Hello All,
I am working on the nrf52810 ,
Using sdk 15.3 .
I am working on the DFU feature on my application.
I have successfully integrated the my application with the buttonless DFU and its working properly.
Now I have added the fds feature to that but its not woking.
if i use fds in my application without buttonless DFU its working properly, but if i integrate fds with dfu its not working.
I have followed some post but not getting main cause.
If anyone know this issue how to solve please let me know .
What modification is required ?
Please check my file below.
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @example examples/ble_peripheral/ble_app_buttonless_dfu
* @brief Secure DFU Buttonless Service Application main file.
* This file contains the source code for a sample application using the proprietary
* Secure DFU Buttonless Service. This is a template application that can be modified
* to your needs. To extend the functionality of this application, please find
* locations where the comment "// YOUR_JOB:" is present and read the comments.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nrf_dfu_ble_svci_bond_sharing.h"
#include "nrf_svci_async_function.h"
#include "nrf_svci_async_handler.h"
#include "ble_cus.h"
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "ble_conn_state.h"
#include "ble_dfu.h"
#include "ble_tps.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "fds.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#include "nrf_power.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_bootloader_info.h"
#include "boards.h"
#include "app_button.h"
#include "bsp.h"
#include "ble_gap.h"
/*** Used for testing FDS ***/
static volatile uint8_t write_flag_fds_test = 0;
#define FILE_ID_FDS_TEST 0x1111
#define REC_KEY_FDS_TEST 0x2222
#define DEVICE_NAME "NRF_02" //Nordic_Buttonless /**< Name of device. Will be included in the advertising data. */
#define DEVICE_NAME_P "Nrf02" /**< Name of device. Will be included in the advertising data. */
//#define DEVICE_NAME "FIND02" //Nordic_Buttonless /**< Name of device. Will be included in the advertising data. */
//#define DEVICE_NAME_P "FinD02" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 80 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define ADVERTISING_LED BSP_BOARD_LED_3 /**< Is on when device is advertising. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define TX_POWER_LEVEL (4) /**< TX Power Level value. This will be set both in the TX Power service, in the advertising data, and also used to set the radio transmit power. */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50)
#define Single_click_INTERVAL APP_TIMER_TICKS(1000)
#define NOTIFICATION_INTERVAL APP_TIMER_TICKS(1000)
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_TPS_DEF(m_tps);
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_CUS_DEF(m_cus);
//NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(long_button_action);
APP_TIMER_DEF(single_button_action);
APP_TIMER_DEF(Double_button_action);
APP_TIMER_DEF(m_notification_timer_id);
int custom_entry_flag;
static uint8_t m_custom_value = 0;
static uint8_t DEVICE_NAME_MED[7] = {"FIND00"};
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
//static void advertising_start(bool erase_bonds); /**< Forward declaration of advertising start function */
static uint32_t cnt = 0, temp = 0, advertising_flag = 0;
static uint8_t press_cnt = 0, temp_click = 0;
static uint8_t temp_name_id_lsb;
extern int temp_name_id;
extern int TX_power_variable;
extern int custom_entry_flag;
uint8_t m_deadbeef[] = {54};//,12};//{8,45,69,44,22,45,12,32};
uint8_t *temp_data;
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded scan data. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = m_enc_scan_response_data,
ble_advdata_t advdata;
ble_gap_adv_params_t adv_params;
/*--------------all function decleration --------*/
static void setDeviceName(uint8_t status);
static void tx_power_set(void);
static void bsp_event_handler(bsp_event_t event);
//static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context);
/*---- flash read/write/delete function ----*/
static ret_code_t fds_test_find_and_delete (void);
static ret_code_t fds_test_init (void);
static ret_code_t fds_read(void);
static ret_code_t fds_test_write(void);
static void my_fds_evt_handler(fds_evt_t const * const p_fds_evt);
/*------- FOR THE UPDATE ADVERTISING VARIABLE FOR SWITCH CASE ------ */
enum
STATUS_LOW,
STATUS_MED,
STATUS_HIGH,
STATUS_ERR
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_TX_POWER_SERVICE, BLE_UUID_TYPE_BLE}
/**@brief Function for initializing the TX Power Service.
static void tps_init(void)
ret_code_t err_code;
ble_tps_init_t tps_init_obj;
memset(&tps_init_obj, 0, sizeof(tps_init_obj));
tps_init_obj.initial_tx_power_level = TX_POWER_LEVEL;
tps_init_obj.tpl_rd_sec = SEC_JUST_WORKS;
err_code = ble_tps_init(&m_tps, &tps_init_obj);
/**@brief Handler for shutdown preparation.
