nrf_dfu_transports_init() error in background dfu
I am using
  • PCA10056
  • SDK 15.3.0
  • Keil IDE
  • The soft device is S140
  • JLinkRTTViewer for debug
I am testing background serial-dfu.(refer to https://devzone.nordicsemi.com/f/nordic-q-a/46336/bootloader-no-transport-dual-bank-dfu-and-dependencies)
I erase 52840 whole and write SoftDevice & bootloader.
I used keil debug to download the app and run.
An error occurred with the attachment.
Please advise
Alex
    I am continuing the background dfu test.
    1. Why did the following message appear when I turn the power on?
       app: Incorrect bootloader start address. Set BOOTLOADER_START_ADDR to 0xE4000
    2. Is the log progress correct?
       I don't know why it doesn't progress at all after the last message in the log.
      00> <debug> app: Bank 0 code: 0x01: Size: 0x296F0
      00>
      00> <debug> app: Bank 1 code: 0x00: Size: 0x0
      00>
      00> <debug> app: pass: 0.
      00>
      00> <debug> app: cache_address: 0x50000.
      00>
      00> <debug> app: cache_too_small: false.
    Please advise.
    Downloading using the bootloader on the target board works well and runs normally.
    Using background dfu causes the same problem as above.
    1. What is BOOTLOADER_START_ADDR set to in your project settings? The problem is that it doesn't correspond to the actual bootloader start address.
    2. This one looks better. Bank 0 looks to contain valid data and the cache is starting at bank 1.
  • Hi Vidar,
    Sorry for asking too basic questions often.
    1. Where and how do I set BOOTLOADER_START_ADDR in Keil?
     <info> app: bootloader_addr_actual = E4000 bootloader_addr_expected = 26000
     00>
     00> START_ADDR to 0xE4000
     In secure_bootloader(uart), IROM1 is set to 0xE4000.
    2. I get the following error message.
    00>
    00>
    00> <debug> app: keep_firmware: true.
    00>
    00> <debug> nrf_dfu_settings: Writing settings...
    00>
    00> <debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000
    00>
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 0
    00>
    00> <error> app: SOFTDEVICE: INVALID MEMORY ACCESS
    Alex
  • Hi Alex,
    1. You can define the BOOTLOADER_START_ADDR symbol in options for target --> C/C++ --> Preprocessor symbols. E.g., BOOTLOADER_START_ADDR=0xE4000 if 0xe4000 is the start address of your bootloader
    2. You need to use the "nrf_fstorage_sd" when the Softdevice is enabled because the nrf_fstorage_nvmc will access the NVMC registers directly. This is why you get the invalid memory access assertion.
