I use two nRF52840 to send notifications every second. Analysis using a logic analyzer revealed that the reception interval had strange variations. What is causing this? Why is there a gap at 1 second from the reception?
connection interval 10ms.
Hi
If you just want to send data, and not worry about connection events/intervals, wouldn't it be easier to just have a beacon transmit the data every X second, as it won't have to wait to connect until it transmits data.
To avoid any BLE device to be able to read the data transmitted by your beacon, you can use a whitelist so that it will only advertise to your central. This will, of course, not work as a notification, as notifications require responses from the central, which a beacon is not able to receive.
Best regards
I see.
Am I using broadcast mode instead of connection?
I'll try.
