Using RTC to create a delay that sleeps while waiting
Our device uses an nRF52840 and we are using SDK v15.3.0 and soft device v140.
In order to optimize power consumption, I want to make a delay function using the RTC (with external oscillator) that will put the device to sleep while it waits.
The delay using the RTC works, as indicated via the LED, but it doesn't go to sleep.
Elsewhere in the code I can successfully enter sleep.
Following is edited and condensed code for how I am trying to implement this delay.
const nrf_drv_rtc_t _realTimClock   = NRF_DRV_RTC_INSTANCE(2);    ///< Declaring an instance of nrf_drv_rtc for RTC2.
rtc_callback_t      _callbacks[RTC_NUM_CHANNELS];                 ///< RTC has 4 timer compare registers.
void rtcInit(void) {
  uint32_t  errorCode;
  /// Initialize RTC instance
  nrf_drv_rtc_config_t  config = NRF_DRV_RTC_DEFAULT_CONFIG;
  config.prescaler = 32;
  errorCode = nrf_drv_rtc_init(&_realTimClock, &config, rtc_handler);
  APP_ERROR_CHECK(errorCode);
  /// Disable tick event & interrupt
  nrf_drv_rtc_tick_enable(&_realTimClock, false);
  /// Power on RTC instance
  nrf_drv_rtc_enable(&_realTimClock);
void runCallback(uint8_t rtc_compare_channel_id) {
  /// Run the requested callback function.
  _callbacks[rtc_compare_channel_id]();
 * @brief:  Function for handling the RTC0 interrupts.
 *      	Triggered on TICK and COMPARE0 match.
static void rtc_handler(nrf_drv_rtc_int_type_t int_type) {
  switch(int_type) {
    /// Intentional fall throughs.
    case NRF_DRV_RTC_INT_COMPARE0:
    case NRF_DRV_RTC_INT_COMPARE1:
    case NRF_DRV_RTC_INT_COMPARE2:
    case NRF_DRV_RTC_INT_COMPARE3:
      runCallback(int_type);
    case NRF_DRV_RTC_INT_OVERFLOW:
      /// RTC overflow event.
    case NRF_DRV_RTC_INT_TICK:
      /// RTC tick event.
      /// Unknown RTC event. Added for completeness.
bool setMsCallback(uint8_t id, uint64_t milliSeconds, rtc_callback_t handler) {
  uint32_t  errorCode;
  uint32_t  delayTimeMs = milliSeconds*RTC_TICKS_PER_SECOND/1000;
  _callbacks[id] = handler;
  errorCode = nrf_drv_rtc_cc_set(&_realTimClock, id, (delayTimeMs + nrf_drv_rtc_counter_get(&_realTimClock)), true);
  if (errorCode == 0) {
    return true;
  else {
    return false;
static void ledToggle(void) {
  nrf_gpio_pin_toggle(PIN_RED_LED);
void rtc_delayMs(uint32_t period)
  /// Trigger the RTC to restart and toggle the LED in 'period' number of milliseconds. Using
  setMsCallback(NRF_DRV_RTC_INT_COMPARE2, period, ledToggle);
  NVIC_ClearPendingIRQ(RTC2_IRQn);
  /// Make sure the RTC IRQ is enabled.
  NVIC_EnableIRQ(RTC2_IRQn);
  /// Go to sleep.
  sd_app_evt_wait();
  ///setup systick timer
  SysTick_Config( SystemCoreClock / 1000 );
  rtcInit();
  BLEInit();  /// BLE will start interrupts and LFClk
  /// Test the newly implemented RTC delay with sleep.
  nrf_gpio_cfg_output(PIN_RED_LED);
  nrf_gpio_pin_set(PIN_RED_LED);
  while(1) {
    rtc_delayMs(5000);
  • I am fairly certain that my method of power consumption measurement is solid.
    The method of current consumption I am using is to charge a large capacitor, power our device using it for a set period of time, and then measuring how much capacitor voltage has dropped. From this I calculate the current consumed so that I get a good average current consumption including time sleeping.
    Is there anything that the power profiler could tell me of my total power consumption that this method will not?
    From power measurements done before trying to implement this RTC delay with sleep I was using ~3x less current.
    This new RTC delay with sleep was added to allow me to wait for a specific sensor measurement to complete. Previously I just used the RTC to trigger tasks and the main loop went to sleep.
  • The power profiler provides a very detailed view of the power draw in time and graphs this for you.
    Outside of that I noticed that you have this  statement SysTick_Config( SystemCoreClock / 1000 );  Are you using the Systick timer?
  • I am using cystic timer. The code I posted is a small edited subset of the whole body of code.
