nrf 9160 Serial LTE Modem
Hello All,
I used the sample Serial LTE modem code and downloaded it to nrf9160. Can some please help me with a sample AT commands to send to tcp/udp server and how should I receive it on the server (like a basic implementation). It would great help.
Thanks
Regards
Nordic user
  • You are correct, sorry about that. I see now that +CESQ is returning an rsrp number at the end of the file.
    Could you enable CONFIG_AT_CMD_LOG_LEVEL_DBG=y in the prj.conf file and reflash the firmware? And in the meantime, I will have somebody take a look at your modem trace.
  • It seems that, after updating the zephyr. I was able to run this example. Thanks for the help Heidi.
  • Hi Heidi,
    Recently I have been working on this example. The file which you attached which details the AT commands works perfectly for TCP and UDP communication. Thanks to you. Now I have been trying to use the gps at commands but it gives me following error. I tried to run the same command before and after AT+CFUN=1. That is before starting the modem and after starting the modem. But it still doesn't seem to work. Could please help me understand and solve this issue? I would really appreciate it.
    Regards
  • Hi Purvesh,
    Can you try the following commands and let me know if this works:
    AT%XSYSTEMMODE=0,0,1,0
    AT%XMAGPIO=1,0,0,1,1,1574,1577
    AT%XCOEX0=1,1,1570,1580
    AT+CFUN=1
    AT#XGPSRUN=1,3
    AT#XGPSRUN?
    AT#XGPSRUN=0
    AT#XGPSRUN?
    Please provide a full output log in a text file not a screenshot of the terminal. If you're using LTE Link Monitor, you can press the button below to open the log in a text file. Please save it and attach it in your next comment by selecting Insert -> Insert image/video/file
    Heidi
  • Hi Heidi,
    Please find attached the log file to this comment. Also I tried the commands but doesn't seem to work. I placed the board at same place where I used to get -7 healthy satellites.
    2020-03-10T00:02:36.399Z INFO Application data folder: C:\Users\ptrac\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2020-03-10T00:02:36.455Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2020-03-10T00:02:36.455Z DEBUG App path: C:\Users\ptrac\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2020-03-10T00:02:36.455Z DEBUG nRFConnect 3.3.0 is supported by the app (^3.2.0)
    2020-03-10T00:02:36.455Z DEBUG nRFConnect path: C:\Users\ptrac\AppData\Local\Programs\nrfconnect\resources\app.asar
    2020-03-10T00:02:36.455Z DEBUG HomeDir: C:\Users\ptrac
    2020-03-10T00:02:36.455Z DEBUG TmpDir: C:\Users\ptrac\AppData\Local\Temp
    2020-03-10T00:02:43.234Z INFO Modem port is opened
    2020-03-10T00:02:43.238Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-03-10T00:02:43.254Z DEBUG modem << +CFUN: 1\x0D\x0A
    2020-03-10T00:02:43.256Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.269Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2020-03-10T00:02:43.275Z DEBUG modem << +CGSN: "352656100159477"\x0D\x0A
    2020-03-10T00:02:43.276Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.281Z DEBUG modem >> AT+CGMI\x0D\x0A
    2020-03-10T00:02:43.287Z DEBUG modem << Nordic Semiconductor ASA\x0D
    2020-03-10T00:02:43.289Z DEBUG modem << \x0A
    2020-03-10T00:02:43.293Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.296Z DEBUG modem >> AT+CGMM\x0D\x0A
    2020-03-10T00:02:43.303Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2020-03-10T00:02:43.304Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.308Z DEBUG modem >> AT+CGMR\x0D\x0A
    2020-03-10T00:02:43.313Z DEBUG modem << mfw_nrf9160_1.1.1\x0D\x0A
    2020-03-10T00:02:43.315Z DEBUG modem << OK\x0D
    2020-03-10T00:02:43.316Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.1.1] SerNr: 352656100159477
    2020-03-10T00:02:43.319Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2020-03-10T00:02:43.323Z DEBUG modem << +CEMODE: 2\x0D
    2020-03-10T00:02:43.328Z DEBUG modem << \x0A
    2020-03-10T00:02:43.330Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.338Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2020-03-10T00:02:43.348Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)\x0D\x0A
    2020-03-10T00:02:43.349Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.355Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2020-03-10T00:02:43.360Z DEBUG modem << +CMEE: 1\x0D