* @details During shutdown procedures, this function will be called at a 1 second interval
* untill the function returns true. When the function returns true, it means that the
* app is ready to reset to DFU mode.
* @param[in] event Power manager event.
* @retval True if shutdown is allowed by this power manager handler, otherwise false.
static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_DFU:
NRF_LOG_INFO("Power management wants to reset to DFU mode.");
// YOUR_JOB: Get ready to reset into DFU mode
// If you aren't finished with any ongoing tasks, return "false" to
// signal to the system that reset is impossible at this stage.
// Here is an example using a variable to delay resetting the device.
// if (!m_ready_for_reset)
// return false;
// else
// // Device ready to enter
// uint32_t err_code;
// err_code = sd_softdevice_disable();
// APP_ERROR_CHECK(err_code);
// err_code = app_timer_stop_all();
// YOUR_JOB: Implement any of the other events available from the power management module:
// -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
// -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
// -NRF_PWR_MGMT_EVT_PREPARE_RESET
return true;
NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
return true;
//lint -esym(528, m_app_shutdown_handler)
/**@brief Register application shutdown handler with priority 0.
NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
if (state == NRF_SDH_EVT_STATE_DISABLED)
// Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
//Go to system off.
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
/* nrf_sdh state observer. */
NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
.handler = buttonless_dfu_sdh_state_observer,
static void advertising_config_get(ble_adv_modes_config_t * p_config)
memset(p_config, 0, sizeof(ble_adv_modes_config_t));
p_config->ble_adv_fast_enabled = true;
p_config->ble_adv_fast_interval = APP_ADV_INTERVAL;
p_config->ble_adv_fast_timeout = APP_ADV_DURATION;
static void disconnect(uint16_t conn_handle, void * p_context)
UNUSED_PARAMETER(p_context);
ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
if (err_code != NRF_SUCCESS)
NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
// YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
/**@brief Function for handling dfu events from the Buttonless Secure DFU service
* @param[in] event Event from the Buttonless Secure DFU service.
static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
switch (event)
case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
// Prevent device from advertising on disconnect.
ble_adv_modes_config_t config;
advertising_config_get(&config);
config.ble_adv_on_disconnect_disabled = true;
ble_advertising_modes_config_set(&m_advertising, &config);
// Disconnect all other bonded devices that currently are connected.
// This is required to receive a service changed indication
// on bootup after a successful (or aborted) Device Firmware Update.
uint32_t conn_count = ble_conn_state_for_each_connected(disconnect, NULL);
NRF_LOG_INFO("Disconnected %d links.", conn_count);
case BLE_DFU_EVT_BOOTLOADER_ENTER:
// YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
// by delaying reset by reporting false in app_shutdown_handler
NRF_LOG_INFO("Device will enter bootloader mode.");
case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
// YOUR_JOB: Take corrective measures to resolve the issue
// like calling APP_ERROR_CHECK to reset the device.
case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
NRF_LOG_ERROR("Request to send a response to client failed.");
APP_ERROR_CHECK(false);
NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
uint32_t err_code = app_timer_init();
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
// if (advertising_flag == 1) //for normal advert
// advertising_flag = 0;
// err_code = sd_ble_gap_device_name_set(&sec_mode,
// (const uint8_t *)DEVICE_NAME,
// strlen(DEVICE_NAME));
// else if (advertising_flag == 2) //for panic advert
// (const uint8_t *)DEVICE_NAME_P,
// strlen(DEVICE_NAME_P));
/* YOUR_JOB: Use an appearance value matching the application's use case.
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
APP_ERROR_CHECK(err_code); */
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
* YOUR_JOB implement a service handler function depending on the event the service you are using can generate
* @details This function will be called for all YY Service events which are passed to
* the application.
* @param[in] p_yy_service YY Service structure.
* @param[in] p_evt Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t * p_yy_service,
ble_yy_service_evt_t * p_evt)
switch (p_evt->evt_type)
case BLE_YY_NAME_EVT_WRITE:
APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
// No implementation needed.
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void notification_timeout_handler(void * p_context)
// Increment the value of m_custom_value before nortifing it.
m_custom_value++;
err_code = ble_cus_custom_value_update(&m_cus, m_custom_value);
/**@brief Function for handling the Custom Service Service events.
* @details This function will be called for all Custom Service events which are passed to
* the application.
* @param[in] p_cus_service Custom Service structure.
