I’m very familiar with the HID keyboard and mouse profile and have built products using it but need direction on how to replicate the functionality of a up/down/left/right finger swipe on a iPhone. Any guidance will be valuable. Thanks
Hi Matthew
Did you check packets 100, 103, 106 etc like I mentioned?
Packet 100 starts with 0x05, 0x0D, 0x09, 0x02, 0xA1, 0x01 .., which is clearly the start of the HID descriptor. It is quite similar to the descriptor you shared below, except the usage is 0x02 (mouse) instead of 0x04 (touch screen).
Looking at the log again the entire descriptor seems to be sent across the following packets: 100, 103, 106, 109, 112 and 115.
Best regards
Torbjørn
Hi Ovrebekk,
I received a new remote in the mail today that was better quality and is performing the same function I'm trying to duplicate. This remote has a nRF51822 instead of some cheap China IC. I took everything that you have educated me on and derived to the following information. I was able to extract the report and also attempted to fill it out with comments. It looks like it is presenting itself as a Digitizer and performing a single finger touch swipe effect. I was able to capture the data for each button press. I'm assuming the data is representing the finger press and the sliding across the screen. I'm thinking I need to take the ble_app_hids_keyboard example and add this report then try sending the raw data. I say keyboard because the remote shows up as keyboard on the computer and I plan to use this with my current product that is a keyboard. Also, I'm having trouble designing the packet structure from this report just for the digitizer. I haven't quite wrapped my mind around how it works. Do you have any recommendations? This has been a great practice to learn in depth how all this works. Your feedback has been great and really appreciate it.
My attempt to start a packet structure.
typedef PACKED_STRUCT
uint8_t report_id:
uint8_t tip_switch : 1;
uint8_t range : 1; // Not sure if this is right
uint16_t x;
uint16_t y;
???? width; // Not sure if this is needed
???? height; // Not sure if this is needed
} digitizer_report_t;
Packet 1: 050D 0901 A101 8501 0922 A102 0942 1500 2501 7501 9501
Packet 2: 8102 0932 8102 9506 8103 0501 26E8 0375 1095 0155 0065
Packet 3: 0009 3035 0046 E803 8102 0931 46E8 0381 02C0 050D 0948
Packet 4: 0949 9502 8102 C005 0C09 01A1 0185 0209 E909 EA09 E209
Packet 5: B509 B60A 2402 09CD 0930 0A23 0209 4015 0125 0C75 1095
Packet 6: 0181 00C0 0501 0906 A101 8503 0507 19E0 29E7 1500 2501
Packet 7: 7501 9508 8102 7508 9501 1500 25F4 0507 1900 29F4 8100
Packet 8: C0
0x05, 0x0D, // USAGE_PAGE (Digitizer) 0x09, 0x01, // USAGE (Digitizer) 0xA1, 0x01, // Collection (Application) 0x85, 0x01, // REPORT_ID 1 0x09, 0x22, // USAGE (Finger) 0xA1, 0x02, // Collection (Logical) 0x09, 0x42, // USAGE (Tip Switch) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0x01, // LOGICAL_MAXIMUM (1) 0x75, 0x01, // REPORT_SIZE (1) 0x95, 0x01, // REPORT_COUNT (1) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x09, 0x32, // USAGE (In Range) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x95, 0x06, // REPORT_COUNT (6) 0x81, 0x03, // INPUT (Cnst,Ary,Abs) 0x05, 0x01, // USAGE_PAGE (Generic Desktop) 0x26, 0xE8, 0x03, // LOGICAL_MAXIMUM (0x03E8 = 1000) 0x75, 0x10, // REPORT_SIZE (16) 0x95, 0x01, // REPORT_COUNT (1) 0x55, 0x00, // UNIT_EXPONENT (0) 0x65, 0x00, // UNIT(Inch, EngLinear) 0x09, 0x30, // USAGE (X) 0x35, 0x00, // PHYSICAL_MINIMUM (0) 0x46, 0xE8, 0x03, // PHYSICAL_MAXIMUM (0x03E8 = 1000) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x09, 0x31, // USAGE (Y) 0x46, 0xE8, 0x03, // PHYSICAL_MAXIMUM (0x03E8 = 1000) 0x81, 0x02, // INPUT (Data,Var,Abs) 0xC0, // END_COLLECTION 0x05, 0x0D, // USAGE_PAGE (Digitizer) 0x09, 0x48, // USAGE (Width) 0x09, 0x49, // USAGE (Height) 0x95, 0x02, // REPORT_COUNT (2) 0x81, 0x02, // INPUT (Data,Var,Abs) 0xC0, // END_COLLECTION 0x05, 0x0C, // USAGE_PAGE (Consumer Devices) 0x09, 0x01, // USAGE_(Consumer Control) 0xA1, 0x01, // COLLECTION (Application) 0x85, 0x02, // REPORT_ID 2 0x09, 0xE9, // USAGE (Volume Increment) 0x09, 0xEA, // USAGE (Volume Decrement) 0x09, 0xE2, // USAGE (Mute) 0x09, 0xB5, // USAGE (Scan Next Track) 0x09, 0xB6, // USAGE (Scan Previous Track) 0x0A, 0x24, 0x02, // USAGE (WWW Back) 0x09, 0xCD, // USAGE (Play/Pause) 0x09, 0x30, // USAGE (Power) 0x0A, 0x23, 0x02, // USAGE (WWW Home) 0x09, 0x40, // USAGE (Menu) 0x15, 0x01, // LOGICAL_MINIMUM (1) 0x25, 0x0C, // LOGICAL_MAXIMUM (12) 0x75, 0x10, // REPORT_SIZE (16) 0x95, 0x01, // REPORT_COUNT (1) 0x81, 0x00, // INPUT (Data,Ary,Abs) 0xC0, // END_COLLECTION 0x05, 0x01, // USAGE_PAGE (Generic Desktop) 0x09, 0x06, // USAGE (Keyboard) 0xA1, 0x01, // Collection (Application) 0x85, 0x03, // REPORT_ID 3 0x05, 0x07, // USAGE_PAGE (Keyboard) 0x19, 0xE0, // USAGE_MINIMUM (Keyboard LeftControl) 0x29, 0xE7, // USAGE_MAXIMUM (Keyboard Right GUI) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0x01, // LOGICAL_MAXIMUM (1) 0x75, 0x01, // REPORT_SIZE (1) 0x95, 0x08, // REPORT_COUNT (8) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x75, 0x08, // REPORT_SIZE (8) 0x95, 0x01, // REPORT_COUNT (1) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0xF4, // LOGICAL_MAXIMUM (244) 0x05, 0x07, // USAGE_PAGE (Keyboard) 0x19, 0x00, // USAGE_MINIMUM (Reserved (no event indicated)) 0x29, 0xF4, // USAGE_MAXIMUM (????) 