UART interrupt missing
I am using SDK SDK_15.3.0_59ac345 with soft device in application that controls a GPS IC from UART (AT command), also the application is running in background beacon adv. (timeslot) and from time to time ble normal adv and gatt connection etc.
Everything is working fine but from time to time UART gets freeze, I mean cannot get data from UART.
I use flow control on, and UART (not UARTE), together with app_uart_fifo at 115200, init is like this:
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.flow_control = eFlow,
.use_parity = false,
.baud_rate = uiUartSpeed
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_HIGHEST,
err_code);
What I found after several days of investigation, is that the lose happens when Nordic is loaded with many task.
I can reproduce if I force to pair during UART transmission (with beacon timeslot in background), from this point even I wait forever I cannot get any interrupt (nor data if try to force reading) from app_uart_get() in the interrupt handler.
Going down to the driver I found that if in this situation I make a manual byte read from UART (DataArray[uiIndex] = NRF_UART0->RXD) the data is there and just after this read everthing continue normally without any data lose till next freeze.
Actually I have a background task that if there are more than 150ms without interrupts while I am reading from UART it makes this manual data reading to unlock the system.
I added some prints on nrfx_uart.c on uart_irq_handler at top of the function I added:
NRFX_LOG_INFO("Function: %s, interrrupt (rx)%d (tx)%d (txrdy)%d (rxrdy)%d (err)%d", __func__,
nrf_uart_int_enable_check(p_uart, NRF_UART_INT_MASK_RXDRDY),
nrf_uart_int_enable_check(p_uart, NRF_UART_INT_MASK_TXDRDY),
nrf_uart_event_check(p_uart, NRF_UART_EVENT_TXDRDY),
nrf_uart_event_check(p_uart, NRF_UART_EVENT_RXDRDY),
nrf_uart_event_check(p_uart, NRF_UART_EVENT_ERROR));
This means every interrupt I get a print out but when system becomes locked no printout is done so the interrupt doesn't come.
From the log (RTT) I get this:
***** Here I send AT+QGPSLOC=2 commadn by UART*********
<00> info> UART: Function: uart_irq_handler, interrrupt (rx)1 (tx)1 (txrdy)1 (rxrdy)0 (err)0
<00> info> app: UART APP_UART_TX_EMPTY
***** Here I start reading from UART echo+command reply*********
<00> info> UART: Function: uart_irq_handler, interrrupt (rx)1 (tx)1 (txrdy)0 (rxrdy)1 (err)0
<00> info> UART: Function: rx_byte, reading
***** Here system is waiting more than 150ms without any new character read from UART and mannually read a 'S' byte 5th of the reply buffer*********
<00> info> app: at_read_command: Cannot receive message, S byte 5
***** From here everything goes on normally*********
***** Here reply echo+answer end and took 184ms (150ms elapsed) normally doesn't take more than 30ms with log on and without log 3/4ms*********
<00> info> app: sleep_duration(OK)=6051-184
<00> info> AT+QGPSLOC=2
+CME ERROR: 516
This happens randomly at different position, most of the times works fine.
It seems that NRF_UART_EVENT_RXDRDY doesn't come (before manual NRF_UART0->RXD I check RXDRDY but it is not set), I read documentation and the it seems that but only way that this event is not generated is because already set to 0 after a read but this case is not because byte is on NRF_UART0->RXD and the only place the byte is read is on rx_byte function (also in log) which always set to 0 and then read which is normal sequence.
Is there any clue or way to understand why this happen?
Thank you!
