 250000 baud
    // <121634816=> 460800 baud
    // <251658240=> 921600 baud
    // <268435456=> 1000000 baud
    #ifndef NRF_LOG_BACKEND_UART_BAUDRATE
    #define NRF_LOG_BACKEND_UART_BAUDRATE 30801920
    // <o> NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings.
    // <i> Size of the buffer is a trade-off between RAM usage and processing.
    // <i> if buffer is smaller then strings will often be fragmented.
    // <i> It is recommended to use size which will fit typical log and only the
    // <i> longer one will be fragmented.
    #ifndef NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE
    #define NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE 64
    // </e>
    Also, enable NRF_LOG_ENABLED as
    // <e> NRF_LOG_ENABLED - nrf_log - Logger
    #ifndef NRF_LOG_ENABLED
    #define NRF_LOG_ENABLED 1
    -Amanda H.
  • Already solved it because the speed in putty i set 15200. Not 115200