* @param[in] p_evt Event received from the Custom Service.
static void on_cus_evt(ble_cus_t * p_cus_service,
ble_cus_evt_t * p_evt)
switch(p_evt->evt_type)
case BLE_CUS_EVT_NOTIFICATION_ENABLED:
err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
case BLE_CUS_EVT_NOTIFICATION_DISABLED:
// Stop the application timer that is triggering the notifications
err_code = app_timer_stop(m_notification_timer_id);
case BLE_CUS_EVT_CONNECTED:
case BLE_CUS_EVT_DISCONNECTED:
case BLE_CUS_EVT_SERVO_CTR_VALUE_RECEIVED:
static void cus_init(void)
/* YOUR_JOB: Add code to initialize the services used by the application.*/
ble_cus_init_t cus_init;
// Initialize CUS Service init structure to zero.
memset(&cus_init, 0, sizeof(cus_init));
cus_init.evt_handler = on_cus_evt;
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
err_code = ble_cus_init(&m_cus, &cus_init);
uint32_t err_code;
//nrf_ble_qwr_init_t qwr_init = {0};
ble_dfu_buttonless_init_t dfus_init = {0};
// qwr_init.error_handler = nrf_qwr_error_handler;
// err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init);
dfus_init.evt_handler = ble_dfu_evt_handler;
err_code = ble_dfu_buttonless_init(&dfus_init);
tps_init();
cus_init();
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling a Connection Parameters error.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
//Disable SoftDevice. It is required to be able to write to GPREGRET2 register (SoftDevice API blocks it).
//GPREGRET2 register holds the information about skipping CRC check on next boot.
err_code = nrf_sdh_disable_request();
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
//ble_advdata_t advdata;
//ble_advdata_t srdata;
//ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
// advdata.short_name_len = 8;
// advdata.include_appearance = true; // changed to true to false
// advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
// advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
// advdata.uuids_complete.p_uuids = m_adv_uuids;
// memset(&srdata, 0, sizeof(srdata));
// srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
// srdata.uuids_complete.p_uuids = adv_uuids;
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
// err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
//ble_gap_adv_params_t adv_params;
// Set advertising parameters.
memset(&adv_params, 0, sizeof(adv_params));
adv_params.primary_phy = BLE_GAP_PHY_1MBPS;
adv_params.duration = APP_ADV_DURATION;
adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
adv_params.p_peer_addr = NULL;
adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
adv_params.interval = APP_ADV_INTERVAL;
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
/**@brief Function for stopping advertising.
static void advertising_stop(void)
err_code = sd_ble_gap_adv_stop(m_adv_handle);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code = NRF_SUCCESS;
//bsp_board_led_off(ADVERTISING_LED);
// bsp_board_init(BSP_INIT_LEDS);
// bsp_board_led_off(ADVERTISING_LED);
//advertising_flag = 1;
// gap_params_init();
// advertising_init();
// advertising_start(); //start normal advertising
//setDeviceName(STATUS_MED);
if(custom_entry_flag == 1)
NRF_LOG_INFO("temp_name_id = %x\r\n", temp_name_id);
// m_deadbeef[0] = temp_name_id;
//NRF_LOG_INFO("m_deadbeef = %x\r\n", m_deadbeef[0]);
err_code =fds_test_init();
err_code = fds_test_find_and_delete();
err_code =fds_test_write();
//while (write_flag_fds_test==1);
err_code = fds_read();
temp_name_id_lsb = temp_name_id;
temp_name_id = temp_name_id/10;
NRF_LOG_INFO("temp_name_id = %d\r\n", temp_name_id);
temp_name_id_lsb = temp_name_id_lsb%10;
NRF_LOG_INFO("temp_name_id_lsb = %d\r\n", temp_name_id_lsb);
custom_entry_flag = 2;
if(custom_entry_flag != 2) //default advt
case BLE_GAP_EVT_CONNECTED:
// m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
// err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle);
// bsp_board_led_on(ADVERTISING_LED);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init()
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
* @param[in] event Event generated when button is pressed.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BSP_EVENT_DISCONNECT:
break; // BSP_EVENT_DISCONNECT
case BSP_EVENT_WHITELIST_OFF:
break; // BSP_EVENT_KEY_0
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
uint32_t err_code;
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
/*err_code = bsp_btn_ble_init(NULL, &startup_event);
*p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);*/
/**@brief Function for the Power manager.
static void log_init(void)
uint32_t err_code = NRF_LOG_INIT(NULL);
/**@brief Function for initializing the GATT module.
