Application service UUID gone after secure OTA DFU
I am using nRF52832 on SES v4.12 with SDK v15.3 and SD v6.1.1 on a custom board.
Background:
I want to perform OTA DFU and with that i have two services enabled (secure dfu buttonless and NUS). I was facing OTA DFU issue in which i was getting CRC does not match error. This has been resolved here - https://devzone.nordicsemi.com/f/nordic-q-a/55653/dfu-crc-does-not-match-error
So, i have been able to perform OTA update.
The package that i created includes BL+SD+APP.
Problem:
Once i perform the update and connect again, i only see one service, which is Secure DFU service and the other which is the main application service ID (NUS) is gone. I looked in the forum and found this -https://devzone.nordicsemi.com/f/nordic-q-a/39982/after-ota-dfu-bootloader-application-gone
But i do not quite fully understand as to what is to be done here. Could you please highlight on what is required for a proper DFU process? From what i understand from the post and infocenter that it is still a single update, so BL+SD+APP merged together should work fine internally.
EDIT:
Zip created has only application hex in it. BL+SD+APP is programmed directly using nrfjprog.
Please let me know if you require more information.
Thanks a lot!
-SK
  • @SK: The issue regarding the MTU request is fixed in SDK v16.0 but not on SDK v15.3 you may want to follow my suggestion in the case.
  • Okay sure, will do. In that case, you say putting in a timer to delay the MTU exchange? When should the timer expire? Could you tell me more on the details, please.
  • The main reason to delay MTU exchange was to wait for the phone to do that. (so that we have larger MTU ATT). I would say give it 1-2 second.
    Regarding the issue of having sd_ble_gatts_service_changed() and sd_ble_gattc_exchange_mtu_request() at the same time, you can check if the error is NRF_ERROR_INVALID_STATE the application can retry after a certain time (let's say 1 second) .
  • Hi
    Sorry, i had to move to some other tasks. I tried to do as you suggested, but i am getting error on the sd_ble_gattc_exchange_mtu_request() --> unknown error code
    Would you know why would that be? I have added timer as below.
        if (p_link->att_mtu_desired > p_link->att_mtu_effective)
            NRF_LOG_DEBUG("Requesting to update ATT MTU to %u bytes on connection 0x%x.",
                          p_link->att_mtu_desired, conn_handle);
            create_mtu_request_timer();
            app_timer_start(mtu_request_delay_timer, APP_TIMER_TICKS(1000), NULL);
    Rest of the code i have moved in the handler:
    static void request_delay_handler(void *p_context)
      ret_code_t err_code;
      nrf_ble_gatt_t * p_gatt = (nrf_ble_gatt_t *)p_context;
      ble_evt_t const * p_ble_evt;
      uint16_t  conn_handle = p_ble_evt->evt.common_evt.conn_handle;
      nrf_ble_gatt_link_t * p_link      = &p_gatt->links[conn_handle];
        err_code = sd_ble_gattc_exchange_mtu_request(conn_handle, p_link->att_mtu_desired);
        if (err_code == NRF_SUCCESS)
            p_link->att_mtu_exchange_requested = true;
        else if (err_code == NRF_ERROR_BUSY)
            p_link->att_mtu_exchange_pending = true;
            NRF_LOG_DEBUG("sd_ble_gattc_exchange_mtu_request()"
                          " on connection 0x%x returned busy, will retry.", conn_handle);
            NRF_LOG_ERROR("sd_ble_gattc_exchange_mtu_request() returned %s.",
                          nrf_strerror_get(err_code));
    Once i connect, i get this error:
    <error> nrf_ble_gatt: sd_ble_gattc_exchange_mtu_request() returned Unknown error code.
  • Okay, got it what i was doing wrong there!
    will continue to check on the DFU procedure now.
