ZB_ZCL_SEND_COMMAND_SHORT (..., cb) call back
Q1, Would it send out APS ACK request? so the call back is dealing the APS ACK confirmation, right?
Q2, If we set the call back as NULL, how the buffer got released?
Q3, If multiple ZB_ZCL_SEND_COMMAND_SHORT are sent, would the zboss call the right call back?
Thanks
    Sorry for the late reply.
    hlshen said:
     if Default Response is enabled, the client needs to register an endpoint handler to take care of it.
    For question 1 (Q1) I am actually not sure if you will get both a Default response and a Add group response if Default response is enabled, I will need to verify this using a sniffer, but from the ZCL specification it sounds like you either get a Add group response or a Default response.
    In ZCL spec section 2.3.2:
    If required, the device SHALL then generate a response to the command. Responses are detailed in the
    specification of each command. If there is no response specified for a particular set of circumstances, (e.g., if
    the command has been rejected or is not recognized, or the command has succeeded but there is no response
    specified to indicate success), the Default Response command SHALL be generated, taking into account the
    conditions in 2.5.12.2.
    If the Disable Default Response bit of the frame control field is not set to 0 (ZB_ZCL_DISABLE_DEFAULT_RESPONSE), or the other criteria listed in section 2.5.12.2 is not met, the Default Response will not be generated.
    The enable/disable the Default response frame shouldn't have anything to do with your decision to register or not an endpoint handler.
    Both the Default response and the Add group response command is handled by the stack, so you don't need any additional logic in your application. That's why you don't see any ZB_ZCL_GROUPS_GET_ADD_GROUP_REQ in the light bulb groups example (Q2).
    The endpoint handler is only implemented as a mechanism to override the default ZCL command processing of the stack, for example if you want to parse the Add group response command you need to do this in the endpoint handler.
    The callback is to handle the APS ACK send events. If no callback is set, the stack will free the buffer upon receiving APS ACK, if you assign a callback for e.g further configuration or for parsing the APS ACK you need to remember to free the buffer when finished.
    Q3. I think this is a typo in the documentation. I will check.
    BR,
    Marjeris
