Behavior of sd_ble_gap_conn_param_update
Peripheral: nrf52832
Central: nrf52840
The communication speed after executing sd_ble_gap_conn_param_update is different in the following two cases.
case 1:
When the BLE_GAP_EVT_CONNECTED event occurs,
Call sd_ble_gap_conn_param_update to update the communication parameter to the value of B.
case 2:
Call sd_ble_gap_conn_param_update to update the communication parameter to the value of A.
When BLE_GATTS_EVT_WRITE event occurs after BLE communication is established,
call sd_ble_gap_conn_param_update to update the communication parameters to the value of B.
A Parameter
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(50, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(65, UNIT_1_25_MS)
#define SLAVE_LATENCY 3
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)
B Parameter
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS)
#define SLAVE_LATENCY 0
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(10000, UNIT_10_MS)
Expect Behavior
Case 1 and case 2 have the same communication speed.
Actual Behavior
Case 1 has a much faster communication speed.
Is sd_ble_gap_conn_param_update used incorrectly?
Both update to the value of parameter B, but I don't know the reason for the difference in speed.
  • Based on your case history, I guess that you are using SDK15.3.0, is that correct?
    In SDK15.3.0, the min and max connection interval settings of the central is found in sdk_config.h. Search for "NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL" and "NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL".
    Make sure that both A and B are within the min and max of the central.
    Then you must wait for the BLE_GAP_EVT_CONN_PARAM_UPDATE for the new connection parameters to take effect.
    If that still doesn't seem to work, is it possible to do a sniffer trace using nRF Sniffer?
  • >>Based on your case history, I guess that you are using SDK15.3.0, is that correct?
    Yes, using Central is SDK15.3.0.
    Each parameter had the following values:
    #define NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL 7.5
    #define NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL 30
    A Parameter is out of range.
    B Parameter is in range.
    Changed to the following values.
    #define NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL 15
    #define NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL 65
    However, even with this change, the communication parameters changed after the NEXT_CONN_PARAMS_UPDATE_DELAY time.
    Waiting to receive BLE_GAP_EVT_CONN_PARAM_UPDATE
    Param update will not be performed again until this event arrives.
    However, the communication parameters are updated after the NEXT_CONN_PARAMS_UPDATE_DELAY time has elapsed.
    Can I provide a sniffer log file obtained with WireShark?
  • static void gap_params_init(void)
    gap_conn_params.min_conn_interval = FAST_MIN_CONN_INTERVAL;
    gap_conn_params.slave_latency = SLAVE_LATENCY;
    gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
    The value set here was A Parameter.
    When B parameter was checked with the function of is_conn_params_ok (), it became NG and the timer started.
    Including the parameters A and B in the value set by gap_params_init () no longer causes problems.
