Missing BLE_GATTS_EVT_HVN_TX_COMPLETE events
Our BLE peripheral uses a custom GATT service similar to the NUS (Nordic UART service) used in the SDK example app_ble_uart. The peripheral receives data on the UART peripheral (not UARTE) from an external device at 115200 baud with full hardware handshaking.
Our PDU data length is configured as 251 and our MTU size as 247.
The peripheral repeatedly calls sd_ble_gatts_hvx with a 244 byte ATT data packet but we only receive 4 BLE_GATTS_EVT_HVN_TX_COMPLETE events.
You can see on the oscilloscope screenshot below that we have called sd_ble_gatts_hvx 11 times (SD_SEND) but have only received TX_COMPLETE 4 times. We keep track of the number of notifications available to us so we no longer try to send after calling sd_ble_gatts_hvx 7 times since the last TX_COMPLETE event.
We are outputting any errors returned by the sd_ble_gatts_hvx call using a spare GPIO line (SD_SEND_ERR) and you can see that there are none.
We have tried keeping the PDU data length configured as 251 and our MTU size as 247, but calling sd_ble_gatts_hvx with 200 byte data payload instead and this has resolved the issue.
So the main question is why do we stop receiving the BLE_GATTS_EVT_HVN_TX_COMPLETE event when we use the maximum payload size?
More detailed setup information:
BLE peripheral = nrf52 dev kit (PCA10040).
BLE central = custom hardware using nrf52832.
We are using the S132 SoftDevice v 7.0.1.
We are not using the nRF SDK driver or HAL layers – we’re interfacing with the peripherals directly, but the chip header files we’re using are taken from SDK version 15.2.
BLE connection parameters:
Connection interval 7.5ms
Event length 7.5ms
Slave latency 0.
Connection supervisory timeout 1s.
Extended event length enabled.
MTU size 247
PDU data length 251
BLE notifications queue size (hvn_tx_queue_size) 7
Happy to provide more information if needed.
  • Hi  Mark,
    To be honest it is the same all over the trace. Looking at the sniffer trace there is a lot of retransmissions. So much that I don't know if the trace makes sense. Have you had your HW properly tuned? Can you test with DK's on both sides so that we know you are using proper HW?
    It may be that you don't get BLE_GATTS_EVT_HVN_TX_COMPLETE events because you don't get data through. And you don't get errors from your call to sd_ble_gatts_hvx() because you stop calling git when the buffer is full (since packets are not successfully sent, even though you do get some data through).
    As mentioned it would be good to test this on knowing good HW. And if that doe snot help, then It would be interesting to see all of your code.
    Einar
  • Hi Einar,
    We are using the nRF52832 chip inside the ISP1507 SoC, so we have no radio or low-level hardware design of our own.
    The central device consists of a ISP1507 connected to an FT2330XS-R USB UART bridge, with a local 3V3 PSU. There is no other circuitry.
    Is this the hardware configuration you'd expect?
    Is there anything in the code that looks particularly suspicious to you?
    If we're not getting data through over the radio after the GATT timeout / supervisory timeout then why would the BLE link not drop (we are handling BLE_GAP_EVT_DISCONNECTED)?
    Mark
  • Hi Mark,
    I see. There should not be any problems using the ISP1507.
    I am having problems understanding what could be the problem here.  Would it be possible to share your complete project, so that I can get a better overview? Also, is it possible to modify it to run on the DK, so that I can test on my side (using two DK's, one for central and one for peripheral)?
    You are right, you will get a disconnect if no packets make it through for the duration of the supervision timeout. And if there is only a problem on the GATT layer, you will get a timeout there as well.
    Einar
  • Hi Einar,
    Here are the central and peripheral binaries that can be run on two DK's.
    Central:
    /cfs-file/__key/communityserver-discussions-components-files/4/deployment.hex
    Peripheral (sends 200 bytes ATT payload):
    Peripheral (sends 244 bytes ATT payload):
    The central will automatically connect to the peripheral.
    Any data received by the peripheral over UART will then be sent over the air to the central.
    You should be able to recreate the issue we're seeing with these.
    I'm happy to provide the complete project, but would rather not upload it all here.
    Mark
  • To clarify, you should already be able to build and run the central side from the project I uploaded previously as there are no I/O changes required for deployment on the development kit.
    When peeking the event length on calling sd_ble_evt_get() I've observed that the event length is always 16 bytes more than the maximum MTU size...
    and I've confirmed that my application works with an MTU size of 231 bytes (247 - 16) but not 232.
    I was using the 'BLE_EVT_LEN_MAX' macro defined in the SDK to calculate the evt_buffer length and this sets the event buffer size to be 247.
    If I set this event buffer size to 263 (247 + 16) then I am then able to set the ATT data payload to 244 and my application works successfully.
    Why does the event buffer size need to be 16 bytes larger than the event size?
    Mark