0x81, 0x00, // INPUT (Data,Ary,Abs) 0xC0 // END_COLLECTION ## UP Button Values ## Packet 1: 07F4 0120 038E 038E 03 Packet 2: 07F4 0102 038E 038E 03 Packet 3: 07F4 01E4 028E 038E 03 Packet 4: 07F4 01C6 028E 038E 03 Packet 5: 07F4 01A8 028E 038E 03 Packet 6: 07F4 018A 028E 038E 03 Packet 7: 07F4 016C 028E 038E 03 Packet 8: 07F4 014E 028E 038E 03 Packet 9: 07F4 0130 028E 038E 03 Packet 10: 07F4 0112 028E 038E 03 Packet 11: 07F4 01F4 018E 038E 03 Packet 12: 07F4 01D6 018E 038E 03 Packet 13: 07F4 01B8 018E 038E 03 Packet 14: 07F4 019A 018E 038E 03 Packet 15: 07F4 017C 018E 038E 03 Packet 16: 07F4 015E 018E 038E 03 Packet 17: 07F4 0140 018E 038E 03 Packet 18: 00F4 0140 018E 038E 03 ## Down Button Values ## Packet 1: 07F4 012C 018E 038E 03 Packet 2: 07F4 014A 018E 038E 03 Packet 3: 07F4 0168 018E 038E 03 Packet 4: 07F4 0186 018E 038E 03 Packet 5: 07F4 01A4 018E 038E 03 Packet 6: 07F4 01C2 018E 038E 03 Packet 7: 07F4 01E0 018E 038E 03 Packet 8: 07F4 01FE 018E 038E 03 Packet 9: 07F4 011C 028E 038E 03 Packet 10: 07F4 013A 028E 038E 03 Packet 11: 07F4 0158 028E 038E 03 Packet 12: 07F4 0176 028E 038E 03 Packet 13: 07F4 0194 028E 038E 03 Packet 14: 07F4 01B2 028E 038E 03 Packet 15: 07F4 01D0 028E 038E 03 Packet 16: 07F4 01EE 028E 038E 03 Packet 17: 07F4 010C 038E 038E 03 Packet 18: 00F4 010C 038E 038E 03 ## Left Button Values ## Packet 1: 0720 032C 018E 038E 03 Packet 2: 07BC 022C 018E 038E 03 Packet 3: 0758 022C 018E 038E 03 Packet 4: 07F4 012C 018E 038E 03 Packet 5: 0790 012C 018E 038E 03 Packet 6: 072C 012C 018E 038E 03 Packet 7: 002C 012C 018E 038E 03 Packet 8: 002C 012C 018E 038E 03 ## Right Button Values ## Packet 1: 07C8 002C 018E 038E 03 Packet 2: 072C 012C 018E 038E 03 Packet 3: 0790 012C 018E 038E 03 Packet 4: 07F4 012C 018E 038E 03 Packet 5: 0758 022C 018E 038E 03 Packet 6: 07BC 022C 018E 038E 03 Packet 7: 00BC 022C 018E 038E 03 Packet 8: 002C 012C 018E 038E 03
Trying to learn fast on how to read the descriptor file and figure out the packet layout or just the number of bytes. As mentioned before I was able to capture the packet logs for a finger up swipe. Below is just one example of that and I'm trying to figure out how it maps into the packet. I'm seeing a count of 9 bytes in the data packet but don't see how to map that back to the descriptor. Have had no luck finding a good tutorial on this.
I have started to use the keyboard example project and merge the digitizer report with it. It seem that there have been many people ask for help around merging keyboard and mouse or keyboard and digitizer but with no luck or they just didn't share their success with the community. Seems to be a pretty confusing topic. Is there any working examples that you know of? I have taken what I can find and attempted to present both reports to the iPhone and at least have keyboard continue to work. So far I think it's working with the new report descriptors added and the digitizer service initialized because the keyboard functionality is still working. I just need to figure out how the digitizer packet looks and how to send the data.
Thanks for your help or advice. I will continue to contribute to this thread so if I get it working I will post the working code so other may benefit from this.
## Packet Data Captured ##
Value: 07F4 0120 038E 038E 03
Length: 0x000C (12) [ 1B 27 00 07 F4 01 20 03 8E 03 8E 03 ] RECV
byte[0] = 0x01 Report ID
byte[1] = Contains bit fields for various input
bit 0 = Tip switch
bit 1 = In range indicator
bit 2 = Not Used
bit 3 = Not Used
bit 4 = Not Used
bit 5 = Not Used
bit 6 = Not Used
bit 7 = Not Used
byte[2] = X Coordinate MSB
byte[3] = X Coordinate LSB
byte[4] = Y Coordinate MSB
byte[5] = Y Coordinate LSB
* Copyright (c) 2012 - 2019, Nordic Semiconductor ASA
* All rights reserved.
/** @file
* @defgroup ble_sdk_app_hids_keyboard_main main.c
* @ingroup ble_sdk_app_hids_keyboard
* @brief HID Keyboard Sample Application main file.
* This file contains is the source code for a sample application using the HID, Battery and Device
* Information Services for implementing a simple keyboard functionality.
* Pressing Button 0 will send text 'hello' to the connected peer. On receiving output report,
* it toggles the state of LED 2 on the mother board based on whether or not Caps Lock is on.
* This application uses the @ref app_scheduler.
