Files for OTA firmware update stored in flash
We are using nRF52840 with SDK 15.2.0, a bootloader, the bootloader settings and the SoftDevice. Our product has a cellular modem to be able to perform OTA firmware updates without BLE. We are currently able to receive and store the new firmware in flash memory, so the next step is to reboot on the bootloader to swap the new application code at the address of the old.
We have tried to store firstly all the .zip DFU file in flash, but according to this answer on an other thread we can't do that. The .zip file contains 3 files : a .bin, a .dat and a .json. The answer said "The bootloader will activate the new image if both init data and FW data are stored correctly."
Can you explain which files must be used and where in the flash memory ? We think FW data is the .bin file but is the init data the .dat ? And is the right location at the first page after the end of the current application ?
Thanks!
  • OK, thanks!
    We have checked what the bootloader do in nrf_bootloader_init() and nrf_bootloader_fw_activate(). It seems ok compared to our settings, but perhaps the problem appears above, in nrf_dfu_settings_init().
    Here is our full nrf_dfu_settings_t structure values after adding the init command:
    • crc = computed value of the settings, like the documentation explains
    • settings_version, app_version and bootloader_version = no modification
    • bank_layout and bank_current = no modification
    • bank_0:
      • image_size and image_crc = no modification
      • bank_code = NRF_DFU_BANK_INVALID
    • bank_1:
      • image_size = size of the new firmware
      • image_crc = computed value of the new firmware
      • bank_code = NRF_DFU_BANK_VALID_APP
    • write_offset and sd_size = no modification
    • progress:
      • command_size = size of the init command
      • command_offset = no modification
      • command_crc = computed value of the init command
      • data_object_size = no modification
      • update_start_address = bank 1 address
    • enter_buttonless_dfu = 1
    • init_command = init command data
    Is it correct? About the CRC of the settings, we must include all the size of the init_command table (256 bytes with several 0xFF at the end) or only the size of the written data?
  • Concerning our last question in the previous post, we have found a difference between the online documentation and the bootloader code about the CRC.
    In the description of the settings structure, we can read "uint32_t nrf_dfu_settings_t::crc CRC for the stored DFU settings, not including the CRC itself."
    But in the comments of the bootloader code, for the settings_crc_get() function, it is written "The crc is calculated from the s_dfu_settings struct, except the crc itself and the init command"
    So we have removed the init command from the CRC calculation but the behavior stays the same.
  • Perhaps our problem comes from the settings backup in 0xFE000 which is not the same as our settings in 0xFF000, so the settings are overwritten like in this thread.
    So we need to write the same data in 0xFE000 and 0xFF000 but the 0xFE000 page is protected by the bootloader like explained in this other thread. Is there a solution for removing this protection directly from the application, without modifying the bootloader?
    Good point. The background is that backup of bootloader settings was introduced as a security feature, as part of the support for secure boot. You can disable parts of this check by setting NRF_DFU_SETTINGS_ALLOW_UPDATE_FROM_APP to 1 in the bootloaders sdk_config.h. Alternatively, you can remove it altogether by modifying settings_forbidden_parts_equal_to_backup in <SDK>\components\libraries\bootloader\dfu\nrf_dfu_settings.c to always return true.
    I am sorry I did not mention this before. (In my faulty memory settings backup was introduced in SDK 15.3 rather than 15.2).
  • Thanks a lot! It works now and we have succesfully swapped on the new firmware.
    But it takes about 2 minutes between the reboot in DFU mode and the start of the new firmware. Is this delay normal? (For information the firmware has a size of 213140 bytes)
