debug terminal does not appear in Segger Embedded Studio
Hello, Nordic.
A while ago, debug terminal do not appear in Segger Embedded Studio, and nothing happens when I click View -> debug terminal in the tab bar.
Currently in use
- SEGGER Embedded Studio V4.30c
- JLINK V6.54c
It doesn't work suddenly while using well. The same thing happens if I try to reinstall or downgrade SES. When I run JLINK-VIEWER, the log is displayed intermittently.
I would like to check inside SES as before rather than seeing it in other viewers via SEGGER_RTT_print/writeString.
Is there a way?
Thanks.
  • Hi Einar Thorsrud.
    I've tried reinstalling, deleting and downgrading both SES and J-LINK. However, none of methods allowed the debug terminal to appear.
    Maybe, my "SEGGER Embedded Studio V4.30c" and "JLINK V6.54c" are incompatible or unstable?
    Let me know each version that has been verified, I will change it.
    Finally, I don't know what you saying that J-Link Viewer opens at the same time as SES.
    I do not recall any issue with RTT due to incompatibilities, but it is possible. Do you use a .zip distribution of SES, or an installed one? If you use an installed one, then you just need to install the latest J-Link package and select that you want to update the J-Link DLL in SES as well. Then you know you have the latest version in SES.
    Regarding the RTT Viewer, my question is if you have that open at the same time as you have SES open? In that case, only one of them will actually be able to display the RTT data (or you sill see some incomplete pieces of data on both) since both will update the pointers in the circular RTT buffer when reading.
    If none of the above seems to help, I wonder if you could test with an unmodified SDK example that uses RTT logging, and see if that works for you. For instance, from \examples\crypto\nrf_crypto\hmac\, since that has RTT logging enabled by default. Does that work if you test the precompiled hex file and test with the RTT Viewer? What if you build yourself and test with RTT Viewer? And what when you try to display the log in SES?
