I have a project which was originally written using SDK12, and have updated it to SDK16, I am sorry I know this question seems to have been asked in many different ways already.
I have one problem left.
I need to dynamically update manufacture specific data for the advertisement, and the code below used to work fine.
I know things have changed now and I have to use the ble_advdata_encode function, but it is not clear how exactly and I cannot find any direct examples.
The searched turn up hundreds of results from the forum which are all slightly different, some use ble_advertising_init, others sd_ble_gap_adv_start and a ton inbetweeners.
The migration guide is also not clear on the matter.
I am using short names and fast advertising, I previously had the following init function and an update function - could someone indicate to me, or point me to a proper example of how I can change this code from SDK12 style to SDK16 and achieve exactly the same result with as little change as possible?
I think I have to continue to use the ble_advertising_init due to the fast advertising options, I would also prefer not to have to stop and start the advertisement every time I want to update it (i believe I will also have to update the interval times as per the change of units mentioned in the migration guide)
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static ble_manufacturer_data_t m_manufacturer_data;
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{ BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE } //,
//{BLE_UUID_CALLPOINT_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN}
ret_code_t err_code;
ble_advdata_manuf_data_t adv_manuf_data;
uint8_array_t adv_manuf_data_array;
uint8_t adv_manuf_data_data[sizeof(ble_manufacturer_data_t) - 2];
memset(&m_adv_init, 0, sizeof(m_adv_init));
m_adv_init.advdata.name_type = BLE_ADVDATA_SHORT_NAME;
m_adv_init.advdata.short_name_len = 3;
m_adv_init.advdata.include_appearance = true;
m_adv_init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
m_adv_init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
m_adv_init.advdata.uuids_complete.p_uuids = m_adv_uuids;
// Configuration of manufacturer specific data
memcpy((uint8_t*) adv_manuf_data_data, (uint8_t*) &m_manufacturer_data.DeviceType,
sizeof(ble_manufacturer_data_t) - 2);
adv_manuf_data_array.p_data = adv_manuf_data_data;
adv_manuf_data_array.size = sizeof(ble_manufacturer_data_t) - 2;
adv_manuf_data.company_identifier = LI_COMPANY;
adv_manuf_data.data = adv_manuf_data_array;
m_adv_init.advdata.p_manuf_specific_data = &adv_manuf_data;
m_adv_init.config.ble_adv_fast_enabled = true;
m_adv_init.config.ble_adv_fast_interval = APP_ADV_INTERVAL;
m_adv_init.config.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
m_adv_init.evt_handler = on_adv_evt;
err_code = ble_advertising_init(&m_advertising, &m_adv_init);
static void update_advertisment(void)
err_code = ble_advdata_set(&m_adv_init.advdata, NULL);
Many thanks
