nRF9160 modem stuck in searching
The modem on the nrf9160DK (modem fw v1.1.0) appears to get stuck in searching mode. It doesn't happen all the time, and I was able to create it with the following AT commands:
(I want to see registration status changes)
AT+CEREG=2
AT%XSYSTEMMODE=0,1,0,0
AT+CFUN=1
(after some time (minutes?) reports AT+CEREG: 2, ...)
(then I see no more +CEREG status reports and give up)
AT+CFUN=4
(wait a few seconds)
AT+CFUN? reports +CFUN: 4, so it seems to have taken the command
AT+CEREG? reports +CEREG: 0,2,"XXXX","XXXXXXXX",9
This all works just fine with %XSYSTEMMODE=1,0,0,0. After the AT+CFUN=4 completes it will report +CEREG: 0,0,...
I kind of expect the connect to work with either mode, as I have good reception from both AT&T and Verizon, but I'm more concerned that the modem appears to get in an *almost* unrecoverable state. Changing systemmode to 1,0,0,0 followed by AT+CFUN=1 returns to normal behavior.
If it helps in troubleshooting, the AT+CFUN=4 takes ~3 seconds in mode 1,0,0,0 and less than 1 sec in mode 0,1,0,0
This link describes a similar issue: https://devzone.nordicsemi.com/f/nordic-q-a/55154/lte-network-detected-but-never-connected
  • Hi Mike,
    Please share the log from LTE link monitor when you are getting this CEREG response after AT+CFUN=4.
    e.g. This is what happens on my side:
  • I can't seem to find a way to attach the logs, so here they are inline. One diff between what you are getting is that I never get connected in NB-IoT mode.
    First log is a successful LTE-M connection:
    2020-02-08T01:24:56.852Z INFO Application data folder: /home/michael/.config/nrfconnect/pc-nrfconnect-linkmonitor
    2020-02-08T01:24:56.913Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2020-02-08T01:24:56.913Z DEBUG App path: /home/michael/.nrfconnect-apps/node_modules/pc-nrfconnect-linkmonitor
    2020-02-08T01:24:56.913Z DEBUG nRFConnect 3.3.0 is supported by the app (^3.2.0)
    2020-02-08T01:24:56.913Z DEBUG nRFConnect path: /tmp/.mount_nrfconwP3uvx/resources/app.asar
    2020-02-08T01:24:56.913Z DEBUG HomeDir: /home/michael
    2020-02-08T01:24:56.913Z DEBUG TmpDir: /tmp
    2020-02-08T01:24:57.155Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS0
    2020-02-08T01:24:57.156Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS1
    2020-02-08T01:24:57.156Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS10
    2020-02-08T01:24:57.156Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS11
    2020-02-08T01:24:57.156Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS12
    2020-02-08T01:24:57.156Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS13
    2020-02-08T01:24:57.156Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS14
    2020-02-08T01:24:57.156Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS15
    2020-02-08T01:24:57.156Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS16
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS17
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS18
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS19
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS2
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS20
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS21
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS22
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS23
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS24
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS25
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS26
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS27
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS28
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS29
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS3
    2020-02-08T01:24:57.157Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS30
    2020-02-08T01:24:57.158Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS31
    2020-02-08T01:24:57.158Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS4
    2020-02-08T01:24:57.158Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS5
    2020-02-08T01:24:57.158Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS6
    2020-02-08T01:24:57.158Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS7
    2020-02-08T01:24:57.158Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS8
