Thingy91 LTE BLE Gateway Power Profile
I am currently working on a project that is set up similar to the Thingy91 LTE BLE Gateway application (Bluetooth HCI UART firmware running on nRF52840) and I am curious what the expected minimum power consumption would be in this configuration.
For preparation to the response to this ticket, I have searched and found the blog post detailing the power consumption on the nRF91 development kit titled, "Measuring PSM idle current on the nRF91 DK" but that is focused solely on the lowest possible base power consumption on the nRF91 development kit with LTE-M PSM and the standard firmware on the nRF52. The blog post was very informative but not exactly tailored to my specific use case (Thingy91/HCI UART).
In my project, I am utilizing the project/patches provided by Sigurd in the following DevZone ticket: https://devzone.nordicsemi.com/f/nordic-q-a/52689/nrf9160-lte-sensor-gateway-on-thingy-91/225659#225659.
When put on a power profiler, I am seeing quite a large draw (1.5-2.0mA) when sitting idle (PSM/eDRX negotiated with carrier on LTE-M). I suspect this might have to do with the UART peripheral remaining enabled with the bluetooth hci uart firmware running on the nRF52840. I have stripped my project down to the bare bones, turned off as much as I could in the project configuration (prj.conf) and even then I can't get the power consumption down. Even turning off serial, I can only get the Thingy91 down to about 500uA. Has Nordic done any power profiling in this configuration (Idle/Sleeping nRF9160 application with HCI UART on nrf52)? Does Nordic have a project that demonstrates low power consumption on the Thingy91?
If my suspicion is correct and its the UART peripheral keeping the power consumption high, is there anything I can do during runtime to disable/enable the bluetooth HCI uart dynamically?
Please advise.
Cody
  • Hey Sigurd,
    I am finally coming back to doing some power profiling on the Thingy91. I am using SB3/4 so that I can separate out the power domains and determine current draw from both the nRF52840 and the nRF9160. If I disable serial, logging and turn off both UARTE peripherals utilizing the config you posted above, it does appear that the power usage significantly drops.
    Unfortunately, because I am utilizing the nRF52840 as a HCI UART device, I am going to need to enable and utilize at least one of the UARTE peripherals for HCI UART. According to a separate DevZone ticket, it appears that the current draw I am seeing is what is expected with the UARTE peripheral enabled (https://devzone.nordicsemi.com/f/nordic-q-a/26030/how-to-reach-nrf52840-uarte-current-supply-specification/). According to the Nordic employee, Stian, on the ticket he states, "First of all, 0.8 mA (on nRF52840, no DCDC. 0.35 mA with DCDC enabled @3V) is the expected run current for the UARTE in RX or TX mode since HF clock is needed and the DMA bus is active."
    I guess my question is, because I don't need the the HCI UART controller to be active at all times, in fact it is rarely utilized, can the nRF52840 HCI UART firmware put the chip into a deep sleep mode or go into a low power state when the nRF9160 is not in need of bluetooth functionality?
    It should be possible, but the functionality here is not implemented.
    Note that we are currently working on a solution for a low-power HCI UARTE. It should solve the issues you are seeing with the power consumption. I don’t have a pull-request to point to right now, but if you check back here in 1-2 weeks the prototype implementation might be ready.
  • Sigurd,
    Thank you for the update, I will be looking forward to the prototype and closely keeping an eye on the progress.
    As for my current setup, according to Stian, the power consumption of HCI UART on the nRF52840 is 0.8 mA with no DCDC and 0.35 mA with DCDC enabled. The power consumption that I am seeing is nearly identical to the power consumption without DCDC even though the configuration for the HCI UART firmware in Zephyr for the nRF52840 enables and turns on the DCDC. This is verifiable from looking at the .config generated after building the project (CONFIG_BOARD_ENABLE_DCDC=y). Can you think of any reasons why my power consumption is 0.8mA instead of 0.35mA?
    Cody
  • Hey ,
    Just checking back on the status of low-power HCI UARTE since its been a couple weeks.
    Cody
  • Just checking back on the status of low-power HCI UARTE since its been a couple weeks.
    It's still work in progress. But you can have a peek look at the ongoing prototype implementation. See this and this link. This PR from upstream zephyr is required.
