After flashing Thingy 52 SDK from uvision IDE thingy not working
downloaded thingysdkv210 from thingy website. extracted that file and executed Prerequisites as per the procedure
downloaded Python v3.xx.xx
downloaded Git v2.xx.xx
Install GNU ARM embedded toolchain v4.9-2015q3
Make installed with default system path
download "Embedded MotionDriver 6.12"    -->   Unzip the downloaded `motion_driver_6.12` folder and navigate to `motion_driver_6.12/mpl libraries/arm/Keil`. Unzip the folder `libmpllib_Keil_M4FP.zip`. Copy the extracted library `libmpllib.lib` into `<your Thingy folder>/libs/libmpllib_Keil_M4FP/`.
---> unzip `/motion_driver_6.12/mpl libraries/arm/gcc4.9.3/liblibmplmpu_m4_hardfp.zip`  and copy the extracted library `liblibmplmpu.a` into the folder `<your Thingy folder>/libs/liblibmplmpu_m4_hardfp/`.
run bat file cmd prompt by executing setup_sdk.bat
complied code in uvision by importing ble_app_thingy_s132_pca20020.uvprojx project from thingy 52 sdk
flashed thingy from PEmicro universal multilink programmer. My thingy stopped reponding from LED. I just flashed code without changing firmware. and i was expecting to behave thingy functionality. But it dint work. I donno whats the issue.. Please guide me to get back working thingy52 firmware..
  • above image is my thingy 52 and programmer(PE micro universal multilink ) which i used for flashing thingysdkv210.
    how to load binaries from scratch?? may be you are true.. i think my boot loader is not working. observed my device is not going to boot mode during the power-on reset switch with top button press simultaneously.
    and i'm using uvision IDE for importing project, building and loading binaries.
    can i get boot-loader code separately so that i can flash my application from DFU to get back my thingy work.
