When CONFIG_PROVISION_CERTIFICATES is y and certificates are defined in certificates.h the program fails in provision_certificates() function, the modem_key_mgmt_delete function never returns.
Version is master from this morning.
Your modem_configure() function is different vs the one in aws_fota sample...
Please do a test with aws_fota sample. Only set your broker, certificates and set CONFIG_PROVISION_CERTIFICATES
This is the actual modem_configure() code.
static void modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
BUILD_ASSERT_MSG(!IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT),
"This sample does not support auto init and connect");
int err;
err = at_notif_init();
__ASSERT(err == 0, "AT Notify could not be initialized.");
err = at_cmd_init();
__ASSERT(err == 0, "AT CMD could not be established.");
printk("LTE Link Connecting ...\n");
err = lte_lc_init_and_connect();
__ASSERT(err == 0, "LTE link could not be established.");
printk("LTE Link Connected!\n");
}Fabien Comte said:This is the actual modem_configure() code.
Yes, I'm sorry, I used the modem_configure() from another sample. But still, it shows that lte_lc_init_and_connect() is called within it.
Fabien Comte said:Please do a test with aws_fota sample. Only set your broker, certificates and set CONFIG_PROVISION_CERTIFICATES
I can run it, but can you please run the example first and provide the output from the LTE Link Monitor? I need more information to know what I'm looking for, and if there is anything else failing.
Your initial issue was that modem_key_mgmt_delete() never returns, and now it's lte_lc_init_and_connect(). And with the fact that you have modified the sample, it is difficult for me to know what it the problem.
Let's start fresh:
Thank you.
-Øyvind