* Also it would accept pairing requests from any peer device.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_assert.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advertising.h"
#include "ble_advdata.h"
#include "ble_hids.h"
#include "ble_bas.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "bsp_btn_ble.h"
#include "app_scheduler.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "peer_manager_handler.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SHIFT_BUTTON_ID 1 /**< Button used as 'SHIFT' Key. */
#define DEVICE_NAME "Nordic_Keyboard" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(2000) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL 81 /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL 100 /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT 1 /**< Increment between each simulated battery level measurement. */
#define PNP_ID_VENDOR_ID_SOURCE 0x02 /**< Vendor ID Source. */
#define PNP_ID_VENDOR_ID 0x1915 /**< Vendor ID. */
#define PNP_ID_PRODUCT_ID 0xEEEE /**< Product ID. */
#define PNP_ID_PRODUCT_VERSION 0x0001 /**< Product Version. */
#define APP_ADV_FAST_INTERVAL 0x0028 /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
#define APP_ADV_SLOW_INTERVAL 0x0C80 /**< Slow advertising interval (in units of 0.625 ms. This value corrsponds to 2 seconds). */
#define APP_ADV_FAST_DURATION 3000 /**< The advertising duration of fast advertising in units of 10 milliseconds. */
#define APP_ADV_SLOW_DURATION 18000 /**< The advertising duration of slow advertising in units of 10 milliseconds. */
/*lint -emacro(524, MIN_CONN_INTERVAL) // Loss of precision */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Minimum connection interval (7.5 ms) */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Maximum connection interval (30 ms). */
#define SLAVE_LATENCY 6 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(430, UNIT_10_MS) /**< Connection supervisory timeout (430 ms). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define ENABLE_DIGITIZER
#ifdef ENABLE_DIGITIZER
#define INPUT_REPORT_COUNT 2 /**< Number of input reports in this application. */
#define INPUT_REP_REF_DIGITIZER_ID 2
#define INPUT_REPORT_DIG_MAX_LEN 1
#define INPUT_REPORT_DIG_INDEX 1 /**< Index of Input Report. */
#else
#define INPUT_REPORT_COUNT 1 /**< Number of input reports in this application. */
#define OUTPUT_REPORT_INDEX 0 /**< Index of Output Report. */
#define OUTPUT_REPORT_MAX_LEN 1 /**< Maximum length of Output Report. */
#define INPUT_REPORT_KEYS_INDEX 0 /**< Index of Input Report. */
#define OUTPUT_REPORT_BIT_MASK_CAPS_LOCK 0x02 /**< CAPS LOCK bit in Output Report (based on 'LED Page (0x08)' of the Universal Serial Bus HID Usage Tables). */
#define INPUT_REP_REF_KEYBOARD_ID 1 /**< Id of reference to Keyboard Input Report. */
#define OUTPUT_REP_REF_ID 0 /**< Id of reference to Keyboard Output Report. */
#define FEATURE_REP_REF_ID 0 /**< ID of reference to Keyboard Feature Report. */
#define FEATURE_REPORT_MAX_LEN 2 /**< Maximum length of Feature Report. */
#define FEATURE_REPORT_INDEX 0 /**< Index of Feature Report. */
#define MAX_BUFFER_ENTRIES 5 /**< Number of elements that can be enqueued */
#define BASE_USB_HID_SPEC_VERSION 0x0101 /**< Version number of base USB HID Specification implemented by this application. */
#define INPUT_REPORT_KEYS_MAX_LEN 8 /**< Maximum length of the Input Report characteristic. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define SCHED_MAX_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE 20 /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE 10 /**< Maximum number of events in the scheduler queue. */
#define MODIFIER_KEY_POS 0 /**< Position of the modifier byte in the Input Report. */
#define SCAN_CODE_POS 2 /**< The start position of the key scan code in a HID Report. */
#define SHIFT_KEY_CODE 0x02 /**< Key code indicating the press of the Shift Key. */
#define MAX_KEYS_IN_ONE_REPORT (INPUT_REPORT_KEYS_MAX_LEN - SCAN_CODE_POS)/**< Maximum number of key presses that can be sent in one Input Report. */
/**Buffer queue access macros
/** Initialization of buffer list */
#define BUFFER_LIST_INIT() \
do \
buffer_list.rp = 0; \
buffer_list.wp = 0; \
buffer_list.count = 0; \
} while (0)
/** Provide status of data list is full or not */
#define BUFFER_LIST_FULL() \
((MAX_BUFFER_ENTRIES == buffer_list.count - 1) ? true : false)
/** Provides status of buffer list is empty or not */
#define BUFFER_LIST_EMPTY() \
((0 == buffer_list.count) ? true : false)
#define BUFFER_ELEMENT_INIT(i) \
do \
buffer_list.buffer[(i)].p_data = NULL; \
} while (0)
/** Abstracts buffer element */
typedef struct hid_key_buffer
uint8_t data_offset; /**< Max Data that can be buffered for all entries */
uint8_t data_len; /**< Total length of data */
uint8_t * p_data; /**< Scanned key pattern */
ble_hids_t * p_instance; /**< Identifies peer and service instance */
} buffer_entry_t;
STATIC_ASSERT(sizeof(buffer_entry_t) % 4 == 0);
/** Circular buffer list */
typedef struct
buffer_entry_t buffer[MAX_BUFFER_ENTRIES]; /**< Maximum number of entries that can enqueued in the list */
uint8_t rp; /**< Index to the read location */
uint8_t wp; /**< Index to write location */
uint8_t count; /**< Number of elements in the list */
} buffer_list_t;
STATIC_ASSERT(sizeof(buffer_list_t) % 4 == 0);
APP_TIMER_DEF(m_battery_timer_id); /**< Battery timer. */
BLE_HIDS_DEF(m_hids, /**< Structure used to identify the HID service. */
NRF_SDH_BLE_TOTAL_LINK_COUNT,
INPUT_REPORT_KEYS_MAX_LEN,
INPUT_REPORT_DIG_MAX_LEN,
OUTPUT_REPORT_MAX_LEN,
FEATURE_REPORT_MAX_LEN);
BLE_BAS_DEF(m_bas); /**< Structure used to identify the battery service. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static bool m_in_boot_mode = false; /**< Current protocol mode. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static sensorsim_cfg_t m_battery_sim_cfg; /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state; /**< Battery Level sensor simulator state. */
static bool m_caps_on = false; /**< Variable to indicate if Caps Lock is turned on. */
static pm_peer_id_t m_peer_id; /**< Device reference handle to the current bonded central. */
static buffer_list_t buffer_list; /**< List to enqueue not just data to be sent, but also related information like the handle, connection handle etc */
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_HUMAN_INTERFACE_DEVICE_SERVICE, BLE_UUID_TYPE_BLE}};
static uint8_t m_sample_key_press_scan_str[] = /**< Key pattern to be sent when the key press button has been pushed. */
0x0b, /* Key h */
0x08, /* Key e */
0x0f, /* Key l */
0x0f, /* Key l */
0x12, /* Key o */
0x28 /* Key Return */
static uint8_t m_caps_on_key_scan_str[] = /**< Key pattern to be sent when the output report has been written with the CAPS LOCK bit set. */
0x06, /* Key C */
0x04, /* Key a */
0x13, /* Key p */
0x16, /* Key s */
0x12, /* Key o */
0x11, /* Key n */
static uint8_t m_caps_off_key_scan_str[] = /**< Key pattern to be sent when the output report has been written with the CAPS LOCK bit cleared. */
0x06, /* Key C */
0x04, /* Key a */
0x13, /* Key p */
0x16, /* Key s */
0x12, /* Key o */
0x09, /* Key f */
static void on_hids_evt(ble_hids_t * p_hids, ble_hids_evt_t * p_evt);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for setting filtered whitelist.