    2020-03-10T00:02:43.361Z DEBUG modem << \x0A
    2020-03-10T00:02:43.362Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.365Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2020-03-10T00:02:43.370Z DEBUG modem << +CNEC: 24\x0D\x0A
    2020-03-10T00:02:43.372Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.376Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2020-03-10T00:02:43.385Z DEBUG modem << +CGEREP: 1,0\x0D\x0A
    2020-03-10T00:02:43.387Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.391Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2020-03-10T00:02:43.396Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.398Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2020-03-10T00:02:43.403Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.406Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2020-03-10T00:02:43.413Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",7\x0D\x0A
    2020-03-10T00:02:43.416Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.425Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2020-03-10T00:02:43.429Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.432Z DEBUG modem >> AT+CESQ\x0D\x0A
    2020-03-10T00:02:43.439Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2020-03-10T00:02:43.440Z DEBUG modem << OK\x0D\x0A
    2020-03-10T00:02:43.449Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2020-03-10T00:02:43.454Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:43.456Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2020-03-10T00:02:43.461Z DEBUG modem << %XSIM: 0\x0D\x0A
    2020-03-10T00:02:43.462Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:02:53.631Z DEBUG modem >> AT%XSYSTEMMODE=0,0,1,0\x0D\x0A
    2020-03-10T00:02:53.636Z DEBUG modem << +CME: 518\x0D\x0A\x00
    2020-03-10T00:03:07.842Z INFO Modem port is closed
    2020-03-10T00:03:07.851Z INFO Modem port is opened
    2020-03-10T00:03:07.853Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-03-10T00:03:18.089Z INFO Modem port is closed
    2020-03-10T00:03:18.095Z INFO Modem port is opened
    2020-03-10T00:03:18.098Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-03-10T00:03:18.110Z DEBUG modem << +CFUN: 0\x0D\x0A
    2020-03-10T00:03:18.116Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:03:19.886Z DEBUG modem << *** Booting Zephyr OS version 2.1.0  ***\x0D\x0A
    2020-03-10T00:03:19.891Z DEBUG modem << Flash region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2020-03-10T00:03:19.894Z DEBUG modem << 00 0x00000 0x08000 \x09Secure\x09\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.898Z DEBUG modem << 01 0x08000 0x10000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.900Z DEBUG modem << 02 0x10000 0x18000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.902Z DEBUG modem << 03 0x18000 0x20000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.905Z DEBUG modem << 04 0x20000 0x28000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.908Z DEBUG modem << 05 0x28000 0x30000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.911Z DEBUG modem << 06 0x30000 0x38000 \x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:19.918Z DEBUG modem << 07 0x38000 0x40000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.920Z DEBUG modem << 08 0x40000 0x48000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.922Z DEBUG modem << 09 0x48000 0x50000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.925Z DEBUG modem << 10 0x50000 0x58000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.928Z DEBUG modem << 11 0x58000 0x60000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.931Z DEBUG modem << 12 0x60000 0x68000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.934Z DEBUG modem << 13 0x68000 0x70000 \x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:19.937Z DEBUG modem << 14 0x70000 0x78000 \x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:19.940Z DEBUG modem << 15 0x78000 0x80000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.943Z DEBUG modem << 16 0x80000 0x88000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.952Z DEBUG modem << 17 0x88000 0x90000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.953Z DEBUG modem << 18 0x90000 0x98000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.954Z DEBUG modem << 19 0x98000 