SDK 16 S332 Bootloader
Hi
After getting  SDK16 , we have tried to load a combined hex file with  bootloader + S132 V7 + application with dfu + bootloader setting page to PCA10040. And It work well, dfu is ok.
And then We update bootloader and application form S132 to S332. It seems working well, while only programming bootloader and S332. but If we load a combined hex file with bootloader,softdevice,applcation,and bootloader setting page, It can't work, application isn't advertising. But If we debug the application( with S332 and bootloader), then it work well. Is there any setting we miss? We also use nfjprog --readregs to get register value while program stuck. The PC is 0x0003AB02 and check with map file, It is stuck at
_do debug_operation
0x000000000003aae8 __do_debug_operation
0x000000000003ab18 __text_end__ = (__text_start__ + SIZEOF (.text))
0x000000000000a744 __text_size__ = SIZEOF (.text)
0x000000000003ab18 __text_load_end__ = __text_end__
Brian
  • Hi Brian,
    Thank you for the updates. Is this log from the problematic case, when you program the merged hex via nrfjprog? Looking at the log the bootloader starts the application, so this indicate that there is no problem with the bootloader or bootloader settings. I am a bit puzzled about why the log states that it is advertising if it should not enter DFU mode, though.
    Can you debug the application to try to see what is happening there? Alternatively, use logging in the application as well? (Note that RTT logging in both the application and bootloader can be problematic, and while it can be fixed, it might be easier to just use UART logging from the application if you have problems.)
  • Hi Einar
    Thanks for your reply. The log above is captured from segger studio when I debug S332 bootloader. Before that I  program PCA1000 with S332 softdevice and bootloader hex via nrf connect desktop tool.
    And I will try to log the application and bootloader using uart logging.
    Brian
  • Hi Brian,
    I see. Dou you get the same RTT log if you don't debug via SES, just program the merged hex from nrfjprog and use RTT Viewer to observe the output? (just so we know it is the same as the failing case we have discussed earlier). I look forward to seeing that log, as well as the log from the application.
    Einar
  • Hi Einar
    while using segger to debug application , the RTT log are as below
    UART started.
    <info> app: Setting vector table to bootloader: 0x00072000
    <info> app: Setting vector table to main app: 0x00030000
    <info> app_timer: RTC: initialized.
    <info> app: Debug logging for UART over RTT started.
    while using nfjprog to programm S332 and bootloader (without segger debug), the RTT viewer log are as below
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <info> app: Boot validation failed. No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x20005984)
    <debug> app: timer_activate (0x20005984)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_ble: Initializing BLE DFU transport
    <debug> nrf_dfu_ble: Setting up vector table: 0x00072000
    <debug> nrf_dfu_ble: Enabling SoftDevice.
    <debug> nrf_dfu_ble: Configuring BLE stack.
    <debug> nrf_dfu_ble: Enabling the BLE stack.
    <debug> nrf_dfu_ble: No advertising name found
    <debug> nrf_dfu_ble: Using default advertising name
    <debug> nrf_dfu_ble: Advertising...
    <debug> nrf_dfu_ble: BLE DFU transport initialized.
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
    <debug> app: Enter main loop
    But, if I program combine hex file (bootloader, S332, application, bootloader setting page) to PCA10040, there is nothing logged in rtt viewer.
    Brian
  • Hi Einar
    Attached the combine hex file.
    Brian
    Final.hex
