Storing Data to flash memory
Hi
I am using the Nordic NRF52840_dk with SDK 16.
I want to store data to flash memory with Ble and uart enabled. I am using a external UART peripheral to receive data which, I then parse and broadcast via a ble advertisement.
However, I wish to store this data locally along with a start time for the logging. The data is received once per second. I want this stored inside a log which, I can later send to a mobile application.
I therefore, presume I need to use the flashwrite example. And my code is based on RTT.
I have a value stored as a string that comes in from a UART. I need to store this string in flash memory. I am presuming having a String array is a poor way to do it. Given that I have a requirement for logging for a day meaning 86400 entries of data.
What I want to happen is a command to be sent from the android app to start a log. And then a command to stop it.
Also for transmitting the data that is stored on Nordic board(when working). I am not sure if the nordic board is capable of making a bluetooth connection and, if not will making a Gatt connection.
  • Also when I run the write code in a loop i quickly ran out of space.
    It comes up with :No space in flash, delete some records to update the config file.
    How do I delete the entrants? ( All of them)
    I presume it has something to do with fds_record_delete within the fds.c code.
    Thomas
  • I didn't understand what exactly you are trying to tell me, but I guess you are not reading the same as you are writing?
    Thomas said:
    If so is there a statement that says something like wait till fds ready.
     Yes.
    Do you have an event handler for your FDS instance? You probably have a call like this somewhere:
    fds_register(fds_evt_handler);
    If so, fds_evt_handler is your fds callback function.
    What you need to do is to wait after you have changed any of the flash content. You can do so by using a flag:
    //Top of main.c
    volatile bool fds_write_complete_flag = false;
    static void fds_evt_handler(fds_evt_t const * p_evt)
        if (p_evt->result == NRF_SUCCESS)
            NRF_LOG_GREEN("Event: %s received (NRF_SUCCESS)",
                          fds_evt_str[p_evt->id]);
            NRF_LOG_GREEN("Event: %s received (%s)",
                          fds_evt_str[p_evt->id],
                          fds_err_str(p_evt->result));
        switch (p_evt->id)
            case FDS_EVT_INIT:
                    m_fds_initialized = true;
            case FDS_EVT_WRITE:
                    NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->write.record_id);
                    NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->write.file_id);
                    NRF_LOG_INFO("Record key:\t0x%04x", p_evt->write.record_key);
                    fds_write_complete_flag = true;
            } break;
            case FDS_EVT_DEL_RECORD:
                    NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->del.record_id);
                    NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->del.file_id);
                    NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
                m_delete_all.pending = false;
            } break;
        (void) fds_register(fds_evt_handler);
        flash_storage_read_data();
        flash_storage_write_data(00,00,00,00,00,00,00,00,00);//Write the information to the flash storage
        while (fds_write_complete_flag == false)
            // Wait...
    See how I use the FDS_EVT_WRITE event to set the fds_write_complete_flag to true, and how I wait in the main() function for this event to set the flag before I read it.
    BR,
    Edvin
  • Thanks for the Edvin,
    I've written that in now.
    But I cant test it because my flash is full.
    00> <info> app: Initializing fds...
    00> <info> app: Event: FDS_EVT_INIT received (NRF_SUCCESS)
    00> <info> app: Found 4 valid records.
    00> <info> app: Found 100 dirty records (ready to be garbage collected).
    00> <info> app: Writing config file...
    00> <info> app: No space in flash, delete some records to update the config file.
    00> <info> app: Event: FDS_EVT_DEL_FILE received (NRF_SUCCESS)
    Therefore, I need to delete the data. How do I delete all of the data?
    I've tried fds_file_delete(&desc); which does not work.
    Thomas
  • Sorry, I forgot to comment your last post.
    Well. The easiest would probably to erase the entire flash if you end up with a lot of records. The easiest way is to use Nordic Command Line Tools, and the command "nrfjprog -e". This will delete everything on the chip.
    However, You can see from your log that you have 100 dirty records, and only 4 valid records. This means that you can run a garbage collection.
    Whenever you either update a record or delete a record, it is marked for deletion. This is what we call a dirty record. The reason it isn't deleted and freeing up the space immediately is because of the nature of the flash. You need to erase large chunks at once,  and you can only write one time to a specific location once between deleting it again (in fact, you can only write 1's to 0's in a flash, before erasing it, which will reset it to 1's. This is why an empty flash is always 0xFF's).
    So, when either fds_record_write or fds_record_update returns NRF_ERROR_NO_MEM, you need to run a garbage collection by calling fds_gc(). This is a complex call, moving the records around to free space (one flash page is always reserved for this in FDS), and deleting the old pages, so that it has room for new records. Remember to wait for the callback for this call before you try to read or write something else.
    The event that you should add to your fds_event handler is called FDS_EVT_GC. Check that it returned with p_evt->result == NRF_SUCCESS before setting a flag saying it is ok to continue.
    Also, don't fall for the temptation of running fds_gc() on every startup. This will beat up the flash. The flash on the nRFs are guaranteeing 10000 flash erase/write cycles. If you run fds_gc() on every startup, this will be limited to 10000 resets.
    The flash will not stop working after 10 001 cycles, but this is what we can say for sure that will work.
    It is not unusual that it will work for 40-50 000 cycles, or even 100 000 cycles, but still, there is no need to beat up the flash by running an fds_gc() before it is necessary.
  • Ok thanks I won't call fds_gs too often,.
    I still have the issue of my code not reading from the correct location.
    I have setup two data configurations. One is the dummy it is unchanged.
    The other is custom see below:
    /* Sensor configuration data. */
    static configuration_t_sensor m_sensor_cfg =
        .config1_on  = false,
        .config2_on  = true,
        .boot_count  = 0x0,
        .device_name = "sensor",
        .count_id    = 0,
        .t1_data     = 0,
        .t2_data     = 0,
        .t3_data     = 0,
        .p1_data     = 0,
        .p2_data     = 0,
    /* A record containing dummy configuration data. */
    static fds_record_t const m_sensor_record =
        .file_id           = CONFIG_FILE,
        .key               = CONFIG_REC_KEY,
        .data.p_data       = &m_sensor_cfg,
        /* The length of a record is always expressed in 4-byte units (words). */
        .data.length_words = (sizeof(m_sensor_cfg) + 3) / sizeof(uint32_t),
    When I print my data to the RTT view it always reads the dummy data.
     NRF_LOG_INFO("Reading data %s.", m_sensor_cfg.device_name);
    I am going to assume this is a configuration / setup issue.
    Also when running the code and looping a function to add. I fill up the flash very fast.
    0> <info> app: Received string: "1,1191,1,1172
    00> "
    00> <info> app: T1 is:"1191"
    00> <info> app: T2 is:"1172"
    00> <info> app: Reading data dummy.
    00> <info> app: Data added successfully
    00> <info> app: Event: FDS_EVT_WRITE received (NRF_SUCCESS)
    00> <info> app: Record ID:  0x0087
    00> <info> app: File ID:  0x8010
    00> <info> app: Record key:  0x7010
    00> <info> app: Received string: "1,1191,1,1172
    00> "
    00> <info> app: Record ID:  0x0088
    00> "
    00> "
    Note the t1 and t2 data are coming in from a UART this is the data I wish to store.
