NRF9160 BSD socket "send function" isn't blocked.
I use BSD socket to send and receive messages to a TCP server over LTE network.
When I send multiple messages by using send() (with flags = 0) function, I get an EINPROGRESS error.
It seems that send() function is not blocked.
I'm currently using the v1.1.0 release.
How can I fix this problem?
  • errono 119, and It always happens (even with newlibc).
    Meni
  • Could this be due to a former socket operation that is on-going?
    What happens if you treat EINPROGRESS as a EAGAIN, ie: you try to send the same data again?
    Håkon
  • No, It does not work.
    The only way it works is when I add a delay after send command.
    Meni
    I am very sorry for the late feedback.
    You mention that you send and receive. Do you have other threads running modem traffic in your firmware?
    Could you provide an example so I can try to recreate this at my end and debug further?
    Håkon
    No, I have only one thread that uses the modem.
    Attached is a source code that describes this thread.
    Meni
    ERROR_STATUS server_connect(uint8_t* url, uint16_t port, int *client_fd)
      ERROR_STATUS err_state;
      err_state = modem_configure();
      if(err_state)
        return err_state;
      struct addrinfo *res;
      int err = getaddrinfo(url, NULL, NULL, &res);
      printk("getaddrinfo err: %d\n\r", err);
      if(err)
        return STATUS_URL_ERROR;
      ((struct sockaddr_in *)res->ai_addr)->sin_port = htons(port);
      struct sockaddr_in local_addr;
      local_addr.sin_family = AF_INET;
      local_addr.sin_port = htons(0);
      local_addr.sin_addr.s_addr = 0;
      *client_fd = socket(AF_INET, SOCK_STREAM, 0);
      printk("client_fd: %d\n\r", *client_fd);
      err = bind(*client_fd, (struct sockaddr *)&local_addr, sizeof(local_addr));
      if(err)
        printk("bind err: %d\n\r", err);
        return STATUS_CONNECTION_ERROR;
      err = connect(*client_fd, (struct sockaddr *)res->ai_addr, sizeof(struct sockaddr_in));
      if(err < 0)
        printk("connect err: %d\n\r", errno);
      freeaddrinfo(res);
      printk("connected to server\n\r");
      return STATUS_NO_ERROR;
    ERROR_STATUS blocking_send(int sock, u8_t *buf, u32_t datalen, u32_t flags, uint32_t timeout)
       u32_t offset = 0U;
       volatile static int ret;
       s64_t  time_stamp = k_uptime_get();
       s64_t  milliseconds_spent = 0;
       while ((offset < datalen)&&(milliseconds_spent <timeout))
          ret = send(sock, buf + offset,
                     MIN(4096, (datalen - offset)), flags);
          if (ret < 0)
             return -errno;
          offset += ret;
          milliseconds_spent += k_uptime_delta(&time_stamp);
      if(milliseconds_spent >= timeout)
              return STATUS_TIMEOUT;
       return 0;
    ERROR_STATUS blocking_recv(int fd, u8_t *buf, u32_t size, u32_t flags, uint32_t timeout)
            volatile static int err;
    	do {
    		err = recv(fd, buf, size, flags);
                    k_sleep(10);
              } while ((err <= 0)&&(milliseconds_spent<timeout));
           if (err < 0)
              printk("recv socket err: %d, errno: %d\r\n", err, errno);
              return err;
    static void server_thread_fn(void *arg1, void *arg2, void *arg3)
    	int client_fd;
        while(true)
                k_msgq_get(&xServerQueue, &task_com, K_FOREVER);
    			uint8_t* buffer = k_malloc(9000);
    			memset(buffer,0,9000);
    			server_connect(url,port,&client_fd);
    			blocking_send(client_fd,buffer,9000,0,60000);
    			blocking_recv(client_fd,buffer,9000,0,60000);
    			close(client_fd);