* @details The GATT module handles ATT_MTU and Data Length update procedures automatically.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
uint32_t err_code = nrf_pwr_mgmt_init();
#if USE_BSP == 0
#define PIN_0 0
APP_TIMER_DEF(m_button_action);
#define BUTTON_STATE_POLL_INTERVAL_MS 10UL
#define LONG_PRESS(MS) (uint32_t)(MS)/BUTTON_STATE_POLL_INTERVAL_MS
/**@brief Function for handling events from the button handler module.
void single_click_timeout_handler(void * p_context)
uint32_t err_code;
if(press_cnt == 2)
NRF_LOG_INFO("double Button press");
press_cnt=0;
err_code = sd_ble_gap_adv_stop(m_adv_handle); //stop advertising
// advertising_stop();
advertising_flag = 2;
/********************************----------SORTING ID IN BITS-------------*************************************/
// advertising_start(); //panic normal advertising
press_cnt = 0;
if( temp_click == 0)
temp_click = 1;
NRF_LOG_INFO("single button press");
app_timer_stop(single_button_action);
//tx_power_set();
return;
/**@brief Function for the button handler module.
void button_press_timeout_handler(void * p_context)
uint32_t err_code;
static uint32_t cnt;
if (app_button_is_pushed(0))
cnt++;
if ( cnt >= LONG_PRESS(2000))
cnt = 0;
temp_click = 0;
NRF_LOG_INFO("Long Button press");
err_code = app_timer_start(long_button_action,
APP_TIMER_TICKS(BUTTON_STATE_POLL_INTERVAL_MS),
NULL);
cnt = 0 ;
press_cnt++;
if(press_cnt==1)
err_code = app_timer_start(single_button_action,
Single_click_INTERVAL,
NULL);
return;
/*void button_timeout_handler(void * p_context)
uint32_t err_code;
static uint32_t cnt = 0, flag = 0,temp=0;
if ((app_button_is_pushed(0)))
cnt++;
if ( (cnt >= LONG_PRESS(2000)) && (flag == 1 ))
cnt = 0;
flag = 2;
NRF_LOG_INFO("stop advertising...");
//uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_IDLE); //stop****************
return;
err_code = app_timer_start(m_button_action,
NULL);
else if((flag == 2 && temp == 1) || temp == 0 )
cnt = 0; // reset counter variable
flag = 1;
temp = 1;
NRF_LOG_INFO("Short button press");
NRF_LOG_INFO("advertising.......");
gap_params_init();
advertising_init();
advertising_start(); //start advertising
return;
void button_callback(uint8_t pin_no, uint8_t button_action)
uint32_t err_code;
if ((pin_no == BUTTON_1) && (button_action == APP_BUTTON_PUSH))
NULL);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
uint32_t err_code;
static app_button_cfg_t button_cfg;
button_cfg.pin_no = BUTTON_1;
button_cfg.button_handler = button_callback;
button_cfg.pull_cfg = NRF_GPIO_PIN_PULLUP;
button_cfg.active_state = APP_BUTTON_ACTIVE_LOW;
err_code = app_button_init(&button_cfg, 1, 100);
err_code = app_button_enable();
/*Enable an app timer instance to detect long button press*/
err_code = app_timer_create(&long_button_action, APP_TIMER_MODE_SINGLE_SHOT, button_press_timeout_handler);
err_code = app_timer_create(&single_button_action, APP_TIMER_MODE_SINGLE_SHOT, single_click_timeout_handler);
#endif //USE_BSP
nrf_pwr_mgmt_run();
/**@brief Function for changing the tx power.
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
ble_tps_tx_power_level_set(&m_tps, TX_POWER_LEVEL);
#define DEVICE_NAME_LOW "123"
//uint8_t DEVICE_NAME_MED[7]= {"FIND_00"};//{0x65,'i','n','d','_','1','1'};
#define DEVICE_NAME_HIGH "789"
#define DEVICE_NAME_ERR "987"
if( advertising_flag == 1)
DEVICE_NAME_MED[2]= 0x4E;
// setDeviceName(STATUS_MED);
DEVICE_NAME_MED[2]= 0x6E;
DEVICE_NAME_MED[4]=0x30 + temp_name_id;
DEVICE_NAME_MED[5]=0x30 + temp_name_id_lsb;
// Set the device name
switch(status)
case STATUS_LOW:
sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME_LOW, strlen(DEVICE_NAME_LOW));
bsp_board_led_on(BSP_BOARD_LED_1);
case STATUS_MED:
sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME_MED, 7);
bsp_board_led_on(BSP_BOARD_LED_3);
case STATUS_HIGH:
sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME_HIGH, strlen(DEVICE_NAME_HIGH));
bsp_board_led_on(BSP_BOARD_LED_2);
case STATUS_ERR:
sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME_ERR, strlen(DEVICE_NAME_ERR));
bsp_board_led_on(BSP_BOARD_LED_0);
// Encode the advertising packet and start advertising
/****************************************---------------Flash read write function-------------------******************************************************/
switch (p_fds_evt->id)
case FDS_EVT_INIT:
if (p_fds_evt->result != FDS_SUCCESS)
// Initialization failed.
