Good day!
Tell me how you can configure access to UART with DMA in the example freertos_coap_server for receiving and transmitting arbitrary messages. Also, please clarify what maximum write read buffer is available in DMA for UART?
Thank's
Good day!
Thank's
Hi Alexander,
Which issue do you have ?
You would need to add all the drivers and libraries as showed in the uart example into the freertos example. In addition please add the configuration to sdk_config.h as showed in the example.
One notice is that OpenThread is compiled with UART0 reserved for CLI (command line interface). If you are using nRF52840 you can use the UART1 instead. If you want to use UART0 for your application, you would need to recompile OpenThread.
Need to add all the definitions from this file?
You are right, you need to add the configuration definition from the sdk_config.h
You can re-build the open thread library here: https://openthread.io/guides/build
But it would take some time to install the toolchain and build environment. If you just want to test UART, I would suggest to use UART1