0xa0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.956Z DEBUG modem << 20 0xa0000 0xa8000 \x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:19.960Z DEBUG modem << 21 0xa8000 0xb0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.963Z DEBUG modem << 22 0xb0000 0xb8000 \x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:19.966Z DEBUG modem << 23 0xb8000 0xc0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.969Z DEBUG modem << 24 0xc0000 0xc8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.973Z DEBUG modem << 25 0xc8000 0xd0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.976Z DEBUG modem << 26 0xd0000 0xd8000 \x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:19.984Z DEBUG modem << 27 0xd8000 0xe0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.986Z DEBUG modem << 28 0xe0000 0xe8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.987Z DEBUG modem << 29 0xe8000 0xf0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.989Z DEBUG modem << 30 0xf0000 0xf8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.992Z DEBUG modem << 31 0xf8000 0x100000 \x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:19.998Z DEBUG modem << Non-secure callable region 0 placed in flash region 0 with size 32.\x0D\x0A
    2020-03-10T00:03:20.168Z DEBUG modem << SRAM region\x09\x09Domain\x09\x09Permissions\x0D
    2020-03-10T00:03:20.173Z DEBUG modem << 00 0x00000 0x02000\x09Secure\x09\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.175Z DEBUG modem << 01 0x02000 0x04000\x09Secure\x09\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.177Z DEBUG modem << 02 0x04000 0x06000\x09Secure\x09\x09rwxl\x0D
    2020-03-10T00:03:20.184Z DEBUG modem << 03 0x06000 0x08000\x09Secure\x09\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.185Z DEBUG modem << 04 0x08000 0x0a000\x09Secure\x09\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.187Z DEBUG modem << 05 0x0a000 0x0c000\x09Secure\x09\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.189Z DEBUG modem << 06 0x0c000 0x0e000\x09Secure\x09\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.192Z DEBUG modem << 07 0x0e000 0x10000\x09Secure\x09\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.195Z DEBUG modem << 08 0x10000 0x12000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.198Z DEBUG modem << 09 0x12000 0x14000\x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:20.201Z DEBUG modem << 10 0x14000 0x16000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.204Z DEBUG modem << 11 0x16000 0x18000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.207Z DEBUG modem << 12 0x18000 0x1a000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.210Z DEBUG modem << 13 0x1a000 0x1c000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.213Z DEBUG modem << 14 0x1c000 0x1e000\x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:20.221Z DEBUG modem << 15 0x1e000 0x20000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.222Z DEBUG modem << 16 0x20000 0x22000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.223Z DEBUG modem << 17 0x22000 0x24000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.226Z DEBUG modem << 18 0x24000 0x26000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.229Z DEBUG modem << 19 0x26000 0x28000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.232Z DEBUG modem << 20 0x28000 0x2a000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.236Z DEBUG modem << 21 0x2a000 0x2c000\x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:20.239Z DEBUG modem << 22 0x2c000 0x2e000\x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:20.242Z DEBUG modem << 23 0x2e000 0x30000\x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:20.245Z DEBUG modem << 24 0x30000 0x32000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.253Z DEBUG modem << 25 0x32000 0x34000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.254Z DEBUG modem << 26 0x34000 0x36000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.257Z DEBUG modem << 27 0x36000 0x38000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.258Z DEBUG modem << 28 0x38000 0x3a000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.261Z DEBUG modem << 29 0x3a000 0x3c000\x09Non-Secure\x09rwxl\x0D\x0A
    2020-03-10T00:03:20.264Z DEBUG modem << 30 0x3c000 0x3e000\x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:20.267Z DEBUG modem << 31 0x3e000 0x40000\x09Non-Secure\x09rwxl\x0D
