Passing a float by value or reference
We are seeing some strange stuff when trying to pass floating point values to a function. When we pass the parameter by value (meaning as an actual floating point number) the parameters' value changes. When we debug the code we can see that in the disassembly there is a call too __aeabi_f2d. However there should be no reason to call this since all of the values are floats and not doubles. When we pass the floating point number by reference everything works fine.
We are using the nRF52840 with the gcc compiler that comes with the 4.20a version of segger embedded studio.
Meaning this does not work, the value of variable intermediate is not the same value as the value found in input_param :
  float32_t intermediate = *pIncomingSample;
  turn_gyry(intermediate);
void turn_gyry(float32_t input_raw){
  float32_t output_low_pass;
  float32_t output_moving_average;
  float32_t output_derivative;
  float32_t input_param = input_raw;
  filter_turn_gyry_low_pass(&input_param, &output_low_pass);
  filter_turn_gyry_moving_average(&output_low_pass, &output_moving_average);
  filter_turn_gyry_derivative(&output_moving_average, &output_derivative);
  printf("output low pass %f", output_low_pass );
  printf("output derivative %f", output_derivative);
But this works just fine:
  turn_gyry(pIncomingSample);
//the function definition of turn_gyry
void turn_gyry(float32_t *input_raw){
Does anybody have an explanation for this behavior? I believe that the call to __aeabi_f2d implies that for some reason the compiler thinks he needs to convert a float to a double but there is no reason to do this...
Any ideas are welcome
Thanks!
    What is your blockSize? If you pass the address of a first element of an array the behavior is different than if you pass address of one intermediate variable. The pass-by-value case would be valid only if blockSize is 1, and it would probably not make sense for FIR filtering.
    The example data used for this test is defined as a const float32_t. In non-test situations this data will not come from a const array, but from sensors so changing them to const is not really an option. But anyway in this case the variables come form a const array. Do you ask this because of memory corruption reasons or some other mechanism?
    Declaring variables as const whenever possible prevents a whole lot of bugs especially when there's a team working on a codebase. I think you should get a compiler warning if you try to pass a non-const array to the arm_fir_f32 in any case.
    As for the interrupts, we tried removing most of them for testing, there is no BLE active, no watchdogs, no Timers (other than the timer that calls the filter periodically). Basically we tried to limit the parts that could influence this code as much as possible for testing. Anyway I get no interrupts interrupting this code when I run it and also how would we then explain that the pointer version of the code is working just fine?
    Most of the bugs I encounter are coming from invalid assumptions. That's why I always stop to think about what my assumptions are and say them out loud. One reason why the code could be working just fine with pointer and break when using stack allocated variable is that an interrupt would be corrupting the stack somehow. My guess is on the blockSize though.
  • When we debug the code we can see that in the disassembly there is a call too __aeabi_f2d
    Those are required for those floating point printf() arguments. Floating porint variable arguments are always (and implicitly) converted to double.
    Ifn case these printfs() are only there for debugging, consider looking at how the NRF_LOG_FLOAT() macros work for displaying a floating point number using just integer arguments.
  • Thanks for joining in.
    I tried removing all the printfs and removed the support for floats in printfs in the compiler options. The disassembly still shows the aeabi_f2d. Also when stepping through the code we can see that the conversion is being called in the function call to "turn_gyry(*pIncomingSample) in which is cleary defined that this should be a float32_t. So it's not clear to me, even with the printfs, why the compiler would try to make a conversion here.
