Bugs in ble_app_hrs_freertos example?
Some bugs in ble_app_hrs_freertos example from the SDK when handling buttons:
(at the end of this listing are same tests but with ble_app_hrs (no rtos) and buttons are handled as expected)
Tests were made with pca10040 / SDK 16.0.0 and SES 4.30b
Could you point where is the problem, please, because I've used some parts of this code as base for one my app and it handles buttons Ok in Release mode, but in Debug mode first pass through the button handler passes, but then the app stalls without reporting any error :(
Thanks
ble_app_hrs_freertos_pca10040_s132
Turn On the PCA10040 board:
<info> app: HRS FreeRTOS example started.
<info> app: Fast advertising.
Press Btn1: ->Sleep
Press Btn1 or Btn2 or Btn3 or Btn4:
While advertising:
Press Btn2:
<error> hardfault: HARD FAULT at 0x00000004
<error> hardfault: R0: 0x200067E4 R1: 0x20006738 R2: 0x200072E0 R3: 0x200072E0
<error> hardfault: R12: 0x20007138 LR: 0x00000004 PSR: 0x6000000E
<error> hardfault: Cause: The processor has attempted to execute an instruction that makes illegal use of the EPSR.
Press Btn3 or Btn4:
<error> hardfault: HARD FAULT at 0x00000002
<error> hardfault: R0: 0x20007098 R1: 0x20006FF8 R2: 0x200072E0 R3: 0x200072E0
<error> hardfault: R12: 0x200065D4 LR: 0x00000002 PSR: 0x6000000E
While Connected (not paired):
<info> app: Connected
Press Btn2:
Press Btn3 or Btn4:
<error> hardfault: R12: 0x20007138 LR: 0x00000002 PSR: 0x6000000E
--- When Paired:
restart:
Connect:
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
Press Btn1 Or Btn2 or Btn3 or Btn4:
For Btn1 and 2 (with some minor diffs in the values):
For Btn3 and 3 (with some minor diffs in the values):
ble_app_hrs_pca10040_s132: (here everything works Ok so far)
Press Btn1: ->Sleep
Press Btn1:
<info> app_timer: RTC: initialized.
<info> app: Heart Rate Sensor example started.
Long press Btn2:
Press Btn1: ->Sleep
Press Btn2:
<info> app: Erase bonds!
<info> peer_manager_handler: All peers deleted.
Pressing Btn2,Btn3, Btn4 while advertising or connected - no any effect
  • Hi bjorn-spockeli,
    I'm comparing ble_app_hrs_pca10040_s132 with ble_app_hrs_freertos_pca10040_s132
    with ble_app_hrs_pca10040_s132 when:
    Press Btn2 from sleep mode::
    Press Btn2 from sleep mode get only these:
    And bonding is not deleted - I tested it and other way with deleting bonding in the Android client, and after this cant reconnect, because old bonding stays in nRF. I didn't go in details through the code, but because of the documentation for HRS FreeRTOS example says: "See Heart Rate Application for a detailed description of the example scenario." I assume the functionality of the both applications should be the same?
    Any idea how can track the problem reported with the first posting: something related to nRF chip version (I have  PCA10040/ V1.1.1/2016.35) or is the SDK16.0.0  only unique release or there sub versions under the same number 16.0.0? I have nRF5_SDK_16.0.0_98a08e2
    This is IDE I'm using: SEGGER Embedded Studio for ARM/Release 4.30b  Build 2019111305.40571/Windows x64
    What is the value configTIMER_TASK_STACK_DEPTH in your test ( 80 )?
    BTW when I was trying to find proper value for configTIMER_TASK_STACK_DEPTH:
    At value 100, Btn 3 and Btn4 stopped giving hardfaults, but Btn2 make nRF to stall
    --- if I rise timer stack: 80 ->100
    If I press Btn3 or 4 no any effect or error, but if I press Btn2 while advertising - nRF stalls and need restart
    --- if I rise timer stack: 80 ->180
    <error> app: Fatal error
    <warning> app: System reset
    (cycling the same non stop)
    Thanks
  • Hi samsam,
     Yes, I am able to reproduce the issue when using the release configuration. I agree that the functionality should be the same as the non-FreeRTOS example.
