BLE does not work after writing a value to UICR
Hi, Everyone
My Environment: nRF52840, SDK15.3, Keil
My code is:
err_code = nrf_sdh_disable_request();
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
while (NRF_NVMC->READY == NVMC_READY_READY_Busy){};
NRF_UICR->CUSTOMER[AES_KEY0] = aes_key0;
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
BLE works before writing data to UICR
However, after writing data to UICR, the name does not appear when scanning from nRFconnect.
Please advise.
  • Hi Einar,
    Thank you for your answer.
    We will change the encryption key every hour.
    The encryption key value should be saved even after reset.
    Your advice seems to be inconvenient to store data that changes frequently in UICR.
    I'll find another way to use it.
    Alex
  • Hi Alex,
    Yes, it is definitely inconvenient to store data that changes frequently in UICR. In fact, it is practically impossible, since you normally don't want to erase the UICR page, and a page erase is needed whenever you want to overwrite data in the same address with new data. I suggest you look into FDS for this, which is perfect for frequently changing data.
  • Hi, sorry to hijack the thread but we have a similar design issue regarding optimal frequency of the key exchange. As I understand the max no of writes to flash-mem is about 10 000. That means the life expectancy using one hour key exchange is about 1 year and 51 days. Correct?
    One solution is to just increase frequency of the key exchange to meet the expected life span of the product but I've got a couple of follow upp questions before we can make any decisions:
    1. Are 10000 max-writes the same for all socs?
    2. Are there any other storage options with static ram or similar that fits 16 bytes with no limitation regarding number of writes?
    Br, Lars.
  • Hi Lars,
    That is the typical number for all nRF52 devices I believe.
    You can use GPREGRET if you don't need the data to be persistent across power-on-reset. However, if you need truly persistent storage, then you probably need to use the flash.
    The SDK includes the FDS library, which is essentially a very simple file system. It implements basic wear leveling, which is very sensible in this case. Essentially you set aside a few flash pages (minimum 2, since there must be one swap page), and the data is moved around whenever you update it, spreading the wear across all the flash pages that are allocated for this. Most BLE examples already use this since it is used by the Peer manager for storing bonding information.
    Einar
  • Thanks!
    1. Does this mean that if you allocate 5 pages you can perform 50 000 writes?
    2. What's the minimal page size (since we only need room for 16 bytes)?
    Lars.