* @param[in] skip Filter passed to @ref pm_peer_id_list.
static void whitelist_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
uint32_t peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
peer_id_count + 1,
BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
err_code = pm_whitelist_set(peer_ids, peer_id_count);
/**@brief Function for setting filtered device identities.
static void identities_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
uint32_t peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
static void advertising_start(bool erase_bonds)
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
APP_ERROR_CHECK(ret);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
advertising_start(false);
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
if ( p_evt->params.peer_data_update_succeeded.flash_changed
&& (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
// Note: You should check on what kind of white list policy your application should use.
/**@brief Function for handling Service errors.
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
static void service_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling advertising errors.
static void ble_advertising_error_handler(uint32_t nrf_error)
/**@brief Function for performing a battery measurement, and update the Battery Level characteristic in the Battery Service.
static void battery_level_update(void)
uint8_t battery_level;
battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != NRF_ERROR_FORBIDDEN) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
battery_level_update();
/**@brief Function for the Timer initialization.
* @details Initializes the timer module.
static void timers_init(void)
err_code = app_timer_init();
// Create battery timer.
err_code = app_timer_create(&m_battery_timer_id,
APP_TIMER_MODE_REPEATED,
battery_level_meas_timeout_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HID_KEYBOARD);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for initializing the Queued Write Module.
static void qwr_init(void)
nrf_ble_qwr_init_t qwr_init_obj = {0};
qwr_init_obj.error_handler = nrf_qwr_error_handler;
err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
/**@brief Function for initializing Device Information Service.
static void dis_init(void)
ble_dis_init_t dis_init_obj;
ble_dis_pnp_id_t pnp_id;
pnp_id.vendor_id_source = PNP_ID_VENDOR_ID_SOURCE;
pnp_id.vendor_id = PNP_ID_VENDOR_ID;
pnp_id.product_id = PNP_ID_PRODUCT_ID;
pnp_id.product_version = PNP_ID_PRODUCT_VERSION;
memset(&dis_init_obj, 0, sizeof(dis_init_obj));
ble_srv_ascii_to_utf8(&dis_init_obj.manufact_name_str, MANUFACTURER_NAME);
dis_init_obj.p_pnp_id = &pnp_id;
dis_init_obj.dis_char_rd_sec = SEC_JUST_WORKS;
err_code = ble_dis_init(&dis_init_obj);
/**@brief Function for initializing Battery Service.
static void bas_init(void)
ble_bas_init_t bas_init_obj;
memset(&bas_init_obj, 0, sizeof(bas_init_obj));
bas_init_obj.evt_handler = NULL;
bas_init_obj.support_notification = true;
bas_init_obj.p_report_ref = NULL;
bas_init_obj.initial_batt_level = 100;
bas_init_obj.bl_rd_sec = SEC_JUST_WORKS;
bas_init_obj.bl_cccd_wr_sec = SEC_JUST_WORKS;
bas_init_obj.bl_report_rd_sec = SEC_JUST_WORKS;
err_code = ble_bas_init(&m_bas, &bas_init_obj);
/**@brief Function for initializing HID Service.
static void hids_init(void)
ble_hids_init_t hids_init_obj;
ble_hids_inp_rep_init_t * p_input_report;
ble_hids_outp_rep_init_t * p_output_report;
ble_hids_feature_rep_init_t * p_feature_report;
uint8_t hid_info_flags;
static ble_hids_inp_rep_init_t input_report_array[INPUT_REPORT_COUNT];
static ble_hids_outp_rep_init_t output_report_array[1];
static ble_hids_feature_rep_init_t feature_report_array[1];
static uint8_t report_map_data[] =
0x05, 0x01, // Usage Page (Generic Desktop)
0x09, 0x06, // Usage (Keyboard)
0x85, 0x01, // Report ID 1
0x05, 0x07, // Usage Page (Key Codes)
0x19, 0xe0, // Usage Minimum (224)
0x29, 0xe7, // Usage Maximum (231)
0x15, 0x00, // Logical Minimum (0)
0x25, 0x01, // Logical Maximum (1)
0x75, 0x01, // Report Size (1)
0x95, 0x08, // Report Count (8)
0x81, 0x02, // Input (Data, Variable, Absolute)
0x95, 0x01, // Report Count (1)
0x75, 0x08, // Report Size (8)
0x81, 0x01, // Input (Constant) reserved byte(1)
0x95, 0x05, // Report Count (5)
0x05, 0x08, // Usage Page (Page# for LEDs)
0x19, 0x01, // Usage Minimum (1)
0x29, 0x05, // Usage Maximum (5)
0x91, 0x02, // Output (Data, Variable, Absolute), Led report
0x75, 0x03, // Report Size (3)
0x91, 0x01, // Output (Data, Variable, Absolute), Led report padding
0x95, 0x06, // Report Count (6)
0x25, 0x65, // Logical Maximum (101)
0x05, 0x07, // Usage Page (Key codes)
0x19, 0x00, // Usage Minimum (0)
0x29, 0x65, // Usage Maximum (101)
0x81, 0x00, // Input (Data, Array) Key array(6 bytes)
0x09, 0x05, // Usage (Vendor Defined)
0x26, 0xFF, 0x00, // Logical Maximum (255)
0x75, 0x08, // Report Size (8 bit)
0x95, 0x02, // Report Count (2)
0xB1, 0x02, // Feature (Data, Variable, Absolute)
0xC0, // End Collection (Application)
memset((void *)input_report_array, 0, sizeof(ble_hids_inp_rep_init_t));
