Can I implement DFU in nRF51822 chip?
I am working on nRF51822-QF-AAFQ chip using SDK 12.3.0 in IAR embedded workbench.
My question is, can I impliment DFU in nrf51822 chip?
If possible suggest Starting RAM address of application and bootloader.
Please give me suggestion as soon as possible.
Thanks & regards,
Urvisha Andani
  • So does you application do the same when you receive it receives the command to go to the bootloader through the buttonless dfu service?
    Yes,from bootloader i am able to go to the application.
    Have you included ble_dfu.c to your project? If so, did you do any changes to that file?
    Yes, i included ble_dfu.c file in project and i did not change any thing in ble_df.c file.
    Please find attached ble_dfu.c file. and ble_dfu.h,
    1) ble_dfu.c
     * Copyright (c) 2012 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    /* Attention!
    *  To maintain compliance with Nordic Semiconductor ASA�s Bluetooth profile
    *  qualification listings, this section of source code must not be modified.
    #include "ble_dfu.h"
    #include "nrf_log.h"
    #include <string.h>
    #include "ble_hci.h"
    #include "sdk_macros.h"
    #include "ble_srv_common.h"
    #include "nrf_dfu_settings.h"
    #define MAX_CTRL_POINT_RESP_PARAM_LEN 3
    ble_dfu_t * p_m_dfu;
    void flash_callback(fs_evt_t const * const evt, fs_ret_t result)
        if (result == FS_SUCCESS)
            NRF_LOG_INFO("Obtained settings, enter dfu is %d\n", s_dfu_settings.enter_buttonless_dfu);
            (void)sd_ble_gap_disconnect(p_m_dfu->conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            p_m_dfu->is_waiting_for_disconnection = true;
    static void enter_bootloader(ble_dfu_t * p_dfu)
        if (p_dfu->evt_handler != NULL)
            ble_dfu_evt_t evt;
            evt.type = BLE_DFU_EVT_ENTERING_BOOTLOADER;
            p_dfu->evt_handler(p_dfu, &evt);
        s_dfu_settings.enter_buttonless_dfu = true;
        (void)nrf_dfu_settings_write(flash_callback);
        TODO:
         - Save bond data
    /**@brief Function for adding RX characteristic.
     * @param[in] p_nus       Nordic UART Service structure.
     * @param[in] p_nus_init  Information needed to initialize the service.
     * @return NRF_SUCCESS on success, otherwise an error code.
    static uint32_t rx_char_add(ble_dfu_t * p_dfu, const ble_dfu_init_t * p_dfu_init)
        /**@snippet [Adding proprietary characteristic to S110 SoftDevice] */
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        ble_uuid_t          ble_uuid;
        ble_gatts_attr_md_t attr_md;
        memset(&cccd_md, 0, sizeof(cccd_md));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
        cccd_md.vloc = BLE_GATTS_VLOC_STACK;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.notify = 1;
        char_md.char_props.write = 1;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = &cccd_md;
        char_md.p_sccd_md         = NULL;
        ble_uuid.type = p_dfu->uuid_type;
        ble_uuid.uuid = 0x0001;
        memset(&attr_md, 0, sizeof(attr_md));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
        attr_md.vloc    = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth = 0;
        attr_md.wr_auth = 1;
        attr_md.vlen    = 1;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid    = &ble_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = 0;
        attr_char_value.init_offs = 0;
        attr_char_value.max_len   = BLE_L2CAP_MTU_DEF;
        return sd_ble_gatts_characteristic_add(p_dfu->service_handle,
                                               &char_md,
                                               &attr_char_value,
                                               &p_dfu->control_point_char);
    uint32_t ble_dfu_init(ble_dfu_t * p_dfu, const ble_dfu_init_t * p_dfu_init)
        uint32_t      err_code;
        ble_uuid128_t nus_base_uuid = BLE_DFU_BASE_UUID;
        VERIFY_PARAM_NOT_NULL(p_dfu);
        VERIFY_PARAM_NOT_NULL(p_dfu_init);
        p_m_dfu = p_dfu; // TODO: find a nicer solution to this
        // Initialize the service structure.
        p_dfu->conn_handle             = BLE_CONN_HANDLE_INVALID;
        p_dfu->evt_handler             = p_dfu_init->evt_handler;
        p_dfu->is_waiting_for_disconnection = false;
        p_dfu->is_ctrlpt_notification_enabled = false;
        /**@snippet [Adding proprietary Service to S110 SoftDevice] */
        // Add a custom base UUID.
        err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_dfu->uuid_type);
        VERIFY_SUCCESS(err_code);
        ble_uuid.uuid = BLE_UUID_DFU_SERVICE;
        // Add the service.
        err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                            &ble_uuid,
                                            &p_dfu->service_handle);
        // Add the RX Characteristic.
        err_code = rx_char_add(p_dfu, p_dfu_init);
        err_code = nrf_dfu_flash_init(true);
        nrf_dfu_settings_init();
        return NRF_SUCCESS;
    static void resp_send(ble_dfu_t * p_dfu, ble_dfu_buttonless_op_code_t op_code, ble_dfu_rsp_code_t rsp_code)
        // Send notification
        uint16_t               hvx_len;
        uint8_t                hvx_data[MAX_CTRL_POINT_RESP_PARAM_LEN];
        ble_gatts_hvx_params_t hvx_params;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_len = 3;
        hvx_data[0] = DFU_OP_RESPONSE_CODE;
        hvx_data[1] = (uint8_t)op_code;
        hvx_data[2] = (uint8_t)rsp_code;
        hvx_params.handle   = p_dfu->control_point_char.value_handle;
        hvx_params.type     = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset   = 0;
        hvx_params.p_len    = &hvx_len;
        hvx_params.p_data   = hvx_data;
        (void)sd_ble_gatts_hvx(p_dfu->conn_handle, &hvx_params);
    /**@brief Handle write events to the Location and Navigation Service Control Point characteristic.
