nRF9160 maximum transmit duty cycle
I am curious if there is an inherit maximum transmit duty cycle of either M1 or the nRF9160.  I am asking for this because we need these numbers for SAR test.  Our product will be near the body and the duty cycle will be an important parameter for this test.
    Unfortunately there is nothing new on this, the max duty cycle is 32/37 and 256/296. How long this lasts for depends on the application and how much data that has to send.
    Andreas
    One example calculation. Your case might be slightly different but it should give a ballpark estimate:
    1 kbyte user data is transmitted over LTE-M1 uplink.
    Assuming 40% higher layer overhead (estimate), and upon various assumption related to physical layer procedures and radio channel, we may estimate that the total time needed for UE to transmit 1 kbyte is about 0.5 second. The UL duty cycle during the transmission period of 0.5 second is 57% (assuming the repetition number for PUSCH is 8 and repetition number for MPDCCH is 2). So, the total UL duty cycle is
    UL duty cycle (over 30 minutes) is: N * 0.5 * 0.57 / (30 * 60),
    where N is the number of user data packets, each of size 1 kbyte, transmitted during the period of 30 minutes.
    Andreas