memset((void *)output_report_array, 0, sizeof(ble_hids_outp_rep_init_t));
memset((void *)feature_report_array, 0, sizeof(ble_hids_feature_rep_init_t));
// Initialize Keyboard HID Service
p_input_report = &input_report_array[INPUT_REPORT_KEYS_INDEX];
p_input_report->max_len = INPUT_REPORT_KEYS_MAX_LEN;
p_input_report->rep_ref.report_id = INPUT_REP_REF_KEYBOARD_ID;
p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
p_input_report->sec.cccd_wr = SEC_JUST_WORKS;
p_input_report->sec.wr = SEC_JUST_WORKS;
p_input_report->sec.rd = SEC_JUST_WORKS;
p_output_report = &output_report_array[OUTPUT_REPORT_INDEX];
p_output_report->max_len = OUTPUT_REPORT_MAX_LEN;
p_output_report->rep_ref.report_id = OUTPUT_REP_REF_ID;
p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
p_output_report->sec.wr = SEC_JUST_WORKS;
p_output_report->sec.rd = SEC_JUST_WORKS;
p_feature_report = &feature_report_array[FEATURE_REPORT_INDEX];
p_feature_report->max_len = FEATURE_REPORT_MAX_LEN;
p_feature_report->rep_ref.report_id = FEATURE_REP_REF_ID;
p_feature_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_FEATURE;
p_feature_report->sec.rd = SEC_JUST_WORKS;
p_feature_report->sec.wr = SEC_JUST_WORKS;
// Initialize Digitizer HID Service
p_input_report = &input_report_array[INPUT_REPORT_DIG_INDEX];
p_input_report->max_len = INPUT_REPORT_DIG_MAX_LEN;
p_input_report->rep_ref.report_id = INPUT_REP_REF_DIGITIZER_ID;
hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
memset(&hids_init_obj, 0, sizeof(hids_init_obj));
hids_init_obj.evt_handler = on_hids_evt;
hids_init_obj.error_handler = service_error_handler;
hids_init_obj.is_kb = true;
hids_init_obj.is_mouse = false;
hids_init_obj.inp_rep_count = INPUT_REPORT_COUNT;
hids_init_obj.p_inp_rep_array = input_report_array;
hids_init_obj.outp_rep_count = 1;
hids_init_obj.p_outp_rep_array = output_report_array;
hids_init_obj.feature_rep_count = 1;
hids_init_obj.p_feature_rep_array = feature_report_array;
hids_init_obj.rep_map.data_len = sizeof(report_map_data);
hids_init_obj.rep_map.p_data = report_map_data;
hids_init_obj.hid_information.bcd_hid = BASE_USB_HID_SPEC_VERSION;
hids_init_obj.hid_information.b_country_code = 0;
hids_init_obj.hid_information.flags = hid_info_flags;
hids_init_obj.included_services_count = 0;
hids_init_obj.p_included_services_array = NULL;
hids_init_obj.rep_map.rd_sec = SEC_JUST_WORKS;
hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
hids_init_obj.boot_kb_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
hids_init_obj.boot_kb_inp_rep_sec.rd = SEC_JUST_WORKS;
hids_init_obj.boot_kb_outp_rep_sec.rd = SEC_JUST_WORKS;
hids_init_obj.boot_kb_outp_rep_sec.wr = SEC_JUST_WORKS;
hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
hids_init_obj.ctrl_point_wr_sec = SEC_JUST_WORKS;
err_code = ble_hids_init(&m_hids, &hids_init_obj);
qwr_init();
dis_init();
bas_init();
hids_init();
/**@brief Function for initializing the battery sensor simulator.
static void sensor_simulator_init(void)
m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
m_battery_sim_cfg.start_at_max = true;
sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = NULL;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting timers.
static void timers_start(void)
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
/**@brief Function for transmitting a key scan Press & Release Notification.
* @warning This handler is an example only. You need to analyze how you wish to send the key
* release.
* @param[in] p_instance Identifies the service for which Key Notifications are requested.
* @param[in] p_key_pattern Pointer to key pattern.
* @param[in] pattern_len Length of key pattern. 0 < pattern_len < 7.
* @param[in] pattern_offset Offset applied to Key Pattern for transmission.
* @param[out] actual_len Provides actual length of Key Pattern transmitted, making buffering of
* rest possible if needed.
* @return NRF_SUCCESS on success, NRF_ERROR_RESOURCES in case transmission could not be
* completed due to lack of transmission buffer or other error codes indicating reason
* for failure.
* @note In case of NRF_ERROR_RESOURCES, remaining pattern that could not be transmitted
* can be enqueued \ref buffer_enqueue function.
* In case a pattern of 'cofFEe' is the p_key_pattern, with pattern_len as 6 and
* pattern_offset as 0, the notifications as observed on the peer side would be
* 1> 'c', 'o', 'f', 'F', 'E', 'e'
* 2> - , 'o', 'f', 'F', 'E', 'e'
* 3> - , -, 'f', 'F', 'E', 'e'
* 4> - , -, -, 'F', 'E', 'e'
* 5> - , -, -, -, 'E', 'e'
* 6> - , -, -, -, -, 'e'
* 7> - , -, -, -, -, -
* Here, '-' refers to release, 'c' refers to the key character being transmitted.
* Therefore 7 notifications will be sent.
* In case an offset of 4 was provided, the pattern notifications sent will be from 5-7
* will be transmitted.
static uint32_t send_key_scan_press_release(ble_hids_t * p_hids,
uint8_t * p_key_pattern,
uint16_t pattern_len,
uint16_t pattern_offset,
uint16_t * p_actual_len)
uint16_t offset;
uint16_t data_len;
uint8_t data[INPUT_REPORT_KEYS_MAX_LEN];
// HID Report Descriptor enumerates an array of size 6, the pattern hence shall not be any
// longer than this.
