Bugs in ble_app_hrs_freertos example?
Some bugs in ble_app_hrs_freertos example from the SDK when handling buttons:
(at the end of this listing are same tests but with ble_app_hrs (no rtos) and buttons are handled as expected)
Tests were made with pca10040 / SDK 16.0.0 and SES 4.30b
Could you point where is the problem, please, because I've used some parts of this code as base for one my app and it handles buttons Ok in Release mode, but in Debug mode first pass through the button handler passes, but then the app stalls without reporting any error :(
Thanks
ble_app_hrs_freertos_pca10040_s132
Turn On the PCA10040 board:
<info> app: HRS FreeRTOS example started.
<info> app: Fast advertising.
Press Btn1: ->Sleep
Press Btn1 or Btn2 or Btn3 or Btn4:
While advertising:
Press Btn2:
<error> hardfault: HARD FAULT at 0x00000004
<error> hardfault: R0: 0x200067E4 R1: 0x20006738 R2: 0x200072E0 R3: 0x200072E0
<error> hardfault: R12: 0x20007138 LR: 0x00000004 PSR: 0x6000000E
<error> hardfault: Cause: The processor has attempted to execute an instruction that makes illegal use of the EPSR.
Press Btn3 or Btn4:
<error> hardfault: HARD FAULT at 0x00000002
<error> hardfault: R0: 0x20007098 R1: 0x20006FF8 R2: 0x200072E0 R3: 0x200072E0
<error> hardfault: R12: 0x200065D4 LR: 0x00000002 PSR: 0x6000000E
While Connected (not paired):
<info> app: Connected
Press Btn2:
Press Btn3 or Btn4:
<error> hardfault: R12: 0x20007138 LR: 0x00000002 PSR: 0x6000000E
--- When Paired:
restart:
Connect:
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
Press Btn1 Or Btn2 or Btn3 or Btn4:
For Btn1 and 2 (with some minor diffs in the values):
For Btn3 and 3 (with some minor diffs in the values):
ble_app_hrs_pca10040_s132: (here everything works Ok so far)
Press Btn1: ->Sleep
Press Btn1:
<info> app_timer: RTC: initialized.
<info> app: Heart Rate Sensor example started.
Long press Btn2:
Press Btn1: ->Sleep
Press Btn2:
<info> app: Erase bonds!
<info> peer_manager_handler: All peers deleted.
Pressing Btn2,Btn3, Btn4 while advertising or connected - no any effect
  • samsam said:
    1. Longer press on the Btn2 needs  until program flow reach bsp_button_is_pressed(BTN_ID_WAKEUP)  at which moment local variable in main() erase_bonds is set to whatever is the current state of the button(not the state the button was at wake-up/reset event)
    2. The actual process for starting delete existing bondings procedure is performed from within the FreeRTOS task  softdevice_task, but unless I change the erase_bonds to static, the correct value that was set for this variable in main() is not seen in the body of the softdevice_task.  Maybe same effect will be if I move erase_bonds variable outside main(), but I didn't try it.
    The question for the 'volatile' was because I read in a lot of places in the examples where they put volatile in order to secure that the variable will prevent  the compiler to optimize it in such way that might not be available for all the  threads that might  need access to it, so currently my test  with 'static' works fine, but I'm not sure is it enough for 'worst scenario' ...
     OK, will report that static is missing in our internal issue database. I dont think that volatile is needed here.
    samsam said:
    BTW where disappear my last post as I cant see ?
    The event log states that your last reply was on 1/24/2020 1:46:05 PM and the second last reply was on 1/23/2020 7:06:42 PM. But I can see your reply on 1/23/20 15:53 in our support view. Could be that its not shown in the public view. Will report this as well.
