How to update advertised TX power?
Using the 15.3 SDK and the 6.1 software device I am successfully changing the transmit power as needed.  When not connected and advertising I would like to update the advertised TX power initialized with:
init.srdata.p_tx_power_level
I have read multiple, multiple posts to DevZone regarding updating the advertising information but so many are out of date or links are broken.  Given advertising the transmit power must be a rather routine situation I'm assuming there is some simple way to do the update.  If there is not a simple way could you provide a complete SDK 15.3, SD 6.1 compatible method example please?  I'm sure others would appreciate a recent example.
Any help would be appreciated as we are doing a pre-production run in China in about two weeks and I would like to have this addressed.  I'm not willing to update to SDK 16.0 because of how close to pre-production date.
Sincerely,
Michael M.
  • We do not have any example to show you, but I can make a simple one like you initially requested but unfortunately I can only do that after i come back from the holidays after the new year. I will keep this case open in my queue until then as a reminder.
  • Hi Susheel,
    I noticed you were back from the holidays and responding to new questions.
    Any progress on my example request of a month ago?
    Looking forward to hearing from you!
    Sincerely,
    Michael
  • Sorry Michael, I am sick at home and trying to answer questions that i already know. I have asked my colleagues to take a look at this. Sorry for the delays.
  • Hi Michael,
    As Susheel wrote, the only thing you need to do to update the advertising data in the scan response or advertising packet is to call sd_ble_gap_adv_set_configure() with the new advertising buffer. So essentially you just build it like before, changing the tx_power field. Since you are just updating the advertising data, the third/last parameter should be NULL, to keep the old configuration. If you are currently advertising, you need to use a different memory buffer for the advertising set, since the SoftDevice does not allow updating an advertising buffer that is currently in use.
    You can refer to the attached file, which is the BLE blinky application for SDK 15.3, modified so that you can pus button 2 to change the Tx power and the Tx power that is advertised. This drops right into the BLE Blinky example application project if you want to test it.
     * Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample server application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "Nordic_Blinky"                         /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define INITIAL_ADV_BUF_OFFSET          0
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[2][BLE_GAP_ADV_SET_DATA_SIZE_MAX];                 /**< Buffers for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[2][BLE_GAP_ADV_SET_DATA_SIZE_MAX];      /**< Buffers for storing an encoded scan data. */
    static int8_t  m_tx_power = 0;
    static const int8_t m_tx_power_list[] = {0, -8, -20};
    static uint32_t m_tx_power_index = 0;
    static uint8_t m_adv_buff_offset = INITIAL_ADV_BUF_OFFSET;
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata[INITIAL_ADV_BUF_OFFSET],
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_scan_response_data[INITIAL_ADV_BUF_OFFSET],
    static void adv_data_buf_swap(void)
        m_adv_buff_offset = (m_adv_buff_offset + 1) % 2;
        m_adv_data.adv_data.p_data = m_enc_advdata[m_adv_buff_offset];
        m_adv_data.scan_rsp_data.p_data = m_enc_scan_response_data[m_adv_buff_offset];
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
        ret_code_t              err_code;
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    static void advertising_data_build(void)
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        ble_advdata_t advdata;
        ble_advdata_t srdata;
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        srdata.p_tx_power_level = &m_tx_power;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_gap_adv_params_t adv_params;
        // Build and set advertising data.
        advertising_data_build();
        // Set advertising parameters.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.p_peer_addr     = NULL;
        adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        adv_params.interval        = APP_ADV_INTERVAL;
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
    static void advertising_update(void)
        // Use other advertising buffers since updating a currently used buffer is not allowed by the SoftDevice
        adv_data_buf_swap();
        // Configure SoftDevice to use new advertising data without changing other configuration
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, NULL);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON!");
            bsp_board_led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF!");
        ble_lbs_init_t     init     = {0};
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        bsp_board_led_on(ADVERTISING_LED);
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                bsp_board_led_on(CONNECTED_LED);
                bsp_board_led_off(ADVERTISING_LED);
                //err_code = app_button_enable();
                NRF_LOG_INFO("Disconnected");
                bsp_board_led_off(CONNECTED_LED);
                //err_code = app_button_disable();
                advertising_start();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    static void update_tx_power(void)
        m_tx_power = m_tx_power_list[++m_tx_power_index % sizeof(m_tx_power_list)];
        NRF_LOG_INFO("Update TX power to %i dBm", m_tx_power);
        // Set new TX power
        err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, m_tx_power);
        // Update advertising data to include current Tx power
        advertising_update();
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            case BSP_BUTTON_1:
                if (button_action == APP_BUTTON_PUSH)
                    NRF_LOG_INFO("Send button state change.");
                    update_tx_power();
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler},
            {BSP_BUTTON_1, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Function for application main entry.
        // Initialize.
        log_init();
        leds_init();
        timers_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("Blinky example started.");
        // Enter main loop.
        for (;;)
            idle_state_handle();
