nRF9160 and SD card example
Dear All,
I want to create a simple example, where the nRF9160 will create a file in an SD card, read it, write to it etc.
I found an example in ncs/zephyr/samples/subsys/fs/fat_fs. In this example the device will mount the SD card and read out the files in it, so it seems to be the perfect starting point for me.
In the Zephyr documentation (here) it is suggested that I need to implement an overlay. But when I make that overlay file the project won't be loaded on the SES, giving me this error:
My overlay file looks like this:
CONFIG_SPI=y
CONFIG_SPI_1=y
CONFIG_DISK_ACCESS=y
CONFIG_DISK_ACCESS_SDHC=y
CONFIG_DISK_ACCESS_SPI_SDHC=y
CONFIG_DISK_SDHC_VOLUME_NAME="SD"
CONFIG_LOG=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_PRINTK=y
From what I understand the overlay file is somehow messing the project up, but I don't see how that happens.
If I do not add the overlay file, the project loads normally, but I am getting this error when I try to compile:
Building ‘zephyr/drivers/spi/libdrivers__spi.a’ from solution ‘build’ in configuration ‘Common’
1> Archiving ‘libdrivers__gpio.a’
2> Compiling ‘spi_nrfx_spim.c’
2> In file included from C:/ncs/zephyr/include/arch/arm/arch.h:26:0,
2>                  from C:/ncs/zephyr/include/arch/cpu.h:17,
2>                  from C:/ncs/zephyr/include/kernel_includes.h:34,
2>                  from C:/ncs/zephyr/include/kernel.h:17,
2>                  from C:/ncs/zephyr/include/device.h:11,
2>                  from C:/ncs/zephyr/include/drivers/spi.h:24,
2>                  from C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:7:
2> C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:374:8: error: 'DT_NORDIC_NRF_SPIM_SPI_1_IRQ_0_PRIORITY' undeclared (first use in this function); did you mean 'DT_NORDIC_NRF_SPIM_SPI_3_IRQ_0_PRIORITY'?
2> C:/ncs/zephyr/include/arch/arm/irq.h:82:32: note: in definition of macro 'Z_ARCH_IRQ_CONNECT'
2> C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:373:3: note: in expansion of macro 'IRQ_CONNECT'
2> C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:412:1: note: in expansion of macro 'SPI_NRFX_SPIM_DEVICE'
2> C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:374:8: note: each undeclared identifier is reported only once for each function it appears in
2> C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:387:17: error: 'DT_NORDIC_NRF_SPIM_SPI_1_SCK_PIN' undeclared here (not in a function); did you mean 'DT_NORDIC_NRF_SPIM_SPI_3_SCK_PIN'?
2> C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:388:17: error: 'DT_NORDIC_NRF_SPIM_SPI_1_MOSI_PIN' undeclared here (not in a function); did you mean 'DT_NORDIC_NRF_SPIM_SPI_3_MOSI_PIN'?
2> C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:389:17: error: 'DT_NORDIC_NRF_SPIM_SPI_1_MISO_PIN' undeclared here (not in a function); did you mean 'DT_NORDIC_NRF_SPIM_SPI_3_MISO_PIN'?
2> In file included from C:/ncs/zephyr/include/drivers/spi.h:24:0,
2> C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:399:9: error: 'DT_NORDIC_NRF_SPIM_SPI_1_LABEL' undeclared here (not in a function); did you mean 'DT_NORDIC_NRF_SPIM_SPI_3_LABEL'?
2> C:/ncs/zephyr/include/device.h:107:11: note: in definition of macro 'DEVICE_AND_API_INIT'
2> C:/ncs/zephyr/drivers/spi/spi_nrfx_spim.c:398:2: note: in expansion of macro 'DEVICE_DEFINE'
Build failed
which obviously comes from the fact that spi1 is not correctly initialized.
So what is the proper form of the overlay file?