    The hardware I am using is a PCA10040 v1.2.4 2018.39
    There is only one unique release of SDK v16.0.0, i.e. nRF5_SDK_16.0.0_98a08e2.  I am using SEGGER Embedded Studio for ARM Release 4.40  Build 2020011001.41059 Windows x64
     Yes, I was using configTIMER_TASK_STACK_DEPTH set to 80. I am seeing the Hardfaults when using button 3 and 4 in this configuration. Increasing configTIMER_TASK_STACK_DEPTH to 100 resolves the button 3 and 4 issues. However, I see the same issue as you with button 2 with configTIMER_TASK_STACK_DEPTH set to 80 and 100
     Yes, increasing configTIMER_TASK_STACK_DEPTH to 180 results in
    If I add DEBUG to the preprocessor definitions in SES, then i get the following output
    <error> app: ERROR 15 [NRF_ERROR_FORBIDDEN] at C:\Nordic_Semiconductor\SDK_repository\nRF5_SDK_16.0.0_684aa2c\examples\ble_peripheral\ble_app_hrs_freertos\main.c:983
    PC at: 0x000333F5
    <error> app: End of error report
    Which means that vTaskStartScheduler returns. Debugging the function I see that xTimerCreateTimerTask returns -1. Which means that  the kernel could not be started,
    because there was not enough FreeRTOS heap to create the idle task or the timer task.
    Increasing configTOTAL_HEAP_SIZE to 8192 from 4096 solved this issue and after doing this change I do not get a stall when pressing button 2. However, I do not see the bonds being erased, so there is apparently something that isnt configured correctly.
    regarding not erasing the bonds - I just go through the code - there is some mess with variable that suppose to trigger bond erasing procedure: in hrs_freertos there is one extra variable bool delete_bonds  which has only one assignment to false when is declared,   then the same name is used as the function static void delete_bonds(void) .... tomorrow will try to debug to see how to fix without side effects as now here is too late ;)
    BTW - your forum is also buggy - now I could answer only to myself :(
  • The erase_bond variable is set by buttons_leds_init(bool * p_erase_bonds), which calls bsp_btn_ble_init(NULL, &startup_event), which in turn calls startup_event_extract()
    static void startup_event_extract(bsp_event_t * p_startup_event)
        // React to button states
        if (bsp_button_is_pressed(BTN_ID_WAKEUP_BOND_DELETE))
            *p_startup_event = BSP_EVENT_CLEAR_BONDING_DATA;
        else if (bsp_button_is_pressed(BTN_ID_WAKEUP))
            *p_startup_event = BSP_EVENT_WAKEUP;
            *p_startup_event = BSP_EVENT_NOTHING;
    In the end of buttons_leds_init() you set  *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);
    Dont see why that shouldnt work. The startup_event_extract() function simply reads the pin...
    Best regards
    Bjørn
    It should work, but unfortunately doesn't work :( I got also some results, but unfortunately SES debugging doesn't work as suppose to and as soon as I put a breakpoint at any line inside main or try to step after initial breakpoint in debugging and the results/output differ from what is in run mode or debugging without any breakpoint. But using the lamest way with NRF_LOGs what I got so far:
        ret_code_t err_code;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    NRF_LOG_INFO("4. startup_event %d" , startup_event);
    NRF_LOG_INFO("5. startup_event %d" , startup_event);
    so in ble_app_hrs_freertos  (with #define configTOTAL_HEAP_SIZE (2 * 4096 ) ):
    From Sleep -> awake with Btn1 | Btn2 | 3 | 4
    <info> app: 4. startup_event 16
    <info> app: 5. startup_event 0
    While in ble_app_hrs:
    From Sleep -> awake with Btn2
    <info> app: 4. startup_event 0
    <info> app: 5. startup_event 2
    <info> app: 5. startup_event 11
    Unfortunately In debug mode (debugging) got those same results for all the buttons 1,2,3,4 if have any breakpoint at any place in main:
    So far I was able to track the problem up to  bsp_btn_ble_init(NULL, &startup_event); which in freertos flavor of hrs example  doesn't assign proper value to the second parameter 'startup_event' as it does in the hrs example without freertos.
    P.S. Let me know if you are able to debug/trace with your edition of SES ble_app_hrs and get same results/output as  in run mode, so I could upgrade my SES and then could dive in bsp_btn_ble_init to try further to identify source of the problem else with NRF_LOGs is quite a waste time.
    Thanks