    2020-02-08T01:24:57.158Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS9
    2020-02-08T01:25:03.721Z INFO Modem port is opened
    2020-02-08T01:25:03.733Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-02-08T01:25:03.766Z DEBUG modem << +CFUN: 0\x0D\x0A
    2020-02-08T01:25:03.768Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:18.365Z DEBUG modem >> AT%XSYSTEMMODE?\x0D\x0A
    2020-02-08T01:25:18.387Z DEBUG modem << %XSYSTEMMODE: 1,0,0,0\x0D\x0A
    2020-02-08T01:25:18.397Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:21.200Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-02-08T01:25:21.227Z DEBUG modem << +CFUN: 0\x0D\x0A
    2020-02-08T01:25:21.281Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:22.888Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2020-02-08T01:25:22.933Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.783Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-02-08T01:25:24.793Z DEBUG modem << +CFUN: 1\x0D\x0A
    2020-02-08T01:25:24.820Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.833Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2020-02-08T01:25:24.845Z DEBUG modem << +CGSN: "352656100038754"\x0D\x0A
    2020-02-08T01:25:24.854Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.867Z DEBUG modem >> AT+CGMI\x0D\x0A
    2020-02-08T01:25:24.874Z DEBUG modem << Nordic Semiconductor ASA\x0D
    2020-02-08T01:25:24.877Z DEBUG modem << \x0A
    2020-02-08T01:25:24.880Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.888Z DEBUG modem >> AT+CGMM\x0D\x0A
    2020-02-08T01:25:24.892Z DEBUG modem << nRF9160-SICA\x0D
    2020-02-08T01:25:24.894Z DEBUG modem << \x0A
    2020-02-08T01:25:24.896Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.903Z DEBUG modem >> AT+CGMR\x0D\x0A
    2020-02-08T01:25:24.908Z DEBUG modem << mfw_nrf9160_1.1.0\x0D\x0A
    2020-02-08T01:25:24.910Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.913Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.1.0] SerNr: 352656100038754
    2020-02-08T01:25:24.917Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2020-02-08T01:25:24.924Z DEBUG modem << +CEMODE: 2\x0D\x0A
    2020-02-08T01:25:24.925Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.937Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2020-02-08T01:25:24.948Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)\x0D\x0A
    2020-02-08T01:25:24.950Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.959Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2020-02-08T01:25:24.969Z DEBUG modem << +CMEE: 0\x0D\x0A
    2020-02-08T01:25:24.971Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.974Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2020-02-08T01:25:24.978Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.985Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2020-02-08T01:25:24.989Z DEBUG modem << +CNEC: 0\x0D
    2020-02-08T01:25:24.990Z DEBUG modem << \x0A
    2020-02-08T01:25:24.991Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:24.994Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2020-02-08T01:25:25.001Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:25.005Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2020-02-08T01:25:25.009Z DEBUG modem << +CGEREP: 0,0\x0D
    2020-02-08T01:25:25.015Z DEBUG modem << \x0A
    2020-02-08T01:25:25.019Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:25.022Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2020-02-08T01:25:25.025Z DEBUG modem << OK\x0D
    2020-02-08T01:25:25.032Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2020-02-08T01:25:25.037Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:25.039Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2020-02-08T01:25:25.042Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:25.048Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2020-02-08T01:25:25.053Z DEBUG modem << OK\x0D
    2020-02-08T01:25:25.055Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2020-02-08T01:25:25.058Z DEBUG modem << OK\x0D
    2020-02-08T01:25:25.061Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2020-02-08T01:25:25.067Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",7\x0D\x0A
