Advertising Stops After Connection - Restarting on Connection Works Most of the Time
We are developing using SDK 15.3.0 and S140. After I noticed that advertising stopped when a connection occurred, I was directed to simply restart upon connection. I have been doing so with largely successful results, but I recently noticed that (on rare occasion) advertising does not restart. This is 1 out of hundreds of connections when the central connecting device is Android, but far more frequent when the central connecting device is a Raspberry Pi 3B running Linux. I would like get an on_ble_evt handler in place and just restart advertising when notified that it has stopped or BLE_ADV_EVT_IDLE, but I cannot see how to set the ble_adv_event_handler_t when the advertising module is not used. I am setting up by advertising using the following code.
// Config advertising.
void xtag_adv_config(bool firstCall)
  ret_code_t             err_code;
  // Setup var to hold ble_advdata_t advert data.
  ble_advdata_t advdata;
  memset(&advdata, 0, sizeof(advdata));
  // Setup var to hold ble_advdata_t scan resp data.
  ble_advdata_t srdata;
  memset(&srdata, 0, sizeof(srdata));
  // Just use srdata to indicate that we want to expose the name provided in gap_params_init().
  srdata.name_type = BLE_ADVDATA_FULL_NAME;
  // Setup variable to hold manufacturer specific advert data
  ble_advdata_manuf_data_t mfr_advdata;
  memset(&mfr_advdata, 0, sizeof(mfr_advdata));
  // Update mfr_data and add to advdata.
  uint8_t data[MFR_PAYLOAD_SIZE_GAP];
  xtag_adv_mfr_data_setup(data);
  mfr_advdata.company_identifier =  0x030E; //Dworx company ID
  mfr_advdata.data.p_data = data;
  mfr_advdata.data.size = sizeof(data);
  advdata.name_type = BLE_ADVDATA_NO_NAME;
  advdata.p_manuf_specific_data = &mfr_advdata;
  advdata.include_appearance      = true;
  advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
  advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
  advdata.uuids_complete.p_uuids  = m_adv_uuids;
  // Initialize advertising parameters (used when starting advertising).
  memset(&m_adv_params, 0, sizeof(m_adv_params));
  m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
  m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
  m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
  m_adv_params.interval        = APP_ADV_INTERVAL;
  m_adv_params.duration        = 0;       // Never time out.
  // Encode advdata to m_gapData[m_bufIdx]
  err_code = ble_advdata_encode(&advdata, m_gapData[m_bufIdx].adv_data.p_data, (uint16_t *) &m_gapData[m_bufIdx].adv_data.len);
  // Encode srdata to m_gapData[m_bufIdx]
  err_code = ble_advdata_encode(&srdata, m_gapData[m_bufIdx].scan_rsp_data.p_data, (uint16_t *) &m_gapData[m_bufIdx].scan_rsp_data.len);
  // Setup adverts. On first call, also set advert params.
  if(firstCall)
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_gapData[m_bufIdx], &m_adv_params);
    err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,m_adv_handle, xTag_get_tx_pwr());
  else  // Susequent calls - update payloady only.
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_gapData[m_bufIdx], NULL);
  // Toggle buffer index to toggle buffer used.
  if(m_bufIdx == 0) {m_bufIdx ++;}
  else {m_bufIdx = 0;}
Thanks in advance.
Mark J
