I am trying to find where to submit bugs against the pc-ble-driver. There are two major bugs I have found
- saved CCCDs (in a bonded connection) do not get restored when calling the sd_ble_gatts_sys_attr_set() method with the locally saved configuration data.
- This bug is very problematic as there is no work-a-round. One simply will be unable to transfer data to a bonded peer on a reconnect (if the bonded peer follows the spec).
- This bug also prevents me from invoking a service-changed event (though it is clear that the peer has enabled the CCCD in the previous connection).
- when handling a BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST the update=0 option does not work. If one gets this event one MUST update the attribute value
- This bug is less severe because there is a work-a-round ... update the value. It may be the same value, but you need to call the update method with the update value.
I have posted these problems to the forum for some time now but its probably better to post them directly to the pc-ble-driver development team. Looked on git-hub but could not find a way to do it.
