APP_USBD_HID_USER_EVT_OUT_REPORT_READY trigger only one time with USB OTG
I'm having a weird problem while doing a communication between nRF52840( perpherial device ) with USB OTG ( STM32 ).
I'm trying send out the data from USB OTG -> nRF52840 via HID OUT endpoint.
I only get the event APP_USBD_HID_USER_EVT_OUT_REPORT_READY one time and get the data by API app_usbd_hid_generic_out_report_get
From second time, I can't get APP_USBD_HID_USER_EVT_OUT_REPORT_READY  any more?
Any require ment to clear the buffer?
I know that I have to call
while(1)
app_usbd_event_queue_process();
but it doesn't work
Any idea?
  • nfo> app: USBD HID generic example started.
    ebug> nrf_ble_lesc: Initialized nrf_crypto.
    ebug> nrf_ble_lesc: Initialized nrf_ble_lesc.
    ebug> nrf_ble_lesc: Generating ECC key pair
    nfo> app: SPI parse
    nfo> app: SPI parse
    nfo> app: USB power detected
    nfo> app: USB ready
    ebug> USBD: USBD event: SUSPEND
    nfo> app: APP_USBD_EVT_DRV_SUSPEND
    ebug> USBD: USBD event: RESUME
    nfo> app: APP_USBD_EVT_DRV_RESET
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0100 i:0000 l:8 )
    ebug> USBD: Transfer called on endpoint 80, size: 8, mode: FLASH
    ebug> USBD: USB DMA process: Starting transfer on EP: 80, size: 8
    ebug> USBD: USB DMA process - finishing
    ebug> USBD: USB event: DMA ready IN0
    ebug> USBD: USBD event: EndpointData: 80
    ebug> USBD: USBD event: EndpointData: In finished
    ebug> USBD: >> ep0status >>
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0100 i:0000 l:18 )
    ebug> USBD: Transfer called on endpoint 80, size: 18, mode: FLASH
    ebug> USBD: USB DMA process: Starting transfer on EP: 80, size: 18
    ebug> USBD: USBD event: Setup (rt:00 r:05 v:0001 i:0000 l:0 )
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0200 i:0000 l:9 )
    ebug> USBD: Transfer called on endpoint 80, mode: Handler
    ebug> USBD: USB DMA process: Starting transfer on EP: 80, size: 9
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0200 i:0000 l:41 )
    ebug> USBD: USB DMA process: Starting transfer on EP: 80, size: 32
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0301 i:0409 l:255 )
    ebug> USBD: Transfer called on endpoint 80, size: 14, mode: RAM
    ebug> USBD: USB DMA process: Starting transfer on EP: 80, size: 14
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0302 i:0409 l:255 )
    ebug> USBD: Transfer called on endpoint 80, size: 12, mode: RAM
    ebug> USBD: USB DMA process: Starting transfer on EP: 80, size: 12
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0303 i:0409 l:255 )
    ebug> USBD: Transfer called on endpoint 80, size: 22, mode: RAM
    ebug> USBD: USB DMA process: Starting transfer on EP: 80, size: 22
    ebug> USBD: USBD event: Setup (rt:00 r:09 v:0001 i:0000 l:0 )
    ebug> USBD: USBD event: Setup (rt:81 r:06 v:2100 i:0000 l:9 )
    ebug> USBD: Transfer called on endpoint 80, size: 9, mode: RAM
    ebug> USBD: USBD event: Setup (rt:81 r:06 v:2200 i:0000 l:40 )
    ebug> USBD: Transfer called on endpoint 80, size: 40, mode: FLASH
    ebug> USBD: USBD event: Setup (rt:21 r:0A v:0000 i:0000 l:0 )
    ebug> USBD: USBD event: Setup (rt:21 r:0B v:0001 i:0000 l:0 )
    nfo> app: SET_REPORT_PROTO
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0301 i:0409 l:100 )
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0302 i:0409 l:100 )
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0300 i:0409 l:100 )
    ebug> USBD: Transfer called on endpoint 80, size: 4, mode: FLASH
    ebug> USBD: USB DMA process: Starting transfer on EP: 80, size: 4
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0304 i:0409 l:100 )
    ebug> USBD: Transfer called on endpoint 80, size: 24, mode: RAM
    ebug> USBD: USB DMA process: Starting transfer on EP: 80, size: 24
    ebug> USBD: USBD event: Setup (rt:80 r:06 v:0303 i:0409 l:100 )
    ebug> USBD: USBD event: EndpointEPStatus: 40000
    ebug> USBD: USBD event: EndpointData: 2
    ebug> USBD: USBD event: EndpointData: Out waiting
    ebug> USBD: USB DMA process: Starting transfer on EP: 2, size: 32
    ebug> USBD: DMA ready OUT: 2
    nfo> app: OUT_REPORT_READY
    nfo> app: GET OUT report event: 32
    nfo> app: 55
    nfo> app: AA
    nfo> app: 20
    nfo> app: 16
    nfo> app: 32
    nfo> app: to dsPic: 55
    nfo> app: to dsPic: AA
    nfo> app: to dsPic: 20
    nfo> app: to dsPic: 16
    nfo> app: to dsPic: 32
    ebug> USBD: Transfer called on endpoint 81, size: 32, mode: RAM
    ebug> USBD: USB DMA process: Starting transfer on EP: 81, size: 32
    ebug> USBD: USB event: DMA ready IN: 81
    ebug> USBD: USBD event: EndpointEPStatus: 2
    ebug> USBD: USBD event: EndpointData: 81
    nfo> app: IN REPORT DONE 32
    nfo> app: USB power removed
  • When I send to OUT transation on PC ( Windows), everything works well. I think there is a problem with bus of USB OTG but don't know why it got the packet one first time.
  • Hi
    In that case I would check with ST if they have any idea why the USB OTG is unreliable. Could be something wrong with the setup on their side.
    Best regards
    Torbjørn