    2020-02-08T01:25:25.069Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:25.082Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2020-02-08T01:25:25.086Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:25.089Z DEBUG modem >> AT+CESQ\x0D\x0A
    2020-02-08T01:25:25.094Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D
    2020-02-08T01:25:25.101Z DEBUG modem << \x0A
    2020-02-08T01:25:25.103Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:25.109Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2020-02-08T01:25:25.115Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:25.119Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2020-02-08T01:25:25.123Z DEBUG modem << %XSIM: 0\x0D
    2020-02-08T01:25:25.124Z DEBUG modem << \x0A
    2020-02-08T01:25:25.126Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:26.785Z DEBUG modem << %XSIM: 1\x0D\x0A
    2020-02-08T01:25:26.812Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2020-02-08T01:25:26.822Z DEBUG modem << +CPIN: READY\x0D\x0A
    2020-02-08T01:25:26.829Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:26.846Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2020-02-08T01:25:27.094Z DEBUG modem << +CPINR: "SIM PIN",3\x0D
    2020-02-08T01:25:27.095Z DEBUG modem << \x0A
    2020-02-08T01:25:27.096Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:27.105Z DEBUG modem >> AT+CIMI\x0D\x0A
    2020-02-08T01:25:27.110Z DEBUG modem << 262017740075598\x0D
    2020-02-08T01:25:27.111Z DEBUG modem << \x0A
    2020-02-08T01:25:27.113Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:27.114Z INFO IMSIdentity: 262017740075598
    2020-02-08T01:25:27.685Z DEBUG modem << %CESQ: 54,2,14,2\x0D\x0A
    2020-02-08T01:25:27.706Z DEBUG modem << +CEREG: 2,"121F","01123911",7\x0D\x0A
    2020-02-08T01:25:29.388Z DEBUG modem << +CGEV: ME PDN ACT 0,0\x0D\x0A
    2020-02-08T01:25:29.422Z DEBUG modem << +CNEC_ESM: 50,0\x0D\x0A
    2020-02-08T01:25:29.443Z DEBUG modem << +CEREG: 5,"121F","01123911",7\x0D\x0A
    2020-02-08T01:25:29.460Z DEBUG modem << +CIND: "service",1\x0D\x0A
    2020-02-08T01:25:29.468Z DEBUG modem << +CIND: "roam",1\x0D\x0A
    2020-02-08T01:25:29.473Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2020-02-08T01:25:29.482Z DEBUG modem << +CGDCONT: 0,"IP","internet.m2mportal.de","10.129.140.125",0,0\x0D
    2020-02-08T01:25:29.484Z DEBUG modem << \x0A
    2020-02-08T01:25:29.485Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:29.493Z DEBUG modem >> AT+COPS=3,2\x0D\x0A
    2020-02-08T01:25:29.496Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:29.504Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2020-02-08T01:25:29.509Z DEBUG modem << +CGACT: 0,1\x0D\x0A
    2020-02-08T01:25:29.510Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:29.515Z DEBUG modem >> AT+COPS?\x0D\x0A
    2020-02-08T01:25:29.520Z DEBUG modem << +COPS: 0,2,"310410",7\x0D\x0A
    2020-02-08T01:25:29.523Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:29.529Z DEBUG modem >> AT%XCBAND\x0D\x0A
    2020-02-08T01:25:29.537Z DEBUG modem << %XCBAND: 17\x0D\x0A
    2020-02-08T01:25:29.539Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:29.545Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2020-02-08T01:25:29.554Z DEBUG modem << +CGDCONT: 0,"IP","internet.m2mportal.de","10.129.140.125",0,0\x0D\x0A
    2020-02-08T01:25:29.555Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:29.562Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2020-02-08T01:25:29.570Z DEBUG modem << +CGACT: 0,1\x0D\x0A
    2020-02-08T01:25:29.572Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:36.642Z DEBUG modem << %CESQ: 54,2,9,1\x0D\x0A
    2020-02-08T01:25:41.629Z DEBUG modem << %CESQ: 54,2,14,2\x0D
    2020-02-08T01:25:53.810Z DEBUG modem >> AT+CFUN=4\x0D\x0A
    2020-02-08T01:25:54.041Z DEBUG modem << +CGEV: ME PDN DEACT 0\x0D\x0A
    2020-02-08T01:25:54.072Z DEBUG modem << +CEREG: 0,"121F","01123911",7\x0D\x0A
    2020-02-08T01:25:54.097Z DEBUG modem << +CIND: "service",0\x0D\x0A
    2020-02-08T01:25:54.111Z DEBUG modem << +CIND: "roam",0\x0D\x0A
    2020-02-08T01:25:54.130Z DEBUG modem << +CGEV: ME DETACH\x0D\x0A
    2020-02-08T01:25:55.499Z DEBUG modem << %CESQ: 255,0,255,0\x0D\x0A
    2020-02-08T01:25:56.564Z DEBUG modem << %XSIM: 0\x0D