    2020-03-10T00:03:20.270Z DEBUG modem << Peripheral\x09\x09Domain\x09\x09Status\x0D\x0A
    2020-03-10T00:03:20.273Z DEBUG modem << 00 NRF_P0               Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.276Z DEBUG modem << 01 NRF_CLOCK            Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.280Z DEBUG modem << 02 NRF_RTC0             Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.288Z DEBUG modem << 03 NRF_RTC1             Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.289Z DEBUG modem << 04 NRF_NVMC             Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.290Z DEBUG modem << 05 NRF_UARTE1           Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.293Z DEBUG modem << 06 NRF_UARTE2           Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.297Z DEBUG modem << 07 NRF_TWIM2            Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.300Z DEBUG modem << 08 NRF_SPIM3            Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.304Z DEBUG modem << 09 NRF_TIMER0           Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.307Z DEBUG modem << 10 NRF_TIMER1           Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.310Z DEBUG modem << 11 NRF_TIMER2           Non-Secure\x09OK\x0D
    2020-03-10T00:03:20.319Z DEBUG modem << 12 NRF_SAADC            Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.321Z DEBUG modem << 13 NRF_PWM0             Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.322Z DEBUG modem << 14 NRF_PWM1             Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.324Z DEBUG modem << 15 NRF_PWM2             Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.327Z DEBUG modem << 16 NRF_PWM3             Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.331Z DEBUG modem << 17 NRF_WDT              Secure\x09\x09SKIP\x0D
    2020-03-10T00:03:20.334Z DEBUG modem << 18 NRF_IPC              Non-Secure\x09OK\x0D
    2020-03-10T00:03:20.338Z DEBUG modem << 19 NRF_VMC              Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.341Z DEBUG modem << 20 NRF_FPU              Non-Secure\x09OK\x0D
    2020-03-10T00:03:20.344Z DEBUG modem << 21 NRF_EGU1             Non-Secure\x09OK\x0D
    2020-03-10T00:03:20.353Z DEBUG modem << 22 NRF_EGU2             Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.355Z DEBUG modem << 23 NRF_DPPIC            Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.357Z DEBUG modem << 24 NRF_GPIOTE1          Non-Secure\x09OK\x0D\x0A
    2020-03-10T00:03:20.358Z DEBUG modem << 25 NRF_REGULATORS       Non-Secure\x09OK\x0D
    2020-03-10T00:03:20.360Z DEBUG modem << SPM: NS image at 0xc000\x0D
    2020-03-10T00:03:20.362Z DEBUG modem << SPM: NS MSP at 0x20028030\x0D
    2020-03-10T00:03:20.365Z DEBUG modem << SPM: NS reset vector at 0xf0b9\x0D\x0A
    2020-03-10T00:03:20.369Z DEBUG modem << SPM: prepare to jump to Non-Secure image.\x0D
    2020-03-10T00:03:20.564Z DEBUG modem << *** Booting Zephyr OS version 2.1.0  ***\x0D\x0A
    2020-03-10T00:03:20.573Z DEBUG modem << Ready\x0D\x0A
    2020-03-10T00:03:21.569Z DEBUG modem << [00:00:00.193,634] \x1B[0m<inf> app: Serial LTE Modem\x1B[0m\x0D
    2020-03-10T00:03:27.206Z DEBUG modem >> AT%XSYSTEMMODE=0,0,1,0\x0D\x0A
    2020-03-10T00:03:27.224Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:03:35.656Z DEBUG modem >> AT%XMAGPIO=1,0,0,1,1,1574,1577\x0D\x0A
    2020-03-10T00:03:35.670Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:03:44.822Z DEBUG modem >> AT%XCOEX0=1,1,1570,1580\x0D\x0A
    2020-03-10T00:03:44.836Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:03:53.442Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2020-03-10T00:03:53.456Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:04:01.655Z DEBUG modem >> AT#XGPSRUN=1,3\x0D\x0A
    2020-03-10T00:04:01.672Z DEBUG modem << #XGPSRUN: 1,3\x0D\x0A
    2020-03-10T00:04:01.673Z DEBUG modem << OK\x0D
    2020-03-10T00:04:09.167Z DEBUG modem >> AT#XGPSRUN?\x0D\x0A
    2020-03-10T00:04:09.173Z DEBUG modem << #XGPSRUN: 1,3\x0D\x0A
    2020-03-10T00:04:09.174Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.197Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-03-10T00:07:24.202Z DEBUG modem << +CFUN: 1\x0D\x0A
