Ndef library: multiple records update issue
I have multiple records that I want to update during the runtime of the program.
What is working:
1. I can write in memory for the first time initial values.
2. I can update all records and it works.
3. I can load all records and it works.
Problem:
When I update for the first time one of the records. All other records points the same "default" location, like they are de-referenced.
However if I update each record one time, it work fine forever.
#define FILE_ID         0x1111
#define REC_KEY         0x1908
#define TOTAL_RECORDS       3
static fds_record_desc_t  m_record_desc[TOTAL_RECORDS];
static fds_record_t       m_record[TOTAL_RECORDS];
ret_code_t ndef_file_load(uint8_t * p_buff, uint32_t size, uint8_t id)
    ret_code_t         err_code;
    fds_find_token_t   ftok;
    fds_flash_record_t flash_record;
    // Always clear token before running new file/record search.
    memset(&ftok, 0x00, sizeof(fds_find_token_t));
    // Search for NDEF message in FLASH.
    err_code = fds_record_find(FILE_ID, REC_KEY+id, &m_record_desc[id], &ftok);
    // If there is no record with given key and file ID,
    // create default message and store in FLASH.
    if (err_code == NRF_SUCCESS)
        NRF_LOG_INFO("Found NDEF file record for id %d", id);
        // Open record for read.
        err_code = fds_record_open(&m_record_desc[id], &flash_record);
        VERIFY_SUCCESS(err_code);
        // Access the record through the flash_record structure.
        memcpy(p_buff,
               flash_record.p_data,
               flash_record.p_header->length_words * sizeof(uint32_t));
        // Print file length and raw message data.
        NRF_LOG_DEBUG("NDEF file data length: %u bytes.",
        NRF_LOG_HEXDUMP_DEBUG(p_buff, flash_record.p_header->length_words * sizeof(uint32_t));
        // Close the record when done.
        err_code = fds_record_close(&m_record_desc[id]);
    else if (err_code == FDS_ERR_NOT_FOUND)
        NRF_LOG_INFO("NDEF file record not found, default NDEF file created.", err_code);
        // Create default NDEF message.
        ndef_file_default_message(p_buff, size, id);
        // Create record with default NDEF message.
        err_code = ndef_record_create(p_buff, size, id);
    return err_code;
static void ndef_file_default_message(uint8_t * p_buff, uint32_t p_size, uint8_t id)
    for(int i=0; i<p_size; i++)
        p_buff[i] = 0xFF;
static void ndef_file_prepare_record(uint8_t const * p_buff, uint32_t size, uint8_t id)
    // Set up record.
    m_record[id].file_id           = FILE_ID;
    m_record[id].key               = REC_KEY + id;
    m_record[id].data.p_data       = p_buff;
    m_record[id].data.length_words = BYTES_TO_WORDS(size); // Align data length to 4 bytes.
static ret_code_t ndef_record_create(uint8_t const * p_buff, uint32_t size, uint8_t id)
    // Prepare record structure.
    ndef_file_prepare_record(p_buff, size, id);
    err_code = fds_record_write(&m_record_desc[id], &m_record[id]);
    return err_code;
ret_code_t ndef_file_update(uint8_t const * p_buff, uint32_t size, uint8_t id)
    // Update FLASH file with new NDEF message.
    err_code = fds_record_update(&m_record_desc[id], &m_record[id]);
    return err_code;
Records are stored in a static fds_record_t array and they got their own individual key.
Any idea on the direction to explore ?
Thanks
  • hello, I have made a complete example that reproduces the problem.
    It was done using the sdk thread and zigbee and can be put in $(sdk_source)/example/multiprotocol/nle_thread
    That is excellent. Can you upload it to this thread? Which Thread and Zigbee SDK version does it work with? What is the procedure to test it to reproduce the issue?
  • It is version nRF5_SDK_for_Thread_and_Zigbee_v4.0.0_dc7186b
    To test, run the code with ses and watch the NRF_LOG_INFO outputs. I have put some commentary to hopefully guide you in the code.ble_thread_dyn_template - flash test.zip
    Your example clearly demonstrates an issue, but I have yet not been able to understand what causes this behavior. I am adding the log from your unmodified example here for my own reference. I will look more into this and get back to you.
    <info> app_timer: RTC: initialized.
    <info> app: BLE Thread template example started.
    <info> app: Thread version   : OPENTHREAD/20180926-01143-g8a1992e2; NRF52840; Dec 10 2019 22:48:00
    <info> app: Network name     : OpenThread
    <info> app: Thread interface has been enabled.
    <info> app: 802.15.4 Channel : 11
    <info> app: 802.15.4 PAN ID  : 0xABCD
    <info> app: Radio mode       : rx-on-when-idle
    <info> app: Fast advertising.
    <info> app: LOADING FLASH at counter = 1
    <info> flash_memory: NDEF file record <info> app: State changed! Flags: 0x009C13A5 Current role: 4
    <info> app: bar8        = 0xFF
    <info> app: bar16       = 0xFFFF
    <info> app: bar8_array  = 0xFFFFFFFFFFFF
    <info> app: LOADING FLASH at counter = 120
    <info> flash_memory: Found NDEF file record for id 0
    <info> flash_memory: Found NDEF file record for id 1
    <info> flash_memory: Found NDEF file record for id 2
    <info> app: bar8        = 0xB
    <info> app: bar16       = 0xB5B
    <info> app: NOW UPDATING FLASH
    <info> flash_memory: bar8 update
    <info> flash_memory: bar16 update
    <info> flash_memory: bar8_array update
    <info> app: LOADING FLASH at counter = 280
    <info> app: bar8        = 0x11
    <info> app: bar16       = 0x1111
    <info> app: bar8_array  = 0x111111111111
    Br,
    Einar
