enable LE Ping with pc-driver-ble-py
HIi
I am using the pc-driver-ble_py library to build a central in order to test a peripheral. At this point, I am interested in starting a LE ping and I saw that I should use the function sd_ble_opt_set.
I am trying to add the necessary code in the driver.py in order to be able to set the auth_payload_timeout however I always get the error : "in method 'sd_ble_opt_set', argument 3 of type 'ble_opt_t const *'", argument 3 is p_opt.
I created the class BLEGapPayload to use it as a p_opt input, but still the same error
class BLEGapPayload(object):
def __init__(
self,
conn_handle,
self.conn_handle = conn_handle
self.auth_payload_timeout = auth_payload_timeout
@classmethod
def from_c(cls, opt_auth_payload_timeout):
return cls(
conn_handle = opt_auth_payload_timeout.conn_handle,
auth_payload_timeout = opt_auth_payload_timeout.auth_payload_timeout
def to_c(self):
opt_auth_payload_timeout = driver.ble_gap_opt_auth_payload_timeout_t()
opt_auth_payload_timeout.conn_handle = self.conn_handle
opt_auth_payload_timeout.auth_payload_timeout = self.auth_payload_timeout
return opt_auth_payload_timeout
putting a constant value in p_opt doesn't work obviously
Can you guide me through this? I know the library doesn't support this functionality yet, Am i in the right direction? thanks in advance
  • No i can continue other tests that require the connexion and they work just fine (no disconnection event received either) I wonder if it is possible for you to test this with the library pc-ble-driver_py and see what you get as an answer.
  • Can you show me the function where you call this? I need to know what context you use it in, and how you pass the connection handle into the function.
    Edvin
  • Here's how I implement the function and where the conn_handle comes from
    self.conn_handle = conn_handle (during on_gap_evt_connected(…) function added in our program)
    self.conn_handle = None (during on_gap_evt_disconnected (…) function added in our program)
    Output debug on our program:
    Nom
    Valeur
    Type
    opt
    <lib.pc_ble_driver_py.ble_driver.BLEOptGapChMap object at 0x00000000031D7D68>
    BLEOptGapChMap
    ◢ ch_map
    [0, 0, 0, 0, 0]
    list
    [0]
    0x0
    int
    [1]
    0x0
    int
    [2]
    0x0
    int
    [3]
    0x0
    int
    [4]
    0x0
    int
    conn_handle
    0x0
    int
    Function in our program:
    def GetChannelMapUpdate(self):
           if(self.conn_handle == None):
            opt = BLEOptGapChMap()
            opt.conn_handle = self.conn_handle
            opt.ch_map = [0x00, 0x00, 0x00, 0x00, 0x00]
    self.driver.ble_opt_get(BLEOpt.gap_ch_map, opt)
    New classes add in ble_driver.py:
    class BLEOptGapChMap(object):
        def __init__(self, conn_handle=1, ch_map=[0xFF, 0xFF, 0xFF, 0xFF, 0xFF]):
            self.ch_map = ch_map
        def to_c(self):
            opt = driver.ble_opt_t()
            opt.gap_opt.ch_map.conn_handle = self.conn_handle
            ch_map_array = util.list_to_uint8_array(self.ch_map[::])
            opt.gap_opt.ch_map.ch_map = ch_map_array.cast()
            return opt
    class BLEOpt(Enum):
        common_pa_lna = driver.BLE_COMMON_OPT_PA_LNA
        common_conn_evt_ext = driver.BLE_COMMON_OPT_CONN_EVT_EXT
        gap_ch_map = driver.BLE_GAP_OPT_CH_MAP
        gap_local_conn_latency = driver.BLE_GAP_OPT_LOCAL_CONN_LATENCY
        gap_passkey = driver.BLE_GAP_OPT_PASSKEY
        gap_scan_req_report = driver.BLE_GAP_OPT_SCAN_REQ_REPORT
        gap_compat_mode_1 = driver.BLE_GAP_OPT_COMPAT_MODE_1
        gap_auth_payload_timeout = driver.BLE_GAP_OPT_AUTH_PAYLOAD_TIMEOUT
        gap_slave_latency_disable = driver.BLE_GAP_OPT_SLAVE_LATENCY_DISABLE
    New function added in ble_driver.py:
    def ble_opt_get(self, opt_id, opt):
            err_code = driver.sd_ble_opt_get(
                self.rpc_adapter, opt_id.value, opt.to_c()
            return err_code
  • For some reason I thought the issue was that the function returned something saying that the conn_handle was invalid, but it isn't right? Is this a compiler error?
  • That is exactly the problem. The softdevice returns the error 0x3002 as I mentioned above (isn't it a conn_handle error for the function ble_opt_get? Did I say something that confused you about the problem?
