NFC can't start up with SoftDevice S140 using SDK 15.3
Hi All,
I have a problem when enabling the NFC tag t2t with the soft device S140 with 52840.
I can run the NFC example project 'nRF5_SDK_15.3.0_59ac345\examples\nfc\record_urlrecord_url' correctly on my hardware, but when porting the demo code to my project, the NFC tag cannot be start up. By reviewing the posts on the forum, I guess it should be the problem of the soft device.
I have read the post here:
https://devzone.nordicsemi.com/f/nordic-q-a/42141/nrf52832---nfc-stops-working-when-softdevice-is-enabled/164732#164732
I had followed the instruction to patch the file "flash_placement.xml", but it not work, perhaps it might be workable only for SDK14.0 ?
My environment is:
NRF52840
SoftDevice 6.1.1,  S140
Keil ARM 5.21
The projects codes has BLE/GPIO/SPI/TWI running smoothly. But when testing the record_url example codes, I disable them all.
Is there anything I missed ? Any help would be appreciated.
Best Regards,
Andy
  • Hi Edvin,
    Finally the root cause was found. In the pca10056.h, there is the button definition:
    #define BUTTON_1 11
    #define BUTTON_2 11 //12
    #define BUTTON_3 24
    #define BUTTON_4 25
    #define BUTTON_PULL NRF_GPIO_PIN_PULLUP
    The BUTTON_2 original port number was 12, in my application board, it's connected to a buzzer, when testing the merged project, it is noisy, so I redirect it to BUTTON_1, let it occupied the same port, I thought is should be OK.....But when running the APP, it's looks the BSP will check the port mapping, if duplicated, issuing an error and stop. I didn't check the LOG viewer, so miss the chance to find the root cause.
    The reason why you are correct is because the ZIP file didn't include the pca10056.h(it's located outside the example directory which I zipped), so you are referring to a correct default mapping pca10056.h, but I still mapping to a bad one.
    Thank you again for your help, I will try to test my product APP to see whether NFC can work or not.
    Best Regards,
    Andy
