nrf8001 setup format
I'm using Maple and custom nrf8001 board... I have the following problems...
I'm usign the library from this topic: forums.leaflabs.com/topic.php
But as you can guest it doesn't work... First after reset my device is in Setup mode, so I don't need RadioReset command.
After that when i'm sending setup data, I get 0x89 (ACI_STATUS_ERROR_UNSUPPORTED_SETUP_FOR MAT)
Any idea where I can be wrong???
    The XML shows that you are using a Setup format for a D version of the chip and this will not work on a C version of the chip. Change the Setup format for the XML in nRF8001 -> Configuration -> Device in the top of the page.
    You can find the version of the chip on the top of the chip
    nRF D 8001 YYWWLL
    The letter marked in bold marking is the version/build code of the chip
    Thanks
