nrF52832 get wrong WHO_AM_I value with spi
Hey guys (and merry Christmas),
I'm working with a Laird BL652-DVK (nrF 52832 - chip), Nordic SDK v.14.2.0 and SES (Segger Embedded Studio v.4.30). I try to receive data from an accelerometer using spi. At first I configured the uart example because I want to send the data to my pc with uart and Termite v3.4. That's working.
Now I have implented the spi example into the uart example.  I have configured spi and the accelerometer. After that I read the WHO_AM_I register (uint8_t read_data_1), but I get a wrong value. I get the value "11" instead of "33".... My code is below. If I read the "uint8_t read_data[1]" (commented out), I get the value "0x0". I really don't know, what to do. I hope someone can help me.
My code:
 * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup uart_example_main main.c
 * @ingroup uart_example
 * @brief UART Example Application main file.
 * This file contains the source code for a sample application using UART.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <math.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
//spi header
#include <nrf_drv_spi.h>
#include "nrf_gpio.h"
#include "boards.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED     /* When UART is used for communication with the host do not use flow control.*/
//spi variables
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
//uint8_t read_data[1];
//accel input register
uint8_t LIS3DH_CTRL_REG1[] = {0x20, 0x47}; //all axes, normal, 50Hz
uint8_t LIS3DH_CTRL_REG2[] = {0x21, 0x00}; //no highpass filter
uint8_t LIS3DH_CTRL_REG3[] = {0x22, 0x00}; //no interrupts
uint8_t LIS3DH_CTRL_REG4[] = {0x23, 0x88}; //all defaults
uint8_t LIS3DH_CTRL_REG5[] = {0x24, 0x00}; //all defaults
uint8_t LIS3DH_CTRL_REG6[] = {0x25, 0x00}; //all defaults
//accel output register
uint8_t LIS3DH_WHO_AM_I_REG[] = {0x0F};
uint8_t LIS3DH_OUT_X_H[] = {0x29};
uint8_t LIS3DH_OUT_X_L[] = {0x28};
uint8_t LIS3DH_OUT_Y_H[] = {0x2B};
uint8_t LIS3DH_OUT_Y_L[] = {0x2A};
uint8_t LIS3DH_OUT_Z_H[] = {0x2D};
uint8_t LIS3DH_OUT_Z_L[] = {0x2C};
//uart error handle
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
//init lis3dh
void init_lis()
        nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG1, sizeof(LIS3DH_CTRL_REG1), NULL, 0);
        nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG2, sizeof(LIS3DH_CTRL_REG2), NULL, 0);
        nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG3, sizeof(LIS3DH_CTRL_REG3), NULL, 0);
        nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG4, sizeof(LIS3DH_CTRL_REG4), NULL, 0);
        nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG5, sizeof(LIS3DH_CTRL_REG5), NULL, 0);
        nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG6, sizeof(LIS3DH_CTRL_REG6), NULL, 0);
//spi user event handler
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    printf("Transfer completed.");
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
          NRF_UART_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
    bsp_board_leds_init();
    printf("\r\nStart: \r\n");
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;  //SPI master driver instance configuration
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MISO_PIN;
    spi_config.mosi_pin = SPI_MOSI_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    spi_config.frequency = NRF_DRV_SPI_FREQ_2M; // data rate: 2 Mbps
    spi_config.mode     = NRF_DRV_SPI_MODE_3;	// SPI mode: SCK active low, sample on trailing edge of clock.
    nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL); //Function for initializing the SPI master driver instance
    printf("\r\nSPI config done! \r\n");
    init_lis();
    uint8_t read_data_1 = nrf_drv_spi_transfer(&spi, LIS3DH_WHO_AM_I_REG, sizeof(LIS3DH_WHO_AM_I_REG), read_data, sizeof(read_data));
    printf("\r\nWHO_AM_I: %x\n", read_data_1);  //value: 0x11 ??
    printf("\r\nWHO_AM_I: %x\n", read_data[1]);  //value: 0x0 ??
Here I get the value "0x11" instead of "0x33":
And here I get the value "0x0" instead of "0x33":
Thanks in advance,
Christoph