    2020-03-10T00:07:24.205Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.208Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2020-03-10T00:07:24.213Z DEBUG modem << +CGSN: "352656100159477"\x0D\x0A
    2020-03-10T00:07:24.214Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.217Z DEBUG modem >> AT+CGMI\x0D\x0A
    2020-03-10T00:07:24.221Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2020-03-10T00:07:24.222Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.230Z DEBUG modem >> AT+CGMM\x0D\x0A
    2020-03-10T00:07:24.235Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2020-03-10T00:07:24.236Z DEBUG modem << OK\x0D\x0A
    2020-03-10T00:07:24.239Z DEBUG modem >> AT+CGMR\x0D\x0A
    2020-03-10T00:07:24.243Z DEBUG modem << mfw_nrf9160_1.1.1\x0D\x0A
    2020-03-10T00:07:24.245Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.247Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.1.1] SerNr: 352656100159477
    2020-03-10T00:07:24.254Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2020-03-10T00:07:24.258Z DEBUG modem << +CEMODE: 2\x0D\x0A
    2020-03-10T00:07:24.259Z DEBUG modem << OK\x0D\x0A
    2020-03-10T00:07:24.267Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2020-03-10T00:07:24.276Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)\x0D
    2020-03-10T00:07:24.277Z DEBUG modem << \x0A
    2020-03-10T00:07:24.278Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.282Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2020-03-10T00:07:24.290Z DEBUG modem << +CMEE: 0\x0D\x0A
    2020-03-10T00:07:24.291Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.299Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2020-03-10T00:07:24.304Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.309Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2020-03-10T00:07:24.312Z DEBUG modem << +CNEC: 0\x0D\x0A
    2020-03-10T00:07:24.313Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.320Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2020-03-10T00:07:24.323Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.330Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2020-03-10T00:07:24.339Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2020-03-10T00:07:24.339Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.342Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2020-03-10T00:07:24.345Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.348Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2020-03-10T00:07:24.351Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.353Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2020-03-10T00:07:24.356Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.366Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2020-03-10T00:07:24.370Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.373Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2020-03-10T00:07:24.376Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.379Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2020-03-10T00:07:24.387Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",7\x0D\x0A
    2020-03-10T00:07:24.387Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.398Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2020-03-10T00:07:24.402Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.406Z DEBUG modem >> AT+CESQ\x0D\x0A
    2020-03-10T00:07:24.411Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2020-03-10T00:07:24.412Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.416Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2020-03-10T00:07:24.421Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:24.423Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2020-03-10T00:07:24.432Z DEBUG modem << %XSIM: 0\x0D\x0A
    2020-03-10T00:07:24.433Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:29.998Z DEBUG modem >> AT#XGPSRUN?\x0D\x0A
    2020-03-10T00:07:30.006Z DEBUG modem << #XGPSRUN: 1,3\x0D\x0A
    2020-03-10T00:07:30.007Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:38.149Z DEBUG modem >> AT#XGPSRUN=1,3\x0D\x0A
    2020-03-10T00:07:38.156Z DEBUG modem << OK\x0D\x0A\x00
    2020-03-10T00:07:39.157Z DEBUG modem << [00:04:17.790,466] \x1B[1;33m<wrn> gps: GPS is running\x1B[0m\x0D
    2020-03-10T00:08:30.700Z DEBUG modem << #XGPSS: tracking 1 using 1 unhealthy 0\x0D\x0A
    2020-03-10T00:08:34.700Z DEBUG modem << #XGPSS: tracking 0 using 0 unhealthy 0\x0D\x0A
    Thanks