case FDS_EVT_WRITE:
if (p_fds_evt->result == FDS_SUCCESS)
write_flag_fds_test=1;
//static uint32_t const m_deadbeef[2] = {0xDEADBEEF,0xBAADF00D};
// static uint8_t const m_deadbeef[8] = {0x00,0xA2,0xA3,0xA4,0x22,45,12,32};
fds_record_t record;
fds_record_desc_t record_desc;
// Set up data.
//for (int x = 0; x<8;x++)
//m_deadbeef[0] = array_update[2];
// Set up record.
record.file_id = FILE_ID_FDS_TEST;
record.key = REC_KEY_FDS_TEST;
temp_data = m_deadbeef[0];
record.data.p_data = &temp_data;
//record.data.length_words = sizeof(m_deadbeef)/sizeof(uint32_t);
record.data.length_words = sizeof(m_deadbeef)/sizeof(uint8_t);
record_desc.record_id =1;
ret_code_t ret = fds_record_write(&record_desc, &record);
if (ret != FDS_SUCCESS)
return ret;
NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
return NRF_SUCCESS;
fds_flash_record_t flash_record;
fds_find_token_t ftok ={0};//Important, make sure you zero init the ftok token
//uint32_t *data;
uint8_t *data;
uint32_t err_code;
uint8_t i=0;
NRF_LOG_INFO("Start searching... \r\n");
// Loop until all records with the given key and file ID have been found.
//while (fds_record_find(FILE_ID_FDS_TEST, REC_KEY_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
while (fds_record_find_in_file(FILE_ID_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
err_code = fds_record_open(&record_desc, &flash_record);
if ( err_code != FDS_SUCCESS)
return err_code;
NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
NRF_LOG_INFO("Data = ");
//data = (uint32_t *) flash_record.p_data;
data = (uint8_t *) flash_record.p_data;
for (uint8_t i=0;i<flash_record.p_header->length_words;i++)
NRF_LOG_INFO("%d ",(data[i]));
NRF_LOG_INFO("\r\n");
temp_name_id = data[0];
// data[2]= 45;
// NRF_LOG_INFO("0x%8x ",data[2]);
// NRF_LOG_INFO("0x%8x ",data[3]);
// if(record_desc.record_id == 1)
// for (uint8_t i=0;i<flash_record.p_header->length_words;i++)
// NRF_LOG_INFO("%x",data[i]);
// //NRF_LOG_INFO("0x%8x ",data[2]);
//fds_record_find_in_file()
// Access the record through the flash_record structure.
// Close the record when done.
err_code = fds_record_close(&record_desc);
if (err_code != FDS_SUCCESS)
return err_code;
return NRF_SUCCESS;
fds_find_token_t ftok;
ftok.page=0;
ftok.p_addr=NULL;
// Loop and find records with same ID and rec key and mark them as deleted.
fds_record_delete(&record_desc);
NRF_LOG_INFO("Deleted record ID: %d \r\n",record_desc.record_id);
// call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
ret_code_t ret = fds_gc();
return ret;
return NRF_SUCCESS;
ret_code_t ret = fds_register(my_fds_evt_handler);
return ret;
ret = fds_init();
return ret;
return NRF_SUCCESS;
/**@brief Function for application main entry.
bool erase_bonds;
log_init();
//bsp_board_init(BSP_INIT_LEDS);
timers_init();
// power_management_init();
#if USE_BSP == 0
buttons_init();
#else
// Initialize the async SVCI interface to bootloader before any interrupts are enabled.
err_code = ble_dfu_buttonless_async_svci_init();
ble_stack_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
conn_params_init();
peer_manager_init();
//tx_power_set();
//bsp_board_led_off(BSP_INIT_LEDS);
// advertising_flag = 1;
//// gap_params_init();
//// advertising_init();
//// advertising_start(); //start normal advertising
NRF_LOG_INFO("Buttonless DFU Application started.");
// Enter main loop.
for (;;)
// idle_state_handle();
Waiting for your valuable response.
Rohit