STATIC_ASSERT((INPUT_REPORT_KEYS_MAX_LEN - 2) == 6);
ASSERT(pattern_len <= (INPUT_REPORT_KEYS_MAX_LEN - 2));
offset = pattern_offset;
data_len = pattern_len;
do
// Reset the data buffer.
memset(data, 0, sizeof(data));
// Copy the scan code.
memcpy(data + SCAN_CODE_POS + offset, p_key_pattern + offset, data_len - offset);
if (bsp_button_is_pressed(SHIFT_BUTTON_ID))
data[MODIFIER_KEY_POS] |= SHIFT_KEY_CODE;
if (!m_in_boot_mode)
err_code = ble_hids_inp_rep_send(p_hids,
INPUT_REPORT_KEYS_INDEX,
data,
m_conn_handle);
err_code = ble_hids_boot_kb_inp_rep_send(p_hids,
data,
m_conn_handle);
if (err_code != NRF_SUCCESS)
offset++;
while (offset <= data_len);
*p_actual_len = offset;
return err_code;
/**@brief Function for initializing the buffer queue used to key events that could not be
* transmitted
* @warning This handler is an example only. You need to analyze how you wish to buffer or buffer at
* all.
* @note In case of HID keyboard, a temporary buffering could be employed to handle scenarios
* where encryption is not yet enabled or there was a momentary link loss or there were no
* Transmit buffers.
static void buffer_init(void)
uint32_t buffer_count;
BUFFER_LIST_INIT();
for (buffer_count = 0; buffer_count < MAX_BUFFER_ENTRIES; buffer_count++)
BUFFER_ELEMENT_INIT(buffer_count);
/**@brief Function for enqueuing key scan patterns that could not be transmitted either completely
* or partially.
* release.
* @param[in] p_hids Identifies the service for which Key Notifications are buffered.
* @param[in] offset Offset applied to Key Pattern when requesting a transmission on
* dequeue, @ref buffer_dequeue.
* @return NRF_SUCCESS on success, else an error code indicating reason for failure.
static uint32_t buffer_enqueue(ble_hids_t * p_hids,
uint16_t offset)
buffer_entry_t * element;
uint32_t err_code = NRF_SUCCESS;
if (BUFFER_LIST_FULL())
// Element cannot be buffered.
err_code = NRF_ERROR_NO_MEM;
// Make entry of buffer element and copy data.
element = &buffer_list.buffer[(buffer_list.wp)];
element->p_instance = p_hids;
element->p_data = p_key_pattern;
element->data_offset = offset;
element->data_len = pattern_len;
buffer_list.count++;
buffer_list.wp++;
if (buffer_list.wp == MAX_BUFFER_ENTRIES)
buffer_list.wp = 0;
return err_code;
/**@brief Function to dequeue key scan patterns that could not be transmitted either completely of
* partially.
* release.
* @param[in] tx_flag Indicative of whether the dequeue should result in transmission or not.
* @note A typical example when all keys are dequeued with transmission is when link is
* disconnected.
static uint32_t buffer_dequeue(bool tx_flag)
buffer_entry_t * p_element;
uint16_t actual_len;
if (BUFFER_LIST_EMPTY())
err_code = NRF_ERROR_NOT_FOUND;
bool remove_element = true;
p_element = &buffer_list.buffer[(buffer_list.rp)];
if (tx_flag)
err_code = send_key_scan_press_release(p_element->p_instance,
p_element->p_data,
p_element->data_len,
p_element->data_offset,
&actual_len);
// An additional notification is needed for release of all keys, therefore check
// is for actual_len <= element->data_len and not actual_len < element->data_len
if ((err_code == NRF_ERROR_RESOURCES) && (actual_len <= p_element->data_len))
// Transmission could not be completed, do not remove the entry, adjust next data to
// be transmitted
p_element->data_offset = actual_len;
remove_element = false;
if (remove_element)
BUFFER_ELEMENT_INIT(buffer_list.rp);
buffer_list.rp++;
buffer_list.count--;
if (buffer_list.rp == MAX_BUFFER_ENTRIES)
buffer_list.rp = 0;
return err_code;
/**@brief Function for sending sample key presses to the peer.
* @param[in] key_pattern_len Pattern length.
* @param[in] p_key_pattern Pattern to be sent.
static void keys_send(uint8_t key_pattern_len, uint8_t * p_key_pattern)
err_code = send_key_scan_press_release(&m_hids,
p_key_pattern,
key_pattern_len,
0,
&actual_len);
// is for actual_len <= key_pattern_len and not actual_len < key_pattern_len.
if ((err_code == NRF_ERROR_RESOURCES) && (actual_len <= key_pattern_len))
// Buffer enqueue routine return value is not intentionally checked.
// Rationale: Its better to have a a few keys missing than have a system
// reset. Recommendation is to work out most optimal value for
// MAX_BUFFER_ENTRIES to minimize chances of buffer queue full condition
UNUSED_VARIABLE(buffer_enqueue(&m_hids, p_key_pattern, key_pattern_len, actual_len));
/**@brief Function for handling the HID Report Characteristic Write event.
* @param[in] p_evt HID service event.
static void on_hid_rep_char_write(ble_hids_evt_t * p_evt)
if (p_evt->params.char_write.char_id.rep_type == BLE_HIDS_REP_TYPE_OUTPUT)
uint8_t report_val;
uint8_t report_index = p_evt->params.char_write.char_id.rep_index;
if (report_index == OUTPUT_REPORT_INDEX)
// This code assumes that the output report is one byte long. Hence the following
// static assert is made.
STATIC_ASSERT(OUTPUT_REPORT_MAX_LEN == 1);
err_code = ble_hids_outp_rep_get(&m_hids,
report_index,
0,
m_conn_handle,
&report_val);
if (!m_caps_on && ((report_val & OUTPUT_REPORT_BIT_MASK_CAPS_LOCK) != 0))
// Caps Lock is turned On.
