Hello Nordic Team,
Currently i'm trying to join my custom HID (a joystick) with the ble_app_hrs_rscs_relay example (SDK 16) for a personal project which consist in: a nrf52832 working as slave and another working as “my custom relay”. In the slave device I’m using the ble_app_hrs example code without any modifications. While my second nrf52832 is in central role, the relay scan’s (filter by name and UUID are set) and can connect to slave device. Instead, in peripheral mode that device is working as HID Joystick and can connect to a PC and smartphones… but the data it’s not sent. In debug mode I can see the ble_hids_inp_rep_send return a failure message. I think the problem is relate to enable notifications, but I’m not sure…
This are the main changes in the ble_app_hrs_rscs_relay.
/**@brief Function for initializing the advertising functionality.
ret_code_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
int8_t tx_power = -20;// Set Power Level
init.advdata.p_tx_power_level = &tx_power;
init.config.ble_adv_whitelist_enabled = true;
init.config.ble_adv_directed_high_duty_enabled = true;
init.config.ble_adv_directed_enabled = false;
init.config.ble_adv_directed_interval = 0;
init.config.ble_adv_directed_timeout = 0;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
init.config.ble_adv_fast_timeout = APP_ADV_FAST_DURATION;
init.config.ble_adv_slow_enabled = true;
init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
init.config.ble_adv_slow_timeout = APP_ADV_SLOW_DURATION;
init.error_handler = ble_advertising_error_handler;
if (err_code== NRF_SUCCESS){
NRF_LOG_INFO("ADV INIT SUCCESFULL")
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
uint16_t role = ble_conn_state_role(conn_handle);
// Based on the role this device plays in the connection, dispatch to the right handler.
if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt))
//ble_hids_on_ble_evt(p_ble_evt, &m_hids);
on_ble_peripheral_evt(p_ble_evt);
else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
on_ble_central_evt(p_ble_evt);
static ble_gap_scan_params_t m_scan_param = /**< Scan parameters requested for scanning and connection. */
.active = 0x01,
.interval = NRF_BLE_SCAN_SCAN_INTERVAL,
.window = NRF_BLE_SCAN_SCAN_WINDOW,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
.timeout = NRF_BLE_SCAN_SCAN_DURATION,
.scan_phys = BLE_GAP_PHY_1MBPS,
.extended = true,
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.p_scan_param = &m_scan_param;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
NRF_LOG_INFO("Scan init success")
if (strlen(m_target_periph_name) != 0)
err_code = nrf_ble_scan_filter_set(&m_scan,
SCAN_NAME_FILTER,
m_target_periph_name);
NRF_LOG_INFO("filter set by name set success")
SCAN_UUID_FILTER,
&m_adv_slave_uuids[HART_RATE_SERVICE_UUID_IDX]);
NRF_LOG_INFO("filter set by uuid success")
err_code = nrf_ble_scan_filters_enable(&m_scan,
NRF_BLE_SCAN_NAME_FILTER| NRF_BLE_SCAN_UUID_FILTER,
false);
NRF_LOG_INFO("scan filter enable success")
/**@brief Function for initializing the GAP.
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device, including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HID_JOYSTICK);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_CONN_HANDLE_INVALID; // Start upon connection.
cp_init.disconnect_on_fail = true;
cp_init.evt_handler = NULL; // Ignore events.
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for initializing HID Service.
