Calls to app_usbd_cdc_acm_write() fail with NRF_ERROR_BUSY if CDC-ACM device is opened / read from
I'm having the issue of where calling app_usbd_cdc_acm_write() more than once within the ble_nus_data_handler fails.
A test case is based on the "examples/peripheral/usbd_ble_uart/main.c"-example (SDK v16).
Diff to above mentioned vanilla example:
diff --git a/examples/peripheral/usbd_ble_uart/main.c b/examples/peripheral/usbd_ble_uart/main.c
index b8d030fa..dfd62b31 100644
--- a/examples/peripheral/usbd_ble_uart/main.c
+++ b/examples/peripheral/usbd_ble_uart/main.c
@@ -243,7 +243,7 @@ static void gap_params_init(void)
+ ret_code_t ret = 1;
bsp_board_led_invert(LED_BLE_NUS_RX);
@@ -259,14 +259,20 @@ static void nus_data_handler(ble_nus_evt_t * p_evt)
length += sizeof(ENDLINE_STRING);
+ NRF_LOG_INFO("app_usbd_cdc_acm_write() :: about to write to CDC-ACM dev");
+ NRF_LOG_FINAL_FLUSH();
// Send data through CDC ACM
- ret_code_t ret = app_usbd_cdc_acm_write(&m_app_cdc_acm,
- m_nus_data_array,
- length);
- if(ret != NRF_SUCCESS)
- NRF_LOG_INFO("CDC ACM unavailable, data received: %s", m_nus_data_array);
+ do {
+ ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_nus_data_array, length);
+ NRF_LOG_INFO("app_usbd_cdc_acm_write() (1) :: ret: %d", ret);
+ } while (ret == NRF_ERROR_BUSY);
+ do {
+ NRF_LOG_INFO("app_usbd_cdc_acm_write() (2) :: ret: %d", ret);
@@ -621,7 +627,7 @@ static void buttons_leds_init(void)
/** @brief Function for initializing the nrf_log module. */
static void log_init(void)
- ret_code_t err_code = NRF_LOG_INIT(NULL);
+ ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
Since there's no example for the pca10059 board (nrf52840 USB dongle) I adapted the pca10056 one.
The Makefile only contains changes related to the board definition (PCA10056 -> PCA10059).
The sdk_config.h only has "NRF_LOG_BACKEND_UART_TX_PIN" and "NRF_LOG_USES_TIMESTAMP" changed compared to the pca10056 one.
Procedure:
  1. powering up pca10059
  2. open /dev/ttyACM0 on host
  3. connect via BLE (nrf connect)
  4. send string "qwertz"
Log output
[00:00:00.000,000] <info> app_timer: RTC: initialized.
[00:00:00.000,000] <info> app: USBD BLE UART example started.
[00:00:00.000,000] <info> app: USB power detected
[00:00:00.005,004] <info> app: USB ready
[00:00:05.362,487] <info> app: CDC ACM port opened
[00:00:08.517,456] <info> app: BLE NUS connected
[00:00:08.517,517] <info> app: Data len is set to 0x3D(61)
[00:00:13.517,578] <info> app: app_usbd_cdc_acm_write() :: about to write to CDC-ACM dev
[00:00:13.517,578] <info> app: app_usbd_cdc_acm_write() (1) :: ret: 0
[00:00:13.517,578] <info> app: app_usbd_cdc_acm_write() (2) :: ret: 17
All calls after the first one to app_usbd_cdc_acm_write() result in NRF_ERROR_BUSY being returned - indefinitely.
Everything is fine though, if I skip step 2), hence not opening /dev/ttyACM0 / reading from it on the host:
[00:00:05.965,576] <info> app: BLE NUS connected
[00:00:06.026,123] <info> app: Data len is set to 0x3D(61)
[00:00:11.981,384] <info> app: app_usbd_cdc_acm_write() :: about to write to CDC-ACM dev
[00:00:11.989,624] <info> app: app_usbd_cdc_acm_write() (1) :: ret: 8
[00:00:11.995,971] <info> app: app_usbd_cdc_acm_write() (2) :: ret: 8
Please also note the different return calls from the first call to app_usbd_cdc_acm_write() each.
In the scenario where ttyACM is opened, it's 0, while where it isn't, it's 8.
  • Thanks for your pointers - I'll definitely give it a try.
    Please mind though, that i'm *not* calling app_usbd_cdc_acm_write() in the *UART* interrupt handler (at least not as far as I know), but in the ble_nus_handler() - when I revćeive data via BLE.
    This might have to do with it. Will check now and report back.
  • As a follow-up - with the following diff to the original example I can call nus_data_handler() - and within it app_usbd_cdc_acm_write() twice - without any issue.
    So the it seems my issue is related to app_usbd_cdc_acm_write() being called within the BLE NUS interrupt.
    index b8d030fa..87213ff2 100644
    @@ -259,14 +259,22 @@ static void nus_data_handler(ble_nus_evt_t * p_evt)
    +        NRF_LOG_INFO("app_usbd_cdc_acm_writer() :: about to write to CDC-ACM dev");
    -                                                m_nus_data_array,
    -                                                length);
    +        do {
    +            //ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_nus_data_array, length);
    +            ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, "foobar\r\n", 8);
    +        do {
    @@ -861,6 +870,13 @@ int main(void)
         ret = app_usbd_power_events_enable();
         APP_ERROR_CHECK(ret);
    +    ble_nus_evt_t * p_evt;
    +    memset(&p_evt, 0, sizeof(ble_nus_evt_t));
    +    p_evt->type = BLE_NUS_EVT_RX_DATA;
    +    NRF_LOG_INFO("Entering main loop");
         // Enter main loop.
         for (;;)
    @@ -869,6 +885,8 @@ int main(void)
                 /* Nothing to do */
             idle_state_handle();
    +        nrf_delay_ms(500);
    +        nus_data_handler(p_evt);
  • I can confirm that changing the USB interrupt priority solves my problem. Thanks a lot!
