nrfutil "image not found error"
Hi there,
I'm using nrfutil (nrfutil version 6.0.1) to dfu via ble (dongle),
Mac (10.15.2), windows (10), linux (raspbian) have been tried out to update the firmware
none has successfully updated the firmware
the command line used to update firmware is </nrfutil dfu ble -pkg <FilePath> -ic NRF52 -n "<DeviceName>" -f>
for windows extra </-p COM1> was added which was the dongle com port,
for raspbian, it was a deadend since the beginning of installation as the latest version available for module (pc-ble-driver-py) was 0.11.4, while requirements was 0.14.1, so I assumed to have it working first on the other 2 platforms,
so, I got for Mac the following error:
  File "/usr/local/bin/nrfutil", line 8, in <module>
    sys.exit(cli())
  File "/Users/ramyezzat/Library/Python/3.7/lib/python/site-packages/click/core.py", line 764, in __call__
    return self.main(*args, **kwargs)
  File "/Users/ramyezzat/Library/Python/3.7/lib/python/site-packages/click/core.py", line 717, in main
    rv = self.invoke(ctx)
  File "/Users/ramyezzat/Library/Python/3.7/lib/python/site-packages/click/core.py", line 1137, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/Users/ramyezzat/Library/Python/3.7/lib/python/site-packages/click/core.py", line 956, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/Users/ramyezzat/Library/Python/3.7/lib/python/site-packages/click/core.py", line 555, in invoke
    return callback(*args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/nordicsemi/__main__.py", line 1099, in ble
    ble_driver_init(conn_ic_id)
  File "/usr/local/lib/python3.7/site-packages/nordicsemi/__main__.py", line 68, in ble_driver_init
    from pc_ble_driver_py.ble_driver    import BLEDriver, Flasher
  File "/usr/local/lib/python3.7/site-packages/pc_ble_driver_py/ble_driver.py", line 77, in <module>
    import pc_ble_driver_py.lib.nrf_ble_driver_sd_api_v5 as driver
  File "/usr/local/lib/python3.7/site-packages/pc_ble_driver_py/lib/nrf_ble_driver_sd_api_v5.py", line 13, in <module>
    from . import _nrf_ble_driver_sd_api_v5
ImportError: dlopen(/usr/local/lib/python3.7/site-packages/pc_ble_driver_py/lib/_nrf_ble_driver_sd_api_v5.so, 2): Library not loaded: /Library/Frameworks/Python.framework/Versions/3.7/Python
  Referenced from: /usr/local/lib/python3.7/site-packages/pc_ble_driver_py/lib/_nrf_ble_driver_sd_api_v5.so
  Reason: image not found
and for windows I got the following error:
  File "c:\users\developer\python3\lib\site-packages\pc_ble_driver_py\ble_driver.py", line 2731, in __init__
    snr = [d.serial_number for d in serial_ports if d.port == serial_port][0]
IndexError: list index out of range
During handling of the above exception, another exception occurred:
  File "C:\Users\developer\PYTHON3\Scripts\nrfutil-script.py", line 11, in <module>
    load_entry_point('nrfutil==6.0.1', 'console_scripts', 'nrfutil')()
  File "c:\users\developer\python3\lib\site-packages\click\core.py", line 764, in __call__
  File "c:\users\developer\python3\lib\site-packages\click\core.py", line 717, in main
  File "c:\users\developer\python3\lib\site-packages\click\core.py", line 1137, in invoke
  File "c:\users\developer\python3\lib\site-packages\click\core.py", line 956, in invoke
  File "c:\users\developer\python3\lib\site-packages\click\core.py", line 555, in invoke
  File "c:\users\developer\python3\lib\site-packages\nrfutil-6.0.1-py3.8.egg\nordicsemi\__main__.py", line 1120, in ble
    flasher = Flasher(serial_port=port, snr = jlink_snr)
  File "c:\users\developer\python3\lib\site-packages\pc_ble_driver_py\ble_driver.py", line 2733, in __init__
    raise NordicSemiException("Board not found: {}".format(serial_port or snr))
pc_ble_driver_py.exceptions.NordicSemiException: Board not found: COM1
eventually I'd like to wrap the code into another python module,
any idea what could possibly be wrong or missing?
