Lifght switch client example with DFU issue
I use 3.10 mesh sd and 2 dk boards.
DFU example works fine, but when I try to implement dfu mode in ls example I can't achieve goal. DFU doesn't work. I follow the instruction of the dfu example, but Istead of the dfu hex file I use hex file from the ls client project with some correction and get no reaction after start of  dfu mode. At the very last I changed main.c in the ls client example from dfu project and result the same. I double checked sdk config and macros placement they are the same.
I have no idea about it ).
  • But then you basically have the same project as the DFU, except that you don't have the same project settings as in the DFU project. Is your plan to add the light switch client afterwards?
    Have you tried to do some debugging? Can you explain what you mean by "DFU doesn't work"?
    Have you tried to do any debugging? Did you receive any of the DFU events?
    BR,
    Edvin
    I did it because  i couldn't adjust light switch example to work in DFU mode and at the very last just had replaced main.c.
    I am debugging via RTT and yes there are no events.
  • Are you using nrfutil with this device directly, since you have NRF_MESH_SERIAL_ENABLE = 1? If not, can you please try?
    What is the output from your nrfutil command? Can you please try to use the command with more verbose output:
    nrfutil --verbose dfu serial -pkg dfu_test.zip -p <COM port> -b 115200 -fc --mesh
    Please copy all the text from your cmd window after using this command
  • I have tried to do it with mesh 4.0. Result the same - no events.
    E:\Nordic\nrf5SDKforMeshv310src>nrfutil --verbose dfu serial -pkg dtest.zip -p COM3 -b 115200 -fc --mesh
    Upgrading target on COM3 with DFU package E:\Nordic\nrf5SDKforMeshv310src\dtest.zip. Flow control is enabled.
    Flushing com-port...
    Opened com-port
    Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 2468
    Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
    PC -> target: 0502aabbccdd
    target -> PC: 0582aabbccdd
    Got echo response
    Sending DFU init packet
    PC -> target: 1378fdff040fb0d4b7c859000000010002000000
    target -> PC: 16a6045900000001000200000059000000010001000000
    target -> PC: 03847800
    PC -> target: 1478fcff0000b0d4b7c8ffffffff6902000040000c
    target -> PC: 0da2010459000000010002000000
    Sending firmware file
    [------------------------------------] 1% 00:11:50PC -> target: 1978fcff0100b0d4b7c800fd0020456802006d6802006f680200
    PC -> target: 1978fcff0200b0d4b7c871680200736802007568020000000000
    [------------------------------------] 2% 00:11:41PC -> target: 1978fcff0300b0d4b7c800000000000000000000000077680200
    PC -> target: 1978fcff0400b0d4b7c879680200000000007b6802007d680200
    [#-----------------------------------] 3% 00:07:45PC -> target: 1978fcff0500b0d4b7c87f6802007f6802007f6802007f680200
    PC -> target: 1978fcff0600b0d4b7c87f6802007f6802007f6802007f680200
    [#-----------------------------------] 4% 00:06:11PC -> target: 1978fcff0700b0d4b7c87f6802007f6802007f6802007f680200
    PC -> target: 1978fcff0800b0d4b7c87f6802007f6802007f6802007f680200
    [##----------------------------------] 6% 00:05:16PC -> target: 1978fcff0900b0d4b7c87f6802007f6802007f6802007f680200
    PC -> target: 1978fcff0a00b0d4b7c87f6802007f6802007f6802007f680200
    [##----------------------------------] 7% 00:04:39PC -> target: 1978fcff0b00b0d4b7c87f6802007f6802007f6802007f680200
    PC -> target: 1978fcff0c00b0d4b7c87f6802007f6802000000000000000000
    [###---------------------------------] 8% 00:04:12PC -> target: 1978fcff0d00b0d4b7c87f6802007f6802007f6802007f680200
    PC -> target: 1978fcff0e00b0d4b7c87f6802007f6802007f68020000000000
    [###---------------------------------] 9% 00:03:51PC -> target: 1978fcff0f00b0d4b7c800000000000000000000000000000000
  • and nrf_mesh_dfu_enable() return NRF_ERROR_NOT_SUPPORTED
