I tried to run debugger but I got this error. Do someone have an idea please ? It's the same error with aws_fota sample.
Fabien Comte said:What settings / variables I have to change when I move a sample please ?
It depends where your copied directory is located. If it's in the same place as aws_fota (ncs/nrf/samples/nrf9160) then you shouldn't change anything in the CMakeLists.txt file.
Just to be sure, I tried to debug aws_fota sample in SES without any modification in the same directory and it not works like the error reported.
My mistake, I changed theses 2 lines because at first, samples had relative paths instead of ZEPHYR_BASE but it was fixed and now I have the same CMakeLists.txt as the sample.
Hi, to clarify you shouldn't have to change anything but changing the paths to be relative like you suggested is a good idea, because then it doesn't matter where your application is located.
Ok as I said, please test the original aws_fota sample with SES. Without any change, debug is already broken.