NRF_LOG_INFO("Caps Lock is turned On!");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
keys_send(sizeof(m_caps_on_key_scan_str), m_caps_on_key_scan_str);
m_caps_on = true;
else if (m_caps_on && ((report_val & OUTPUT_REPORT_BIT_MASK_CAPS_LOCK) == 0))
// Caps Lock is turned Off .
NRF_LOG_INFO("Caps Lock is turned Off!");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
keys_send(sizeof(m_caps_off_key_scan_str), m_caps_off_key_scan_str);
m_caps_on = false;
// The report received is not supported by this application. Do nothing.
// Prepare wakeup buttons.
/**@brief Function for handling HID events.
* @details This function will be called for all HID events which are passed to the application.
* @param[in] p_hids HID service structure.
* @param[in] p_evt Event received from the HID service.
switch (p_evt->evt_type)
case BLE_HIDS_EVT_BOOT_MODE_ENTERED:
m_in_boot_mode = true;
case BLE_HIDS_EVT_REPORT_MODE_ENTERED:
case BLE_HIDS_EVT_REP_CHAR_WRITE:
on_hid_rep_char_write(p_evt);
case BLE_HIDS_EVT_NOTIF_ENABLED:
// No implementation needed.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
NRF_LOG_INFO("High Duty Directed advertising.");
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
case BLE_ADV_EVT_DIRECTED:
NRF_LOG_INFO("Directed advertising.");
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_SLOW:
NRF_LOG_INFO("Slow advertising.");
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
case BLE_ADV_EVT_FAST_WHITELIST:
NRF_LOG_INFO("Fast advertising with whitelist.");
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
case BLE_ADV_EVT_SLOW_WHITELIST:
NRF_LOG_INFO("Slow advertising with whitelist.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
case BLE_ADV_EVT_WHITELIST_REQUEST:
ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
ble_gap_irk_t whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
uint32_t addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
uint32_t irk_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
whitelist_irks, &irk_cnt);
NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
addr_cnt, irk_cnt);
// Set the correct identities list (no excluding peers with no Central Address Resolution).
identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
// Apply the whitelist.
err_code = ble_advertising_whitelist_reply(&m_advertising,
whitelist_addrs,
addr_cnt,
whitelist_irks,
irk_cnt);
} break; //BLE_ADV_EVT_WHITELIST_REQUEST
case BLE_ADV_EVT_PEER_ADDR_REQUEST:
pm_peer_data_bonding_t peer_bonding_data;
// Only Give peer address if we have a handle to the bonded peer.
if (m_peer_id != PM_PEER_ID_INVALID)
err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
if (err_code != NRF_ERROR_NOT_FOUND)
// Manipulate identities to exclude peers with no Central Address Resolution.
identities_set(PM_PEER_ID_LIST_SKIP_ALL);
ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
} break; //BLE_ADV_EVT_PEER_ADDR_REQUEST
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
// Dequeue all keys without transmission.
(void) buffer_dequeue(false);
// Reset m_caps_on variable. Upon reconnect, the HID host will re-send the Output
// report containing the Caps lock state.
m_caps_on = false;
// disabling alert 3. signal - used for capslock ON
break; // BLE_GAP_EVT_DISCONNECTED
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTS_EVT_HVN_TX_COMPLETE:
// Send next key event
(void) buffer_dequeue(true);
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for the Event Scheduler initialization.
static void scheduler_init(void)
APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
* @param[in] event Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
uint32_t err_code;
static uint8_t * p_key = m_sample_key_press_scan_str;
static uint8_t size = 0;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle,
case BSP_EVENT_WHITELIST_OFF:
case BSP_EVENT_KEY_0:
if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
keys_send(1, p_key);
p_key++;
size++;
if (size == MAX_KEYS_IN_ONE_REPORT)
size = 0;
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
uint32_t err_code;
uint8_t adv_flags;
ble_advertising_init_t init;
adv_flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = adv_flags;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_whitelist_enabled = true;
init.config.ble_adv_directed_high_duty_enabled = true;
init.config.ble_adv_directed_enabled = false;
init.config.ble_adv_directed_interval = 0;
init.config.ble_adv_directed_timeout = 0;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
init.config.ble_adv_fast_timeout = APP_ADV_FAST_DURATION;
init.config.ble_adv_slow_enabled = true;
init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
init.config.ble_adv_slow_timeout = APP_ADV_SLOW_DURATION;
init.error_handler = ble_advertising_error_handler;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
app_sched_execute();
nrf_pwr_mgmt_run();
/**@brief Function for application main entry
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
scheduler_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
buffer_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("HID Keyboard example started.");
timers_start();
advertising_start(erase_bonds);
// Enter main loop.
for (;;)
idle_state_handle();
Hi Matthew
Sorry for the slow response, I have been out in travel for the last couple of days.
Are you able to send me the current state of your code so I can try it out on my end?
Then I will block off some time tomorrow to try and dig into this.
Best regards
Torbjørn
Hi Ovrebekk,
No worries, I have been working hard figuring a few things out. I started pulling bluetooth packet logs off my iPhone and noticed that the report descriptor is different from the report pulled from my laptop. So once again I had to start over with decoding the report. I have found that the report usage page is a digitizer but the usage is a pen/stylus. I was able to validate the functionality on the iPhone Notes app as when I pushed the up button it gave me a "Pen" warning and started to draw a straight line. BINGO!!!
I'm some what able to get the code to work. The problem that I have now is it will only send a total of 5 messages to the phone and not the total of 8 that I expect. Can you please review the function "digitizer_send()" and see what I need to do to make sure all 8 packets are sent in order. I get no errors. There might be a timing issue that I need to address between sending packets. I see the screen on the phone move to the left but only partial because not all the packets are sent.