    2020-02-08T01:25:56.593Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:56.598Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2020-02-08T01:25:56.613Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:56.616Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2020-02-08T01:25:56.629Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:56.631Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2020-02-08T01:25:56.644Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:25:56.648Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2020-02-08T01:25:56.661Z DEBUG modem << OK\x0D\x0A
    And this is the failed NB-IoT:
    2020-02-08T01:27:01.247Z INFO Application data folder: /home/michael/.config/nrfconnect/pc-nrfconnect-linkmonitor
    2020-02-08T01:27:01.334Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2020-02-08T01:27:01.334Z DEBUG App path: /home/michael/.nrfconnect-apps/node_modules/pc-nrfconnect-linkmonitor
    2020-02-08T01:27:01.334Z DEBUG nRFConnect 3.3.0 is supported by the app (^3.2.0)
    2020-02-08T01:27:01.334Z DEBUG nRFConnect path: /tmp/.mount_nrfconwP3uvx/resources/app.asar
    2020-02-08T01:27:01.335Z DEBUG HomeDir: /home/michael
    2020-02-08T01:27:01.335Z DEBUG TmpDir: /tmp
    2020-02-08T01:27:01.627Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS0
    2020-02-08T01:27:01.627Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS1
    2020-02-08T01:27:01.627Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS10
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS11
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS12
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS13
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS14
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS15
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS16
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS17
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS18
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS19
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS2
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS20
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS21
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS22
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS23
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS24
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS25
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS26
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS27
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS28
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS29
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS3
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS30
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS31
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS4
    2020-02-08T01:27:01.628Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS5
    2020-02-08T01:27:01.629Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS6
    2020-02-08T01:27:01.629Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS7
    2020-02-08T01:27:01.629Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS8
    2020-02-08T01:27:01.629Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS9
    2020-02-08T01:27:03.168Z INFO Modem port is opened
    2020-02-08T01:27:03.176Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-02-08T01:27:03.179Z DEBUG modem << **** Booting Zephyr OS build v2.0.99-ncs1 *****\x0D\x0A
    2020-02-08T01:27:03.180Z DEBUG modem << Flash region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2020-02-08T01:27:03.182Z DEBUG modem << 00 0x00000 0x08000 \x09Secure\x09\x09rwxl\x0D\x0A
    2020-02-08T01:27:03.211Z DEBUG modem << 01 0x0800+CFUN: 0\x0D\x0A
    2020-02-08T01:27:03.214Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:12.268Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-02-08T01:27:12.287Z DEBUG modem << +CFUN: 0\x0D\x0A
    2020-02-08T01:27:12.332Z DEBUG modem << OK\x0D
    2020-02-08T01:27:23.497Z DEBUG modem >> AT%XSYSTEMMODE=0,1,0,0\x0D\x0A
    2020-02-08T01:27:23.515Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:29.667Z DEBUG modem >> AT%XSYSTEMMODE?\x0D\x0A
    2020-02-08T01:27:29.699Z DEBUG modem << %XSYSTEMMODE: 0,1,0,0\x0D\x0A