     * @param[in]   p_dfu         DFU Service structure.
     * @param[in]   p_evt_write   Write event received from the BLE stack.
    static void on_ctrlpt_write(ble_dfu_t * p_dfu, ble_gatts_evt_write_t const * p_evt_write)
        uint32_t      err_code;
        ble_dfu_rsp_code_t rsp_code = DFU_RSP_OPERATION_FAILED;
        ble_gatts_rw_authorize_reply_params_t write_authorize_reply;
        memset(&write_authorize_reply, 0, sizeof(write_authorize_reply));
        write_authorize_reply.type   = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
        if (p_dfu->is_ctrlpt_notification_enabled)
            write_authorize_reply.params.write.update      = 1;
            write_authorize_reply.params.write.gatt_status = BLE_GATT_STATUS_SUCCESS;
            write_authorize_reply.params.write.gatt_status = DFU_RSP_CCCD_CONFIG_IMPROPER;
        // reply to the write authorization
        do {
            err_code = sd_ble_gatts_rw_authorize_reply(p_dfu->conn_handle, &write_authorize_reply);
        } while (err_code == NRF_ERROR_BUSY);
        if (write_authorize_reply.params.write.gatt_status != BLE_GATT_STATUS_SUCCESS)
            return;
        // Start executing the control point write action
        switch (p_evt_write->data[0])
            case BLE_DFU_ENTER_BOOTLOADER:
                rsp_code = DFU_RSP_SUCCESS;
             // Unrecognized Op Code
                rsp_code = DFU_RSP_OP_CODE_NOT_SUPPORTED;
        resp_send(p_dfu, (ble_dfu_buttonless_op_code_t)p_evt_write->data[0], rsp_code);
        if (rsp_code == BLE_DFU_ENTER_BOOTLOADER
            && p_evt_write->data[0] == BLE_DFU_ENTER_BOOTLOADER)
            enter_bootloader(p_dfu);
    /**@brief Write authorization request event handler.
     * @details The write authorization request event handler is called when writing to the control point.
     * @param[in]   p_dfu     DFU structure.
     * @param[in]   p_ble_evt Event received from the BLE stack.
    static void on_rw_authorize_req(ble_dfu_t * p_dfu, ble_evt_t const * p_ble_evt)
        if (p_ble_evt->evt.gatts_evt.conn_handle != p_dfu->conn_handle)
            return;
        const ble_gatts_evt_rw_authorize_request_t * p_auth_req =
            &p_ble_evt->evt.gatts_evt.params.authorize_request;
        if (
            (p_auth_req->type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
            (p_auth_req->request.write.handle == p_dfu->control_point_char.value_handle)
            (p_auth_req->request.write.op != BLE_GATTS_OP_PREP_WRITE_REQ)
            (p_auth_req->request.write.op != BLE_GATTS_OP_EXEC_WRITE_REQ_NOW)
            (p_auth_req->request.write.op != BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL)
            on_ctrlpt_write(p_dfu, &p_auth_req->request.write);
    /**@brief Connect event handler.
    static void on_connect(ble_dfu_t * p_dfu, ble_evt_t const * p_ble_evt)
        p_dfu->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    /**@brief Disconnect event handler.
    static void on_disconnect(ble_dfu_t * p_dfu, ble_evt_t const * p_ble_evt)
        if (p_dfu->conn_handle != p_ble_evt->evt.gatts_evt.conn_handle)
            return;
        if (p_dfu->is_waiting_for_disconnection)
            NVIC_SystemReset();
    /**@brief Write event handler.
     * @param[in]   p_ble_evt Event received from the BLE stack.rtt
    static void on_write(ble_dfu_t * p_dfu, ble_evt_t const * p_ble_evt)
        const ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
        if (p_evt_write->handle != p_dfu->control_point_char.cccd_handle)
            return;
        if (p_evt_write->len == BLE_CCCD_VALUE_LEN)
            // CCCD written, update indications state
            p_dfu->is_ctrlpt_notification_enabled = ble_srv_is_notification_enabled(p_evt_write->data);
                ble_dfu_evt_t evt;
                    evt.type = BLE_DFU_EVT_INDICATION_ENABLED;;
                    evt.type = BLE_DFU_EVT_INDICATION_DISABLED;;
    void ble_dfu_on_ble_evt(ble_dfu_t * p_dfu, ble_evt_t * p_ble_evt)
        VERIFY_PARAM_NOT_NULL_VOID(p_dfu);
        VERIFY_PARAM_NOT_NULL_VOID(p_ble_evt);
            case BLE_GAP_EVT_CONNECTED:
                on_connect(p_dfu, p_ble_evt);
                on_disconnect(p_dfu, p_ble_evt);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                on_rw_authorize_req(p_dfu, p_ble_evt);
            case BLE_GATTS_EVT_WRITE:
                on_write(p_dfu, p_ble_evt);
                // no implementation
    2)ble_dfu.h
    ble_dfu.h
    Basically what the buttonless dfu service needs to do is to write some new bootloader settings with the s_dfu_settings.enter_buttonless_dfu = true; and then wait for that to finish, disconnect, and reboot.
    Does your application do that? If you haven't modified the ble_dfu.c it should do that by default.
    Yes it is by default.
    You say that it stays in the bootloader, but doesn't advertise. Have you verified that by scanning for it with another device after it is in DFU mode?
    Yes, I checked in another device but in this also i can not able to scan device.
     That wasn't really my question. Can I see what your main.c in your application look like?
    Did you do any changes to the bootloader project?