Using nRF5_SDK_15.3.0_59ac345 for testing
static void digitizer_send() {
// Left Button Press Packets
uint8_t packet_1_data[] = { 0x03, 0x20, 0xC3, 0x12 };
uint8_t packet_2_data[] = { 0x03, 0xBC, 0xC2, 0x12 };
uint8_t packet_3_data[] = { 0x03, 0x58, 0xC2, 0x12 };
uint8_t packet_4_data[] = { 0x03, 0xF4, 0xC1, 0x12 };
uint8_t packet_5_data[] = { 0x03, 0x90, 0xC1, 0x12 };
uint8_t packet_6_data[] = { 0x03, 0x2C, 0xC1, 0x12 };
uint8_t packet_7_data[] = { 0x02, 0x2C, 0xC1, 0x12 };
uint8_t packet_8_data[] = { 0x02, 0x2C, 0xC1, 0x12 };
uint32_t err_code;
err_code = ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_DIG_INDEX, INPUT_REPORT_DIG_MAX_LEN, packet_1_data, m_conn_handle);
err_code = ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_DIG_INDEX, INPUT_REPORT_DIG_MAX_LEN, packet_2_data, m_conn_handle);
err_code = ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_DIG_INDEX, INPUT_REPORT_DIG_MAX_LEN, packet_3_data, m_conn_handle);
err_code = ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_DIG_INDEX, INPUT_REPORT_DIG_MAX_LEN, packet_4_data, m_conn_handle);
err_code = ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_DIG_INDEX, INPUT_REPORT_DIG_MAX_LEN, packet_5_data, m_conn_handle);
err_code = ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_DIG_INDEX, INPUT_REPORT_DIG_MAX_LEN, packet_6_data, m_conn_handle);
err_code = ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_DIG_INDEX, INPUT_REPORT_DIG_MAX_LEN, packet_7_data, m_conn_handle);
err_code = ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_DIG_INDEX, INPUT_REPORT_DIG_MAX_LEN, packet_8_data, m_conn_handle);
//APP_ERROR_CHECK(err_code);
Packet 1: 050D 0902 A101 8501 050D 0920 A102 0942 1500 2501 7501 Packet 2: 9501 8102 0932 8102 9502 8101 7504 0951 250F 9501 8102 Packet 3: 0501 1600 0026 E803 750C 5500 6500 0930 3600 0046 E803 Packet 4: 9501 8102 26E8 0346 E803 0931 8102 C085 0375 0895 0115 Packet 5: 0125 0809 55B1 02C0 050C 0901 A101 8502 1500 2501 7501 Packet 6: 9518 0A23 020A 2102 0A8A 010A AE01 0A96 010A 0103 0A02 Packet 7: 030A 0503 0A06 030A 0703 0A08 030A 8301 0A0B 0309 4009 Packet 8: 3009 6509 7009 6F09 B609 CD09 B509 E209 EA09 E981 02C0 0x05, 0x0D, // USAGE_PAGE (Digitizer) 0x09, 0x02, // USAGE (Pen) 0xA1, 0x01, // Collection (Application) 0x85, 0x01, // REPORT_ID 2 0x05, 0x0D, // USAGE_PAGE (Digitizer) 0x09, 0x20, // USAGE (Stylus) 0xA1, 0x02, // Collection (Logical) 0x09, 0x42, // USAGE (Tip Switch) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0x01, // LOGICAL_MAXIMUM (1) 0x75, 0x01, // REPORT_SIZE (1) 0x95, 0x01, // REPORT_COUNT (1) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x09, 0x32, // USAGE (In Range) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x95, 0x02, // REPORT_COUNT (2) 0x81, 0x01, // Input (Constant) 0x75, 0x04, // REPORT_SIZE (4) 0x09, 0x51, // USAGE (Contact Identifier) 0x25, 0x0F, // LOGICAL_MAXIMUM (15) 0x95, 0x01, // REPORT_SIZE (1) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x05, 0x01, // USAGE_PAGE (Generic Desktop) 0x16, 0x00, 0x00, // LOGICAL_MINIMUM (0) 0x26, 0xE8, 0x03, // LOGICAL_MAXIMUM (0x03E8 = 1000) 0x75, 0x0C, // REPORT_SIZE (12) 0x55, 0x00, // UNIT_EXPONENT (0) 0x65, 0x00, // UNIT(Inch, EngLinear) 0x09, 0x30, // USAGE (X) 0x36, 0x00, 0x00, // PHYSICAL_MINIMUM (0) 0x46, 0xE8, 0x03, // PHYSICAL_MAXIMUM (0x03E8 = 1000) 0x95, 0x01, // REPORT_COUNT (1) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x26, 0xE8, 0x03, // LOGICAL_MAXIMUM (0x03E8 = 1000) 0x46, 0xE8, 0x03, // PHYSICAL_MAXIMUM (0x03E8 = 1000) 0x09, 0x31, // USAGE (Y) 0x81, 0x02, // INPUT (Data,Var,Abs) 0xC0, // END_COLLECTION 0x85, 0x03, // REPORT_ID 3 0x75, 0x08, // REPORT_SIZE (8) 0x95, 0x01, // REPORT_COUNT (1) 0x15, 0x01, // LOGICAL_MINIMUM (1) 0x25, 0x08, // LOGICAL_MAXIMUM (8) 0x09, 0x55, // USAGE (Contact Count Maximum) 0xB1, 0x02, // FEATURE (Data,Var,Abs) 0xC0 // END_COLLECTION ## UP Value: 03F4 0132 Value: 03F4 2130 Value: 03F4 412E Value: 03F4 612C Value: 03F4 812A Value: 03F4 A128 Value: 03F4 C126 Value: 03F4 E124 Value: 03F4 0123 Value: 03F4 2121 Value: 03F4 411F Value: 03F4 611D Value: 03F4 811B Value: 03F4 A119 Value: 03F4 C117 Value: 03F4 E115 Value: 03F4 0114 Value: 02F4 0114 ## DOWN Value: 03F4 C112 Value: 03F4 A114 Value: 03F4 8116 Value: 03F4 6118 Value: 03F4 411A Value: 03F4 211C Value: 03F4 011E Value: 03F4 E11F Value: 03F4 C121 Value: 03F4 A123 Value: 03F4 8125 Value: 03F4 6127 Value: 03F4 4129 Value: 03F4 212B Value: 03F4 012D Value: 03F4 E12E Value: 03F4 C130 Value: 02F4 C130 ## LEFT Value: 0320 C312 Value: 03BC C212 Value: 0358 C212 Value: 03F4 C112 Value: 0390 C112 Value: 032C C112 Value: 022C C112 Value: 022C C112 ## RIGHT Value: 03C8 C012 Value: 032C C112 Value: 0390 C112 Value: 03F4 C112 Value: 0358 C212 Value: 03BC C212 Value: 02BC C212 Value: 022C C112