    2020-02-08T01:27:29.706Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:32.332Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2020-02-08T01:27:32.379Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:33.851Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-02-08T01:27:33.871Z DEBUG modem << +CFUN: 1\x0D\x0A
    2020-02-08T01:27:33.908Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:33.927Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2020-02-08T01:27:33.939Z DEBUG modem << +CGSN: "352656100038754"\x0D
    2020-02-08T01:27:33.953Z DEBUG modem << \x0A
    2020-02-08T01:27:33.955Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:33.960Z DEBUG modem >> AT+CGMI\x0D\x0A
    2020-02-08T01:27:33.969Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2020-02-08T01:27:33.972Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:33.976Z DEBUG modem >> AT+CGMM\x0D\x0A
    2020-02-08T01:27:33.986Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2020-02-08T01:27:33.990Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:33.992Z DEBUG modem >> AT+CGMR\x0D\x0A
    2020-02-08T01:27:34.000Z DEBUG modem << mfw_nrf9160_1.1.0\x0D\x0A
    2020-02-08T01:27:34.003Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.005Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.1.0] SerNr: 352656100038754
    2020-02-08T01:27:34.006Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2020-02-08T01:27:34.015Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2020-02-08T01:27:34.018Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.025Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2020-02-08T01:27:34.033Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)\x0D
    2020-02-08T01:27:34.036Z DEBUG modem << \x0A
    2020-02-08T01:27:34.037Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.051Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2020-02-08T01:27:34.056Z DEBUG modem << +CMEE: 0\x0D
    2020-02-08T01:27:34.058Z DEBUG modem << \x0A
    2020-02-08T01:27:34.059Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.066Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2020-02-08T01:27:34.071Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.074Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2020-02-08T01:27:34.083Z DEBUG modem << +CNEC: 0\x0D\x0A
    2020-02-08T01:27:34.085Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.088Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2020-02-08T01:27:34.091Z DEBUG modem << OK\x0D
    2020-02-08T01:27:34.100Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2020-02-08T01:27:34.109Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2020-02-08T01:27:34.110Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.120Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2020-02-08T01:27:34.124Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.127Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2020-02-08T01:27:34.134Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.137Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2020-02-08T01:27:34.142Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.149Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2020-02-08T01:27:34.154Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.156Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2020-02-08T01:27:34.160Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.170Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2020-02-08T01:27:34.177Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",9\x0D
    2020-02-08T01:27:34.180Z DEBUG modem << \x0A
    2020-02-08T01:27:34.183Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.210Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2020-02-08T01:27:34.216Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.220Z DEBUG modem >> AT+CESQ\x0D\x0A
    2020-02-08T01:27:34.227Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D
    2020-02-08T01:27:34.239Z DEBUG modem << \x0A
    2020-02-08T01:27:34.241Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.258Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2020-02-08T01:27:34.263Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:34.275Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2020-02-08T01:27:34.281Z DEBUG modem << %XSIM: 0\x0D\x0A
    2020-02-08T01:27:34.292Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:36.332Z DEBUG modem << %XSIM: 1\x0D\x0A
