Enabling Softdevice fails in bootloader when trying to initialize multiple DFU transports
I'm working on a bootloader that combines both the BLE and UART transport layers. We have custom hardware containing the nRF52832 chip running on SDK 15.3, and we're using softdevice s132 v6.1.1.
I started with the secure BLE bootloader example pca10040_ble_debug and then slowly added in the UART transport layer. I did this by first adding the file nrf_dfu_serial_uart.c to the project and then working through any errors when building in SES. Roughly, from memory, I think it involved the following additional changes to the project:
  • Added these additional files:
    • nrf_dfu_serial.c
    • nrf_drv_uart.c
    • nrfx_uart.c
    • nrfx_uarte.c
    • nrfx_prs.c
    • slip.c
  • Added these additional include paths:
    • ../../../../../components/libraries/slip
    • ../../../../../integration/nrfx/legacy
    • ../../../../../modules/nrfx/drivers/include
    • ../../../../../modules/nrfx/drivers/src/prs
  • Merging the sdk_config.h files from both the pca10040_ble_debug and pca_10040_uart_debug example projects.
The project builds without errors, but when running, I do not see dfu_targ advertising, and timed out when trying to perform a DFU over UART using nrfutil. Debugging through the issue, the error occurs when trying to enable the softdevice when initializing the BLE DFU transport layer. I get the following debug printout:
<info> app: Entering DFU mode.
<debug> app: Initializing transports (found: 2)
<debug> nrf_dfu_ble: Initializing BLE DFU transport
<debug> nrf_dfu_ble: Setting up vector table: 0x00072000
<debug> nrf_dfu_ble: Enabling SoftDevice.
<debug> app: Failed to initialize transport 0, error 4096
<error> app: Could not initalize DFU transport: 0x00001000
<error> app: Received an error: 0x00000003!
Error code 4096 is "NRF_ERROR_SDM_LFCLK_SOURCE_UNKNOWN" which is "unknown LFCLK source". However, I don't think this is really the issue since it is set up the same way as always when bootloaders, softdevices, applications have had no issue running. Also, to further debug, I removed the file nrf_dfu_serial_uart.c from the project, cleaned, and then built again and the softdevice enabled without issue. I even saw dfu_targ advertising. Which means that the issue is with adding in the additional transport layer, but I don't know why it would cause an unknown LFCLK source error to occur.
Wondering if it was a global issue with having multiple transport layers, I edited the project file to list nrf_dfu_serial_uart.c first so it would be the first transport layer initialized and it initialized successfully with the following debug printout:
<debug> app:
<debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
<debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
<debug> app:
Lastly, after doing a lot of research online, I noticed that a lot of other people's issues stemmed from FLASH or RAM size / placement. I tried changing the values but it did not have any effect. Nor do I think it's the issue since there was no suggesting in the debug printouts to change any of the RAM or FLASH values. But for the record, here are my values:
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x80000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x10000
FLASH_START=0x72000
FLASH_SIZE=0xc000
RAM_START=0x200057b8
RAM_SIZE=0xa848
**NOTE: I also tried running the project on a DK board and the same issue happens.
Any suggestions or help would be much appreciated. Thanks.
  • Yeah, we had previously done a bootloader update when migrating from SDK 14.2 to 15.3 and upgrading the softdevice, but didn't run into the size issue.
    When loading the hex file in nRF Connect Programmer, there seems to be two memory regions from 0x70000 to 0x7D2AC. I'm assuming those are both for the bootloader.
    Lastly, I'm assuming it is safe to predict that we should be fine for future-proofing?
    Adam
  • As long as you only loaded one .hex file, they belong to the same file yes. So in this case it is the bootloader ranges from 0x00070000 to 0x0007D2AC. I don't know exactly how nRF Connect for Desktop -> Programmer interprets that it is two several files, but I believe it looks for certain familiar chunks and sizes, in order to tell whether it is an application or a softdevice or MBR and so on. So since this is a bit modified, it probably gets confused.
    By the way, it looks like it uses the memory layout for the nRF52840. It doesn't really matter, but if you plug in an nRF52832 DK, it will use the memory range for that device. But again, it doesn't really matter. You should only look at the numbers.
    As for your memory settings. It looks good now. You still have the area from 0x7D2AC to 0x7DFFF for future expansion. You may already have done this, but remember to disable logging and turn back optimization (set it to -O3) and compile after you are done implementing the bootloader, because this will reduce the size of the bootloader. You may have already done this, but just in case.
    Edvin
  • And if -O3 is just a bit too big, try -Os optimization. This should be a bit smaller since -O3 unrolls loops.
  • Oh okay, interesting. It might be interpreting both the uart bootloader and the ble bootloader separately since they're combined.
    And I was wondering why the memory layout seemed to be double the size. That makes sense.
    I had already had optimization set to -Os (thanks for making sure!), and since my last post, I had turned off logging and save another ~20kB in size.
    Thanks Edvin for all of your help! It's much appreciated.