  • yes reading it again it's confusing
    Is it enough to connect the DK and use the nrfutil + <-snr <DK serial number>>? would the nrfutil will be using the ble on DK board directly?
    or should I build and run an example from SDK?
    thinking about it again, I think it's enough to direct the nrfutil to the connected DK, isn't it?
    You do not need to build an example from the SDK, but you need to program the correct connectivity firmware for nrfutil. Firmware for the DK can be flashed by nrfutil with the "-f" option. Unlike the nRF Connect BLE app, nrfutil does not do it for you automatically for the dongle. You can refer to this post for more details.
  • thanks a lot for the support!
    one last thing, the linux .whl module of pc_ble_driver_py latest version doesn't meet the nrfutil repo. requirement, where it has to be 0.14.1 or more while the available latest for now is 0.11.2
  • Another question, Is it possible at all to DFU using a generic ble dongle say this ASUS dongle mentioned earlier or another?
    in case not I managed to get the library installed on linux, yet not the pc_ble_driver_py library, still release is earlier than the requirement
    using the following command line:
    nrfutil dfu ble -ic NRF52 -pkg NAS_lwm_EU868_1_2_3_dfu.zip -p /dev/ttyACM0 -a "F7:E7:B1:D8:72:F3"
    I got the following exception:
    File "/home/nas0082/.local/bin/nrfutil", line 11, in <module>
    File "/home/nas0082/.local/lib/python3.6/site-packages/click/core.py", line 764, in __call__
    File "/home/nas0082/.local/lib/python3.6/site-packages/click/core.py", line 717, in main
    File "/home/nas0082/.local/lib/python3.6/site-packages/click/core.py", line 1137, in invoke
    File "/home/nas0082/.local/lib/python3.6/site-packages/click/core.py", line 956, in invoke
    File "/home/nas0082/.local/lib/python3.6/site-packages/click/core.py", line 555, in invoke
    File "/usr/local/lib/python3.6/dist-packages/nrfutil-6.0.1-py3.6.egg/nordicsemi/__main__.py", line 1099, in ble
    File "/usr/local/lib/python3.6/dist-packages/nrfutil-6.0.1-py3.6.egg/nordicsemi/__main__.py", line 68, in ble_driver_init
    File "/home/nas0082/.local/lib/python3.6/site-packages/pc_ble_driver_py/ble_driver.py", line 112, in <module>
    driver = importlib.import_module(SWIG_MODULE_NAME)
    File "/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
    File "/home/nas0082/.local/lib/python3.6/site-packages/pc_ble_driver_py/lib/linux/x86_64/pc_ble_driver_sd_api_v3.py", line 28, in <module>
    _pc_ble_driver_sd_api_v3 = swig_import_helper()
    File "/home/nas0082/.local/lib/python3.6/site-packages/pc_ble_driver_py/lib/linux/x86_64/pc_ble_driver_sd_api_v3.py", line 24, in swig_import_helper
    _mod = imp.load_module('_pc_ble_driver_sd_api_v3', fp, pathname, description)
    File "/usr/lib/python3.6/imp.py", line 243, in load_module
    return load_dynamic(name, filename, file)
    File "/usr/lib/python3.6/imp.py", line 343, in load_dynamic
    return _load(spec)
    ImportError: dynamic module does not define module export function (PyInit__pc_ble_driver_sd_api_v3)
    for the same linux machine I tried nrfConnect the desktop application I got the following error in the picture
    Yes, but then you need to write your own DFU master application. We provide generic DFU master libraries for iOS and Android, but for PC we just provide DFU imålementations that require nRF HW connected to the PC.
    Did you install nrfutil with pip this time, and did all dependencies install correctly (particularily pc-ble-driver-py in this case)?
    The nRF Connect issue may not be related. It also uses the pc-ble-driver (via JavaScrip bindings instead of Python bindings), but everything on top of that is different. The nRF Connect. That should work out of the box, since it is distributed in a self-contained way (using an AppImage that should work on most major Linux distros). Please make a separate thread for that if you need more follow up to keep topics separate.
