troubleshooting of produced prototype: nrf9160
I have developed 10pcs of one prototype with the nrf9160 SiP.
I have some questions regarding some errors im having.
Regarding the SIM 1V8 driver VCC, for UICC interface, I am observing a fluctuation on this channel/voltage, from 0V -> 0.4 VDC, with approximately 1hz frequency.
What can cause this to happend, what is the normal behaviour of this channel when it is short-circuited with ground or something else/similar ?
My second question is regarding the attached image, im observing this on a few of my prototypes, im not able to upload any modem firmware to the SiP, any idea why?
David
  • You are correct, I am using an external strap between (pin 2 of J7 -> C24 pad 1 (capacitor below analoge switch))
  • I measure 0 Ohm between sim traces and gnd, when board is power off. Is this normal?
    Regards, David
    David said:
    If I meassure the voltage on some other boards of my prototype, I meassure a stable 2.2V on DEC0, on the one prototype that I am having the issue with the sim-interface voltage, I meassure here between 2.1 and 2.2 VDC, oscillation.
     OK, nice to know although I am not sure this answers anything at this point.
    David said:
    I am still waiting for the correct capacitor components, for DEC0 -> GND. Therefore, DEC0 is floating at the moment.
     Not sure if this is ideal, 4.7µF is better than nothing I would assume. It is not necessarily incorrect, but with 47µF the clock signals will be more resilient across PVT variation and is recommended for mass production devices.
     Not sure, I have forwarded it internally.
     Thanks for the confirmation, this is all good then.
    Andreas
  • Hello again,
    I must correct myself:
    J7 was set to ground.
    Thank you for replying so fast, It seems that the main issue now, is the missing 1V8 voltage from the SIM vdd.
    I would appreciate it, if your support team could answer me on, what possily  can cause this, maybe firmware related?
    Regards, David
    OK, thanks for correcting.
    I am a 'HW guy' so not really the right person to judge your FW or the modem FW, but as Didrik judged it we believe this to be HW related.
    Andreas
