SDK16.0
nRF52DK
HTS example
I got this error msg in the RTT log while running the example:
peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Encryption, error: 4102
What shall I do to fix it?
SDK16.0
nRF52DK
HTS example
I don't know what numbers the events are coming from, but what I am interrested in is the log messages coming from the peer_manager_handler.
Now. Did you try to erase the bonding information both on the nRF and on the connected device? Please let me know if you are not sure how to do that. Also, please let me know what you are trying to connect to.
How to erase the bonding information?
On the nRF, the easiest is to run the Nordic Command Line Tools command:
"nrfutil --eraseall"
and the reprogram your application. Let me know if you are having trouble doing this. If so, what IDE do you use?
What is your other device? If it is a phone, you must enter your bluetooth settings and select something like "Forget Device". If it is another nRF52810 you are trying to connect to, then you should erase that chip and reprogram it like the other one.
Edvin