    2020-02-08T01:27:36.368Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2020-02-08T01:27:36.374Z DEBUG modem << +CPIN: READY\x0D
    2020-02-08T01:27:36.377Z DEBUG modem << \x0A
    2020-02-08T01:27:36.380Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:36.392Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2020-02-08T01:27:36.642Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2020-02-08T01:27:36.661Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:36.696Z DEBUG modem >> AT+CIMI\x0D\x0A
    2020-02-08T01:27:36.707Z DEBUG modem << 262017740075598\x0D\x0A
    2020-02-08T01:27:36.711Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:27:36.720Z INFO IMSIdentity: 262017740075598
    2020-02-08T01:27:58.583Z DEBUG modem << %CESQ: 62,3,22,3\x0D\x0A
    2020-02-08T01:27:58.620Z DEBUG modem << +CEREG: 2,"131B","0112393B",9\x0D\x0A
    2020-02-08T01:27:59.370Z DEBUG modem << +CNEC_EMM: 15\x0D\x0A
    2020-02-08T01:27:59.395Z DEBUG modem << +CEREG: 4,"131B","0112393B",9\x0D\x0A
    2020-02-08T01:27:59.762Z DEBUG modem << %CESQ: 255,0,255,0\x0D
    2020-02-08T01:27:59.771Z DEBUG modem << +CEREG: 4,"FFFE","FFFFFFFF",9\x0D\x0A
    2020-02-08T01:28:09.452Z DEBUG modem << %CESQ: 56,2,18,2\x0D\x0A
    2020-02-08T01:28:09.481Z DEBUG modem << +CEREG: 2,"6D82","01AAD61E",9\x0D\x0A
    2020-02-08T01:28:12.368Z DEBUG modem << +CNEC_ESM: 32,0\x0D\x0A
    2020-02-08T01:28:12.389Z DEBUG modem << +CNEC_EMM: 19\x0D\x0A
    2020-02-08T01:28:13.216Z DEBUG modem << %CESQ: 255,0,255,0\x0D
    2020-02-08T01:28:13.241Z DEBUG modem << +CEREG: 2,"FFFE","FFFFFFFF",9\x0D\x0A
    2020-02-08T01:28:38.262Z DEBUG modem << %CESQ: 58,2,18,2\x0D\x0A
    2020-02-08T01:28:38.287Z DEBUG modem << +CEREG: 2,"6D82","01AAD61E",9\x0D\x0A
    2020-02-08T01:29:43.746Z DEBUG modem << %CESQ: 53,2,18,2\x0D\x0A
    2020-02-08T01:31:56.870Z DEBUG modem << %CESQ: 58,2,18,2\x0D\x0A
    2020-02-08T01:32:22.286Z DEBUG modem << %CESQ: 49,2,18,2\x0D\x0A
    2020-02-08T01:32:22.336Z DEBUG modem << %CESQ: 49,2,23,3\x0D\x0A
    2020-02-08T01:32:22.358Z DEBUG modem << +CEREG: 2,"EE0B","00C526D4",9\x0D\x0A
    2020-02-08T01:32:23.155Z DEBUG modem << +CNEC_EMM: 11\x0D\x0A
    2020-02-08T01:32:23.207Z DEBUG modem << %CESQ: 255,0,255,0\x0D\x0A
    2020-02-08T01:32:23.244Z DEBUG modem << +CEREG: 2,"FFFE","FFFFFFFF",9\x0D\x0A
    2020-02-08T01:32:27.392Z DEBUG modem << %CESQ: 62,3,21,3\x0D\x0A
    2020-02-08T01:32:27.420Z DEBUG modem << +CEREG: 4,"131B","0112393B",9\x0D\x0A
    2020-02-08T01:32:34.091Z DEBUG modem << %CESQ: 62,3,26,3\x0D\x0A
    2020-02-08T01:32:36.127Z DEBUG modem >> AT+CFUN=4\x0D\x0A
    2020-02-08T01:32:36.151Z DEBUG modem << %CESQ: 255,0,255,0\x0D\x0A
    2020-02-08T01:32:36.385Z DEBUG modem << %XSIM: 0\x0D\x0A
    2020-02-08T01:32:36.415Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:32:52.223Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2020-02-08T01:32:52.247Z DEBUG modem << +CEREG: 2,4,"131B","0112393B",9\x0D\x0A
    2020-02-08T01:32:52.271Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:32:57.996Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-02-08T01:32:58.021Z DEBUG modem << +CFUN: 4\x0D\x0A
    2020-02-08T01:32:58.047Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:32:58.070Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2020-02-08T01:32:58.114Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:33:01.967Z DEBUG modem << %XSIM: 1\x0D\x0A
    2020-02-08T01:33:02.001Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2020-02-08T01:33:02.012Z DEBUG modem << +CPIN: READY\x0D\x0A
    2020-02-08T01:33:02.015Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:33:02.059Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2020-02-08T01:33:02.273Z DEBUG modem << +CPINR: "SIM PIN",3\x0D
    2020-02-08T01:33:02.277Z DEBUG modem << \x0A
    2020-02-08T01:33:02.280Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:33:02.316Z DEBUG modem >> AT+CIMI\x0D\x0A
    2020-02-08T01:33:02.326Z DEBUG modem << 262017740075598\x0D
    2020-02-08T01:33:02.333Z DEBUG modem << \x0A
    2020-02-08T01:33:02.337Z DEBUG modem << OK\x0D\x0A
    2020-02-08T01:33:02.340Z INFO IMSIdentity: 262017740075598
  • Try to run the AT%XEPCO=0 before turning on the modem when selecting NB-IoT (AT%XSYSTEMMODE).
  • Tried and got the same results. Also tried AT%XEPCO=1 and no difference