static void hids_init(void)
ble_hids_init_t hids_init_obj;
ble_hids_inp_rep_init_t * p_input_report;
uint8_t hid_info_flags;
static ble_hids_inp_rep_init_t inp_rep_array[INPUT_REPORT_COUNT];
static uint8_t rep_map_data[] =
0x05, 0x01, /* USAGE_PAGE (Generic Desktop) */
0x09, 0x04, /* USAGE (Joystick) */
0xa1, 0x01, /* COLLECTION (Application) */
0xa1, 0x03, /* COLLECTION (Report) */
0x85, 0x01, /* REPORT_ID (1) */
0x05, 0x09, /* USAGE_PAGE (Button) */
0x19, 0x01, /* USAGE_MINIMUM (Button 1) */
0x29, 0x10, /* USAGE_MAXIMUM (Button 16) */
0x15, 0x00, /* LOGICAL_MINIMUM (0) */
0x25, 0x01, /* LOGICAL_MAXIMUM (1) */
0x95, 0x10, /* REPORT_COUNT (16) */
0x75, 0x01, /* REPORT_SIZE (1) */
0x81, 0x02, /* INPUT (Data,Var,Abs) */
0xa1, 0x00, /* COLLECTION (Physical) */
0x09, 0x30, /* USAGE (X) */
0x09, 0x31, /* USAGE (Y) */
0x15, 0x81, /* LOGICAL_MINIMUM (-127) */
0x25, 0x7f, /* LOGICAL_MAXIMUM (127) */
0x75, 0x08, /* REPORT_SIZE (8) */
0x95, 0x02, /* REPORT_COUNT (2) */
0xc0, /* END_COLLECTION */
0xc0 /* END_COLLECTION */
memset(inp_rep_array, 0, sizeof(inp_rep_array));
// Initialize HID Service.
p_input_report = &inp_rep_array[INPUT_REP_INDEX];
p_input_report->max_len = INPUT_REP_LEN;
p_input_report->rep_ref.report_id = INPUT_REP_REF_ID ;
p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
p_input_report->sec.cccd_wr = SEC_JUST_WORKS;
p_input_report->sec.wr = SEC_JUST_WORKS;
p_input_report->sec.rd = SEC_JUST_WORKS;
hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
memset(&hids_init_obj, 0, sizeof(hids_init_obj));
hids_init_obj.evt_handler = on_hids_evt;
hids_init_obj.error_handler = service_error_handler;
hids_init_obj.is_kb = false;
hids_init_obj.is_mouse = false;
hids_init_obj.inp_rep_count = INPUT_REPORT_COUNT;
hids_init_obj.p_inp_rep_array = inp_rep_array;
hids_init_obj.outp_rep_count = 0;
hids_init_obj.p_outp_rep_array = NULL;
hids_init_obj.feature_rep_count = 0;
hids_init_obj.p_feature_rep_array = NULL;
hids_init_obj.rep_map.data_len = sizeof(rep_map_data);
hids_init_obj.rep_map.p_data = rep_map_data;
hids_init_obj.hid_information.bcd_hid = BASE_USB_HID_SPEC_VERSION;
hids_init_obj.hid_information.b_country_code = 0;
hids_init_obj.hid_information.flags = hid_info_flags;
hids_init_obj.included_services_count = 0;
hids_init_obj.p_included_services_array = NULL;
hids_init_obj.rep_map.rd_sec = SEC_JUST_WORKS;
hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
hids_init_obj.boot_mouse_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
hids_init_obj.boot_mouse_inp_rep_sec.wr = SEC_JUST_WORKS;
hids_init_obj.boot_mouse_inp_rep_sec.rd = SEC_JUST_WORKS;
hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
hids_init_obj.ctrl_point_wr_sec = SEC_JUST_WORKS;
err_code = ble_hids_init(&m_hids, &hids_init_obj);
if(err_code==NRF_SUCCESS){
NRF_LOG_INFO("HID init");
static void joystickMovementSendData( uint8_t buttonsOneToEight, uint8_t buttonsNineToSixteen, uint8_t inputX, uint8_t inputY)
uint8_t buffer[INPUT_REP_LEN];
if (m_in_boot_mode)
return;
APP_ERROR_CHECK_BOOL(INPUT_REP_LEN == 4);
buffer[0] = buttonsOneToEight;
buffer[1] = buttonsNineToSixteen;
buffer[2] = inputX;
buffer[3] = inputY;
err_code = ble_hids_inp_rep_send(&m_hids,
INPUT_REP_INDEX,
INPUT_REP_LEN,
buffer,
m_conn_handle);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
NRF_LOG_INFO("Send!");
}else {
NRF_LOG_INFO("NOT SENT...FAILED");
Your help will be greatly appreciable.
Thanks in advance for your support.
